Question about Home Security
Vemco gt200 stanley garage door opener
I have 3 car garage all with vemco gt200 stanley garage door openers. the middle bay was working fine by remote and by wall-mounted opener. Now it is having trouble..I have to push and hold the wall mounted button and hold it in the whole time the door is closing. it is opening fine..ie push button once and door opens. to close...have to push and hold or if you lift you finger off the button the garage stops closing and the light flashes
  • 476 Answers
SOURCE: Liftmaster 1280 LMC Motion Detector Garage Opener Push Button Pad Not Working
Have you tried to reprogram the chanel again?
Changed the battery?
Posted on Aug 02, 2008
  • 3197 Answers
SOURCE: Liftmaster 971LM opens but won't close correctly
Check the wiring going to the sensors to make sure it is not broken or disconnected. You have a problem with the sensors themselves or the logic board. Unfortunately the only way to be sure is to replace.
Posted on Jul 14, 2009
lobsterman72
  • 91 Answers
SOURCE: Door will only close when held down
That normally happens when the sensors aren't aligned. Both sensors have led lights on them the yellow/orange one will stay on all the time the green one will go out if it cant see the other sensor. Possibly theres a wire that's broken or the other sensor is really out of alignment. Check every inch of wiring from the sensor to the opener, remove wire nuts if present and check the connections. The wires that are used are small, solid and can break easily. Also see if there's a staple that's too tight, move the wire abit where it's stapled and look for damage.
Posted on Jun 27, 2008
  • 3197 Answers
SOURCE: Sear garage door wall mount contol light keeps blinking
Hold the button with the lock icon in for 3 seconds. This should toggle the unit off vacation mode and your remotes will work.
Posted on Jun 01, 2009
  • 3197 Answers
SOURCE: I have a craftsman garage door opener (1/2 hp) won't close proper
Check your door sensors. They have probably been bumped. Tweak them until they are pointed at one another and the small light on each one is lit and not blinking.
My liftmaster formula1 opens everytime but only the wall button will close it. Once in a while a remote will work but rarely. I have one remote, one vehicle oem remote and a wall mounted remote outsid
does it attempt to close. stop go back up and the lights flash....if so check the safety eyes, check for boken spring/ springs using the wall mount button circumvents the safety system. check the down pressure setting.
Nov 15, 2014 | Building Materials
I have a liftmaster formula 1 1280R opener that works fine from the wall mount but all of a sudden both remotes and the built-in remote in my car stopped working. It is not the batteries in the remotes. ...
The motor/control unit may have gotten reset. It needs to relearn the codes transmitted by the remotes.
MIne has a "learn" button on the control unit. Press and hold, then press the button on the remote. Lights will flash indicating it has received and stored the code. Release button.
Check to see if the remote works now. If so, all three should be working. If not, dig up your manuals.
Feb 28, 2013 | Sears Craftsman LiftMaster Chamberlain...
How to reset garage door opener pad without old acess number
A Stanley garage door keypad is wall-mounted, battery-operated device that allows you to open your home's garage door electronically without having to manually lift the door or use a pull chain. The keypad uses a four-digit access code that you program after the keypad is initially installed. You can change the code, disable the keypad manually by entering a invalid code and reset the keypad if the device is not working properly. After you reset your Stanley garage door keypad, the device is ready to accept a new access code.
May 29, 2010 | Sears Craftsman LiftMaster Chamberlain...
Garage door will not open close with remote
Press and hold for 3 seconds the button on the wall control with the lock icon.
Aug 29, 2009 | Sears Craftsman LiftMaster Chamberlain...
Garage door wont work with remote
If the small light in your wall control is blinking it is in the lock mode. Press and hold for 3 seconds the button with the icon of a lock. This will toggle the lock function off.
Aug 04, 2009 | Sears Craftsman LiftMaster Chamberlain...
My keypad works,my remote opener does not, even
It is related. One of the buttons on your wall control is the lock button and has a lock icon on it. Press and hold it for 3 seconds. The blinking should stop and your remote should now work.
Aug 01, 2009 | Sears Craftsman LiftMaster Chamberlain...
May 31, 2009 | Sears Craftsman LiftMaster Chamberlain...
Have chamberlain security plus 950cb lost instructions.
http://www.chamberlain-diy.com/doityourself/pdfdocs/114A2184.pdf
This web address came from the Chamberlain site. I also needed to relearn my remotes due to a newer car that has a built in garage door opener that needed to be set. I also needed to reset my keypad remote, those instructions I was able to get from the same site. Good Luck
Apr 05, 2009 | Chamberlain 950CB Remote Control
Home Security Logo
391 people viewed this question
Top Home Security Experts
Lawrence Oravetz
Are you a Home Security Expert? Answer questions, earn points and help others
