Question about Air Cool Dryers
I bought an uberhaus water cooling fan less than a year ago, now the water cooling part doenst work
The light showing the air cooling feature will rarely turn on. air doesnt cool and occasionally the fan beeps for 10 or 15 mins then stops.
  • 883 Answers
SOURCE: Fan will not work
open it. look for a wire that has become disconnected from careless factory assembly
Posted on May 20, 2007
  • 146 Answers
SOURCE: refrigerator stopped cooling
The most common problems for refers not cooling is a condenser fan motor (the one that cools the compressor) is out. This can be caused by either a mouse has tried to jump trough the fan and it came on or a loss of grease or oil. There is no way to oil them so they have to be replaced. That is the problem especially if you unplugged the refer and it worked for a while then quit. If the fan doesn't cool the compressor it will overheat and shut down coming on intermittently then shutting off again. As for the refer that still doesn't cool when everything else does you may have an burnt overload also. Check the compressor area for burnt or stalled components ex. fan motor, relay, overload. If your compressor is out plan on spending from $300.00 to $500.00. But check the suggested components first. And beware there are appliance shops out there that will find one of these problems and give you an estimate for a compressor. Find someone reputable.
Posted on Dec 18, 2007
the dr
  • 447 Answers
SOURCE: Kenmore 106.53603202 stopped cooling making a clicking sound
The compressor may not have to be changed it could be the relay that is bad, not properly starting the compressor. The relay is attached to the compressor where the wires go to it. Remove it, Shake it, If it sounds like little rocks are inside (it rattles) than it is bad. Let me know what you find
Posted on Jan 05, 2008
refritech08
  • 149 Answers
SOURCE: Help!! No cooling, just fan!!!
you probably have a defective contactor or start capacitor on condensing unit. if you pretty handy with wiring go to the condensing section open the panel. you should see a contactor (it's the little black piece with all the wires) check the condition of it. next to it is a capacitor and by the problem that you describe it could be that. check it if it looks bloated there's your problem just go an get an combination capacitor and wire up. (make sure the power to unit is off first. any other questions email me @ hvac.tech7872pr@gmail.com
Posted on May 09, 2008
fredcause
  • 51 Answers
SOURCE: Fan and light no longer turn on
possibly the thermal overload sensor failed internally? as indicated in the instructions there is a overload sensor and thay will typically fail in others appliances.
Posted on Dec 08, 2008
Why did my Hairer 8000 BTU portable A/C quit cooling on cool mode? It was working very well. This afternoon, I went into the bedroom, where the A/C is located, and room was not cool. When I switched t
Do you hear compresser start up noise. If so then please check it with a clamp meter and Amperage the Unit is drwing. If it is less than 8-9 Amps than there is some leakage in the AC and all the collent has leaked. So you got to get it serviced.
Sep 25, 2014 | Haier Heating & Cooling
I have a 98 Chevy Cav 2.2L.
Make sure your radiator fan is working or cutting on.It could be a faulty fan relay or fuse and it could also be a faulty coolant temperature sensor.
Jan 24, 2012 | 1998 Chevrolet Cavalier
Hi. I have a HP laptop for about 3 months and now it gives me the message " a cooling factor is not working properly" , and it shuts down 15 minutes later. what should I do? Should I go to the...
The laptop should be covered since it is only three months old. That's the good news. The less than good news, is that you may have to wait a while before you get your computer back.
I don't have the laptop in front of me, so naturally I can't diagnose the problem directly.
I would hazard an intelligent guess that the Cooling Fan inside the laptop has failed.
Components inside a computer are normally cooled by air. (High tech gamer computers may use a different type of cooling system. They may use water, or a refrigerant of some sort. { Dry Ice, Nitrogen, Freon, etc)
Two main computer components generate the most heat.
The Processor, and the graphics chipset. (Video chip, Same/same)
The Processor is the 'Brain' of the computer. It's designed to operate up to a maximum temperature, (Thermal Limit), and no higher, or damage to the Processor will result.
There is a Fail Safe feature built-in to turn the Processor off, if it becomes too hot.
(BIOS turns the Processor off)
With no cooling fan operating the Processor will overheat.
You didn't indicate what model name, and model number your HP laptop is.
This is to just show you what an average cooling fan looks like in an HP laptop,
(HP DV6 series ), and what is entailed in order to access it,
http://www.insidemylaptop.com/disassemble-hp-pavilion-dv6-laptop/
Scrolling down to Step 24, and 25 shows the top view of the cooling fan.
Step 29 shows the bottom view.
Would appreciate hearing the outcome, please reply in a Comment.
Regards,
joecoolvette
Apr 26, 2011 | HP (344872-001) Laptop Cooler, Cooling Fan
Replace cooling fan termstat and vehicle still over heats
Thermostat
Test thermostat in a jug and pour boiling water on it , it should compress meaning it works. Check that the waterpunp is operating pushing water into the engine .Check that radiator water flows to the watrpump. Is tension of fanbelt of waterpump sufficient that it doenst slip. Lastly check that the radiator fan is working if has a electric fan. if this doesn’t help check if radiator or engine water passages isn’t blocked.
Aug 29, 2009 | 1995 Pontiac Sunfire
Bought 2 several years ago. Neither one cools
What type of refrigerant is running with these units? what Ambient temp do they work in? what is the temp of the Air off.
Jun 09, 2009 | Maytag M6Q10F2A Air Conditioner
I have a Mitsubishi DLP 1080p TV with air flow problems
Hello ags98,
First I would suggest that you re-seat the bulb and then check the cooling fan, and air flow path. In addition to checking the fan make sure all air flow ingress and egress vent are unobstructed.
I hope this helps
Thank you,
Shuttle83
Oct 01, 2008 | Televison & Video
sounds like the unit is low on charge.you will need a pro to check it
Aug 04, 2008 | Heating & Cooling
Sunpentown SF-609 Evaporative Air Cooler - no cool air
Sometimes there is a separate switch to turn on the water pump. No water=no cooling. Check to make sure the cooling pads are wet! If they are completely wet and the fan is blowing it should cool.
Jul 06, 2008 | Sunpentown SF-609 Air Cooler Fan
I have a Honeywell oscillating quiet cooling tower fan that was bought two years ago. Loved it, till yesterday it just stopped working. the oscillating feature still moves, but the fan does nothing. the...
Could be fixable but until someone determines the problem there is no way of knowing if it is fixable. Could be a broken wire between the selector switch and the motor or the motor itself could be bad.
When you are trying to operate it does the fan motor get warm or hot? Does the fan turn freely?
May 03, 2008 | Heating & Cooling
Dryers Logo
246 people viewed this question
Top Air Cool Dryers Experts
Dan Webster
Dan Webster
Are you an Air Cool Dryer Expert? Answer questions, earn points and help others
