Question about Microwave Ovens
Search Fixya...drscholls the wrapper model no. dr8540
Interior lite is out, dont know where the bulb is unless its in the rear compartment
If there's no obvious removable cover over the bulb (most often on the rear or side) and the owner's manual doesn't address it, then disassembly will be required.
You'll need to remove the outer cover (wrapper) to get to the bulb.
Always unplug a microwave before removing or installing any bulbs.
If it's an over the range type, remove the vent grille across the top and see if bulbs can be accessed there. There may be a panel on the bottom covering the light(s), instead.
If not, chances are you'll have to remove it from the wall, then remove the outer cover. If so, the installation instructions are very handy, and it's best to have two people since the microwave can be heavy and awkward.
Once it's out of the wall, the outer cover (wrapper) will need to be removed, just as you'll need to do on a counter top model.
On a counter top model, be sure it's unplugged, but otherwise ignore the instructions above this paragraph.
See these links before proceeding: http://031d26d.namesecurehost.com/mwd/safety.txt
http://031d26d.namesecurehost.com/mwd/disassembly.txt
The screws you need to remove should be pretty obvious, but a special driver (such as a T20H type or GTXH20-100) may be needed.
Be sure to put all the screws back in the right holes, since some may be special grounding screws.
Bulbs (or 20A ceramic fuses) can be had locally in most grocery stores, hardware stores, home improvement centers, and big box or department stores.
Many models use halogen lamps. You must not touch halogen types with your bare skin, as the oils will shorten the bulb life.
Jan 06, 2014 | Emerson Microwave Ovens
How to change light Daewoo KOR - 63F7
If you don't have your instructions, please reply back with your brand and model number.
http://www.microwavedisplay.com/safety.txt
http://www.microwavedisplay.com/disassembly.txt
Bulbs can be had locally in most grocery stores, hardware stores, home improvement centers, and big box or department stores.
Aug 19, 2009 | Daewoo Microwave Ovens
Light out
Many models use halogen lamps. You must not touch the new one with your bare skin, as the oils will shorten the bulb life.
Mar 14, 2009 | Sanyo Microwave Ovens
Light bulb replacement for sanyo ems3553 microwave oven
Mar 05, 2009 | Sanyo Microwave Ovens
How do i change the bulb on my emerson mw8991sb microwave
Mar 04, 2009 | Emerson Black Microwave Oven
How do you replace the internal bulb in the Siemens HF87950?
Mar 02, 2009 | Siemens Microwave Ovens
Light out
Bulbs can be had in most grocery stores, hardware stores, home improvement centers, and big box or department stores.
Feb 02, 2009 | Sanyo EM-P672W Microwave Oven
Have a tesco microwave Model number - MTG06 bulb blown ho do i replace it
Jan 24, 2009 | Microwave Ovens
Replace magnetron in a samsung smh7174
If you or a friend decide to look into it, we have critical safety information, info on door switch diagnosis and replacement, and disassembly information at our site, and our link is at our listing here on FixYa: http://tinyurl.com/yzjozk
But essentially you unplug the power, remove the microwave from the wall mount and remove the outer wrapper / cover.
Discharge the high voltage capacitor and then it should be pretty straightforward, but please do read and heed the safety warnings.
We're happy to help and we appreciate your thoughtful rating of our answer.
Feb 26, 2008 | Microwave Ovens
Door will not open (no tension on botton)
This is usually a broken door opening lever behind the door open button. Sometimes it is a broken tab on the door opening button. It will require visual inspection to tell. Since this is a counter top model, the outer cover / wrapper will have to be removed to get to the door opening parts. If you or a friend decide to work on it, we have *critical* safety and disassembly info at our site, which is linked at our listing here on FixYa: http://tinyurl.com/yzjozk You can order parts at one of these sites: http://www.pasc.panasonic.com/epartr http://www.vancebaldwin.com/
Mar 20, 2007 | Panasonic NN-P794SF Microwave Oven
Microwave Ovens Logo
19 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Microwave Oven Expert? Answer questions, earn points and help others
