Question about Garden
Cub cadet 1554 24 horse Koehler not charging battery. New battery and stator. Any help?
    Master:
  • 969 Answers
Check for in line blown fuse.
Posted on May 28, 2014
joboo1
  • 257 Answers
SOURCE: transmission oil ? for cub cadet tractor
Hi, Cissy, Every Cub Cadet is different, and they keep their manuals to themselves. With your exact model and serial number, you can go to their website and view the manual for your model which should have the type of oil you need. Their website is www.cubcadet.com and go to service. If you have trouble, let me know, but I will need the model and serial. Good Luck, this should Fixya!
Posted on Mar 23, 2009
  • 8 Answers
SOURCE: cub cadet 2140 wont start or turn over
check the cilanoid or the stater , you may also have a lose conaction, try cross jumping the cilanoid
Posted on Aug 16, 2009
  • 4 Answers
SOURCE: I have a Cub Cadet lawn tractor that just stop
CHECK THE FUSE
Posted on Jul 02, 2010
hunter19_46m
  • 7482 Answers
SOURCE: Cub Cadet 2166 won't start...........new
Sounds like your solinoid switch is bad, replace it
Posted on Oct 03, 2010
  • 2239 Answers
SOURCE: Cub Cadet LT1050-Replaced the solenoid, had starter checked out-it's good, battery has full charge, but mower won't start. Help!!
You need to check that there is a 12volt supply from the low tention wire at the solinoid when the key is turned, if there is not either the switch is bad, or the wire from the switch is bad, or the fuse has blown.
Posted on Mar 07, 2012
My 25 horse power cub cadet mower starts and runs great until you try to mow with it and it has no power. At half speed it mows fair but in heavy grass no power. Any help app. Bill
be sure the battery is fully charged. be sure the blades are sharp. be sure there is no grass or string or wire wrapped around the spindles under the deck. be sure it is firing on both cylinders . be sure the belt is in good shape .
Jul 05, 2017 | Cub Cadet Garden
My 04 cub cadet m60 tank with a 27hp Koehler just up and quits after 20 min. I just changed oil and filter and "change oil " is blinking. Help
I'm not a Cub dealer but the "change oil" light should reset itself after usually an hour of use. check the oil level for the no start. if it has an oil level switch and is low, there will be no spark.
Jun 01, 2016 | Cub Cadet Garden
Won't charge battery
Yes, but most likly not. It could be the rectifier is just a loose connection.
Jul 09, 2014 | Cub Cadet Riding Lawn Garden Tractor 25hp...
Does a cub cadet model 2544 use a alternator to charge the battery my battery is not holding a charge alredy put in a new battery
yes it has a low amp charging system charge the battery and disconnect the neg cable install a test light between the cable and the battery if the light is on there is a draw unplug the harness that goes to the charging system if the light then goes out the diode on the charging system is bad
Aug 06, 2012 | Cub Cadet Lawn Mower Electric PTO Clutch...
Starter generator turns over slow with new full charged battery on a 124 cub cadet when trying to start. It is a new starter generator - suppose to have been tested. I have checked wiring - acts like it...
With the battery going dead on its own like that, I think you have a short circuit somewhere that is causing this problem. This could be anywhere in your wiring system so check everything out. Hope this is helpful to you. Best regards and good luck.
Jan 08, 2011 | Cub Cadet Lawn Mower Electric PTO Clutch...
I have a cub cadet 1525 mower with the kawasaki engine. the mower will not charge my battery. i have to take it out and charge it every 4 to 6 weeks. do you know what my problem is?
The charging system is only two parts. A stator and a regulator....I would locate and test the regulator first. If it is intact you can consider getting the stator replaced.
Jun 27, 2010 | Cub Cadet Garden
Cub cadet 1610 rans the battery down went mowing.
Hello bigdave1138:
From your Description it Sounds like the Stator/Charging Coils are Bad or the Voltage Regulator (if Applicable) is Bad.
For Testing the Electrical (Charging) System on Mowers you can Use this Site Addy; http://faqs.custhelp.com/cgi-bin/faqs.cfg/php/enduser/std_adp.php?p_faqid=3438&p_created=1101706364&p_sid=4fQ1f8Xi&p_accessibility=0&p_redirect=&p_lva=3443&p_sp=cF9zcmNoPTEmcF9zb3J0X2J5PSZwX2dyaWRzb3J0PSZwX3Jvd19jbnQ9NTEmcF9wcm9kcz0mcF9jYXRzPTAmcF9wdj0mcF9jdj0mcF9wYWdlPTEmcF9zZWFyY2hfdGV4dD1Wb2x0YWdlIGFuZCBTdGF0b3IgQ2hlY2s*&p_li=&p_topview=1 and Use the Link for AC Volts/DC Amps Meter Setting Chart. This is for Briggs Engines and Works Well for Kohler and Other Engine OEMs.
Please, Do Not Hesitate, If you Hit a Snag or this Does Not Correct the Problem, I am Here if You Require More Assistance.
Hope this Helps. Let me Know What Happens, Please. May the All Mighty Bless You and Yours. Be Safe and Be Happy. Thanks.
Good Luck
Respectfully
jbridger (John)
May 12, 2009 | Cub Cadet Street Sign- tractor lawn riding...
Garden Logo
Top Garden Experts
Dennis Key
Dennis Key
john h
