Right side of my remote is not working for Vizio VW22L High Definition LCD
Buttons 3,6,9,- Volumn up & down ARE NOT WORKING. NOT A BATTERY PROBLEM! HOW DO I FIX?
  • 4 Answers
SOURCE: Vizio GV42L 42 in. LCD
May be a bad power supply, which is a common problem with these units.I have a GV42L 42" manufactured in march 2007. It works perfect except the screen has a fracture on it. The warranty is voided because we damaged the screen. I can sell this to somone who has a good screen but needs boards or speakers, etc. Or I will buy your tv that has a good screen but damaged boards in it.
camckay7626@yahoo.com
Posted on Sep 06, 2008
SOURCE: channel buttons (up/down arrows)
I called the Vizio help line. The solution is to auto re-scan for channels. I was skeptical, but it worked!
Posted on Oct 14, 2008
  • 4 Answers
SOURCE: New Vizio TV - Channel up and down buttons don't work
upon the psp and try to fix it
Posted on Apr 10, 2010
toolkits
  • 1099 Answers
SOURCE: JK321 32
well this is common on your model and could be a few different things. one is the video circuit and a cost would range around 100.00. the other is a weak picture tube this would cost more than the TV new. sometimes when it is the tube we can adjust it but it does not always last long. sounds to me it would be better to invest into a newer TV in this case.
good luck :)
Posted on Jun 02, 2010
SOURCE: CANNOT GET MY CABLE REMOTE
Try 11822.
Posted on Aug 07, 2011
The vizio set will not respond to remote to turn set on.
Point the remote at your cellphone camera and press a button. You should see a flicker from the remote if it is working. If no flicker then remote is defective. If you have a flicker then the problem lies in the t.v. could be the receiver or another issue in the t.v.
Jul 21, 2016 | Vizio 60" E601I-A3 Full HD LED-LCD TV
The remote isn't working
A few things to try:
1) Make sure Batts. are in correctly.
2) check in all around the sides back and under the sound bar for a reset button.
3) Clean the IR emitter on the remote and the receiver on the bar. On the remote it will be a reddish plastic window or a small bulb looking thing on the front. The receiver may be harder to find. I suggest just giving the entire front of the sound bar a good cleaning. I have had remotes stop working because there was to much dust built up on the receiver. I have also found that my kids handled the remote with dirty fingers and had gotten peanut butter on the emitter! Good Luck!
Jun 25, 2014 | Vizio High Definition Sound Bar
Vizio sound bar codes
If you get a Vizio sound bar it comes with its own remote control and is, therefore compatable. If however, you want to control all of your electronic devices with one control, instead of searching for the particular codes just spend some small amount on a universal remote unit which has instructions that come with it that show you how to have the remote find and store codes for a whole bunch of devices including the sound bar!
Jan 01, 2013 | Vizio High Definition Sound Bar
The screen on our 42"
  • Turn on your VIZIO HDTV. Press the orange button with the "VIZIO" logo, which looks like a letter "V" with a triangular wedge in the center. If there is no VIZIO logo button, press the "Menu" button. Press the "Right Arrow" button twice to highlight the "Setup" icon, which looks like a wrench.
  • 4
    Press the "Down Arrow" button three times to highlight the "Wide" menu item. Press the "Left Arrow" or "Right Arrow" buttons repeatedly until the correct aspect ratio is selected. "Normal" is for a standard definition 480i signal, which has a 3:4 aspect ratio. "Wide" is for high definition signals, and has a 16:9 aspect ratio. "Panoramic" stretches the outside of the image while keeping the center at the normal aspect ratio. "Zoom" enlarges the image on the screen. Press the "Last" button twice to close the VIZIO on-screen menu.
  • 5
    Watch the image on the screen of your VIZIO HDTV to ensure that the picture is at the right aspect ratio. If it still looks distorted, it's most likely because you chose the wrong aspect ratio setting, because your source device is set incorrectly or because you used the wrong connection method.
  • Feb 27, 2011 | Vizio VW42LF 42 in. LCD HDTV
    The only button that works is the remote power button. None of the buttons on the side of the tv work. The volume bar is always visible. The picture works when I'm watching a dvd, but the volume bar is...
    Hi check to see if the volume button on the side is pushed in or sticking as this will cause all the buttons to not work as the micro thinks you are trying to turn up the button and thinks this button is depressed.
    Dec 23, 2010 | Vizio VW22L 22 in. LCD HDTV
    While installing a new vizio m550nv model the screen permantly from on "Vizio Internet Apps." We tried unplugging for 5 minutes, every button on the remote, including holding down. All Vizio tech support...
    Try using the control on the right side near the bottom on back of set. Pushing this nob should get you to any menu that you want. rotating will change volumn when in the audio selection and etc.
    Sep 19, 2010 | Televison & Video
    Looking for remote codes for vizio sound bar and comcast remote
    After much research, here is a step-by-step for getting your Vizio Soundbar to work with the Comcast remote using EFC codes (mine is the newer charcoal grey one, works great!)
    Aux - Setup (2 blinks) - 11144 (2 blinks)Aux - Setup (2 blinks) - 994 - Setup - 00169 - Vol Up - Should get 2 blinksAux - Setup (2 blinks) - 994 - Setup - 00168 - Vol Down - Should get 2 blinksAux - Setup (2 blinks) - 994 - Setup - 00037 - Mute - Should get 2 blinksAux - Setup (2 blinks) - 994 - Setup - 00165 - Power - Should get 2 blinksAux - Setup (2 blinks) - 994 - Setup - 00164 - Input - Should get 2 blinks
    These are optional, I didn't use them:Aux - Setup (2 blinks) - 994 - Setup - 00036 - <button to use for TVOL> - Should get 2 blinksAux - Setup (2 blinks) - 994 - Setup - 00101 - <button to use for TSHD> - Should get 2 blinks
    Then set the volume control on the remote and other settings according to the Remote's manual.
    ENJOY!! Hope this helps someone...
    Aug 28, 2010 | Vizio High Definition Sound Bar
    My Vizio remote doesn't work...
    I know that on the Logitech Harmony Remotes, sometimes the infrared LED emitters go bad. Perhaps that is what is happening to your Vizio remote. If everything was working just fine but now none of the buttons work, it is probably your issue. You can test to see if the LED(s) are working by using a digital camera (or cell phone camera). Here is link that describes how to test to see if your IR emitters are working. Although you have a different model, you may be able to pick up a few tips from this article. Good luck!
    http://hubpages.com/hub/HowToFixaLogitechHarmony880Remote
    Mar 02, 2010 | Vizio VW22L 22 in. LCD HDTV
    How to remove the subtitles off my vizio
    you need to use your remote and press the menu button. under the audio options, you will have the CC, close captioned, options. just turn off.
    Apr 08, 2009 | Vizio VW22L 22 in. LCD HDTV
    Televison & Video Logo
    13 people viewed this question
    Top Televison & Video Experts
    Electro Med Services...
