Question about GE WVSR1060A Top Load Washer
Washer agitates, but makes horrible grinding noise. Spins okay.
Washer fills, but when it starts to agitate it makes a terribly loud grinding noise. Removed all the clothes, still made that terrible noise. Switched to spin cycle and it drained and spun just fine.
  • 15 more comments
  • robindenver Aug 27, 2007
    Solved my own problem! Upon removing the agitator, we found a tiny metal jewelry piece in the groove between the plastic inner tub and the metal inner that the agitator connects to. Hope this helps someone else sometime. Glad I didn't pay GE $80 to come look at it.
  • Anonymous Mar 13, 2014
    The agitator sometimes skips and doesn't turn the base of the agitator. It sounds like it doesn't complete its twist
    Grinding noise during spin cycle
    Recently my Whirlpool washer would not spin and started making clicking noise when it tried to spin. I replaced the motor coupler and now it spins, But, it still makes that clicking noise during the spin cycle. It drains & agitates fine. It looks as if the agitator is slipping during the spin cycle. Could this be a clutch or brake issue?
  • Anonymous Mar 16, 2014
    When you first turn on the washer and it starts pumping it makes a loud grinding noise. Then after the rinse as it starts to drain it makes the same noise but spins fine
  • Anonymous Mar 18, 2014
    My washer will fill up, drain and spin like normal but it will not agitate. The agitator is hard to turn and makes a growling noise.
  • Anonymous Mar 19, 2014
    Makes noise when washing and spinning and clothes are not spun enough gives up sign
    Spins slow leaves clothes to wet
  • Anonymous Mar 21, 2014
    Basket spins but then starts hittingand makes loud noises
    noticed burning smell, now spinning, but makes a noise like it is struggling to spin.
    It filled then shut off. I turned it back on and it made a grinding noise, then shut back off. There's a bad , burn like smell.
  • Anonymous Mar 26, 2014
    the washer will agitate, but will not spin on rinse cycle. I can hear a slight grinding noise when on the rinse cycle and the tub does not move
    while in wash mode you hear a grating noise
  • Anonymous Mar 30, 2014
    the machine used to
    what could this be
    washer will not agitate or spin. but does drain
  • Anonymous Mar 31, 2014
    Danby DTT420 portable washer making a loud noise when in spin even with no clothes in it
  • 291 Answers
Thanks for posting problem solve :0)
Posted on Sep 03, 2007
I have a top load fridgidaire washer model fwsc445rfs0. During the wash cycle it makes a high pitched scraping noise.... Struggles also while it winds down before rinse. Bearing maybe?
How To Fix A Washing Machine Making Noise During The ...
removeandreplace.com/.../washing-machine-making-noise-during-the-sp...
Jul 27, 2015 - Agitator directional cogs aka "agitator dogs" (top load washers) ... If you hear a rubbing sound or the drum spins uneven, then the ... A washer making a loud noise during spin cycle can also be caused ... The clutch in a washing machine connects the inner wash tub to the ..... May 8, 2015; High Water Bill?
Dishwasher Making Loud Grinding Noise During Wash Cycle
removeandreplace.com/.../dishwasher-making-loud-grinding-noise-durin...
Apr 11, 2014 - Dishwasher Making Loud Grinding Noise During Wash Cycle ... GE, Whirlpool, Frigidaire, KitchenAid, Maytag, Kenmore, and LG) this is a .... Our Amana dishwasher is making a loud, high-pitched squealing noise throughout the wash ....Out Of A Washing Machine - Top Load & Front Load September 30, ...
All comments on Loud dishwasher Frigidaire Gallery mode ...
https://www.youtube.com/all_comments?v=v-arYb20kOk
Dec 03, 2015 | Washing Machines
Washer makes grinding noise when it agitates
check back of unit as the concrete on the back may of been dislodged check not over loaded also the belt maybe loose or streached
Jan 02, 2014 | Crosley CAWC529JQ Top Load Washer
I have a ge washer. it fills up okay, but will not agitate. the water spins out okay also. and it goes through all steps but clothes were not washed due to not agitating. the model number is WCSR2090D.
If the agitator can be moved freely by hand, you probably have a stripped bell, which is the small plastic dome that the agitator is attached to. Maybe hear a grinding noise in agitation from under the agitator?
It takes a large amount of force to pull the agitator straight off to access the bell, which has one small bolt securing it to the transmission shaft.
Bell is a fairly inexpensive part. Not saying this is your problem, but would check this first, as it is a common repair.
good luck
Feb 23, 2010 | General Electric WCSR2090D Top Load Washer
Water fills to proper level but agitator doesn't come on instead there is a grinding noise, when I move control to just prior to rinse cycle water drains properly, but still just grinding or buzzing n
Hi, Do you know if the washer spins at all?
It sounds like the coupler has gone bad.
Please let me know if it spins at all.
I can send yyou instructions on changing the coupler.
Vic
May 28, 2009 | Whirlpool LTE6234D Top Load Stacked...
KitchenAid washer Model#KAWS700jqsr fills but won't agitate
if it's making a loud buzzing noise while its suppose to be agitating or spinning its the motor coupling
Dec 20, 2008 | KitchenAid KAWS700L Top Load Washer
Loud grinding motor protesting humming w/no spinning or agitating
The drum/agitator bearings are bad I believe, or the gearbox has been damaged. This is an expensive repair. I would strongly consider buying a new washer. This is a great time to buy appliances since the stores are really competing, and the prices are at their lowest.
Ray
Dec 14, 2008 | Kenmore 22422 Top Load Washer
Terrible noise when agitating
Your transmission has gone out. The reason the spin cycle works is because the transmission spins two different ways and you agitate way stripped the gear. Some places rebuild them. Try with your local stores maybe they can rebuild it or get you a good used one. If not you can order a new one from sears.com
Nov 12, 2008 | Kenmore 24032\24036 Top Load Washer
My Capacity Plus Admiral Washer will spin and agitate, but it makes a loud grinding noise.
Well, Sounds to me like the Bearings are going out, but it could make that noise a good while, before it goes completely out.. Replacement would possably be more cost effective, Kinda hard to beleive !!!!!!
Oct 26, 2008 | Washing Machines
Grinding niose from agitator.
If the fill and drain functions correctly, AND the spin cycle works correctly, AND the cycle itself starts and completes correctly, the problem being that the back and forth motion of the agitator starts the loud grinding noise, it will likley be broken gears in the transmission. The single most expensive part in the washing machine.
Feb 04, 2007 | Maytag Atlantis MAV6451 Top Load Washer
GE WVSR1060A Top Load Washer Logo
4,196 people viewed this question
Top GE Washing Machines Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
