Question about Sharp Aquos LC65E77UM 65 in. LCD HDTV
Sharp Aquos 65" LCD: LC65D64U DEAD no power
This TV when plugged is DEAD! No standby light. The AC enters the power control board at 120 Volts and the fuses seem to be ok. None of the PINs have any DC voltage except for PP3 which reads around 2.0 to 2.5 VDC. I am assuming this is the standby voltage, which i believe should be 5 VDC. Am i correct in assuming this and if the standby is approximate 2.0 VDC I have a bad power supply board? Any help would be appreciated.
    Top Expert:
  • Sharp Master
  • 75,424 Answers
To get the accurate values to all the pins and test points, you have to download the repair manual to this set by internet. If you wish to get some details about the voltage charts, check the site linked here. http://electronicshelponline.blogspot.com/ Pull up previous posts there, either by its left side bar, or view it in Timeslide option.
Posted on Jul 10, 2013
  • Michael Jul 13, 2013
    Unfortunately, the repair manual does not have the voltage chart.
4 Suggested Answers
dsacco86
  • 1077 Answers
SOURCE: have a 30" SHARP Aquos LC30HV2U that has a bad power supply. Nothing happens when I turn on the LCD - though it is getting power confirmed by green light going on but nothing on LCD. Visual inspection
You did try the CLEAR button on front of the box?
One possible idea is the cables going the box to the TV. ( might be bad )
If your sure about the problem, you can get your Service Manual here:
http://www.nodevice.com/manual/newmans/upsharp/LC30HV2UPDF/get53718.html
This with have all the schematic, diagrams, part number, and test points you need.
Posted on May 17, 2009
  • 63 Answers
SOURCE: Problems with Sharp LC65D64U 65 in. LCD TV?
...here is where to download your manual
Posted on Oct 07, 2009
  • 8909 Answers
SOURCE: Is there a generic power supply for the following
If it is external, there will be one.
eBay will give you the widest chioce and I found six suppliers on the first page from Google.
Hope this helps
Posted on Dec 10, 2010
Samsung tv un60j6200afxza version ns02. No standby light and will not power on. Power board tested ok by tv tech. Replaced main board and still not working. Yes board tested ok. Tried multiple outlets to...
Power board is where 120 volts AC enters the TV. From the rear, the power board is on your right hand side (not bottom). After 120 volts, there is a fuse on the power line. Then the 120 volts go to a high voltage transformer and then there is a capacitor - 100 uf at 450 volts DC. Check the voltage here -- should be at least 390 volts or higher. If not, replace this capacitor with a higher capacity, ie, 350 uf with a rating of at least 400 volts (or any combination of capacitors totaling 350 uf.)
Dec 29, 2017 | Samsung Televison & Video
Im looking for a baseor stand for my 65 inch sharp aquos tv LC65D64U.thanks
Search for it in ebay site. Universal base stands are available for different brand LCD tvs.
https://electronicshelponline.blogspot.com/
Jul 24, 2016 | Sharp Televison & Video
Where can I get an HDMI board for my Sharp Aquos 65 Model LC65D64u
go to ebay and put your model tv in the searchbar followed by the word parts u may need a mainboard
Jan 29, 2013 | Sharp Aquos LC65E77UM 65 in. LCD HDTV
Sharp aquos 60le8 willl not power up. power led is flashing.
power supply board is dead, do you know basic electronics' and soldering? Most of the times, the power supply board just have dead leakages gases capacitors.These capacitors always bulges up on it top,or puff up on it top.Replaced these gases leakages capacitors will get your TV power stable,and work again.Or tries websites like Shopjimmy.com,Ebay.com to buy a whole refurbish power supply board for the replacement.
Hope this workout in solving the problem...
Jun 19, 2011 | Sharp Aquos LC65E77UM 65 in. LCD HDTV
52inch Sharp Aquos has a constant blue blinking power on light no picture at all.Tried the resets,still the same,installed new inverter boards,still the same.Now what?
This problems is not those 2 long LCD inverter boards problems,why did u replaced those 2 long LCD inverter boards?I fix this problems before for a 46" LCD Sharp Aquos L46D55U tv.This problems,it the Tuner signal board is dead.That the board,where the incomming broadcasting signal cable plug into it.Tries websites like Shopjimmy.com,Ebay.com to buy a refurbish Tuner signal board for the replacement.
Nov 08, 2010 | Sharp LC52D65U 52 in. LCD TV
My sharp aquos lc-32p55e tv.When u swith it on it will go from standby to green light for 4 or 5 seconds and then switch back to standby
Ur power board have dead parts,Check parts like Capacitors puff up or burst open.Know how to solder?Or replaced the the whole power board,Websites Shopjimmy.com,Ebay.com have reburbish power board.
Jan 13, 2010 | Sharp LC32P55E 32 in. LCD Television
Sharp aquos won't turn on
Any indicator lights on, if it is then you only have the standby 5v circuit working, you will need to have the power supply check out first, that is a starting point.
Oct 30, 2009 | Sharp Aquos LC-46D62U 46 in. LCD HDTV
Oct 06, 2009 | Sharp LC65D64U 65 in. LCD TV
The TV just don't turn on
Check ur power source like A/C cord connection.If ur power light & stand by light blink.Ur power ic inverter board is dead.
Aug 25, 2009 | Sharp AQUOS LC-65SE94U 65 in. LCD HDTV
My Lcd tv doesnt come on ... jst the power light blinks
hi..
You have a bad relay hopefully you have warranty coverage for ur tv... replace ur relay unit..
thank u
rate me!!
Jul 27, 2009 | Sharp LC65D64U 65 in. LCD TV
Sharp Aquos LC65E77UM 65 in. LCD HDTV Logo
185 people viewed this question
Top Sharp Televison & Video Experts
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
