Question about Alienware PC Systems Alienware Aurora High Performance Gaming Desktop Computer
Black screen My screen will occasionally just go black even is there is not stress on the video card. The computer is running and what ever program I have on is still running, but my monitor gets no signal.
    Brigadier General:
  • Alienware PC... Master
  • 3,400 Answers
Check the cabels.
try with a other monitor if it works the monitor are brooken if not possibly fauity videocard.
Posted on Jul 10, 2013
Black screen and no sound on my Hauppauge Colossus PCI Express Win 7 capture card. I have confermed that the signa is getting to the card, by plugging each the HDMI, S-Video and composite video cables into...
Restart your computer and then press and hold F8 keys until you get Advanced Options menu screen.Use the arrow key to highlight Safe Mode, and then press Enter, your computer will boot automatically to safe mode.
If you able to start in the safe mode then Scan your computer for viruses. Some viruses can cause a black Screen , especially ones that infect the master boot record (MBR) or boot sector.
Update drivers for your hardware. black Screens are hardware or driver related so updated drivers could fix the cause of the STOP error.
Return BIOS settings to their default levels. An overclocked or misconfigured BIOS can cause all sorts of random issues, including black screen.
If it didn't helps you then simply get the system utility program like PC Fresher that will fix windows errors that cause of black screen screen
Aug 27, 2013 | Hauppauge Colossus PCI Express HD Video...
Hi I'm using a VisionTek Radeon 9250 128 MB PCI video card and every time I try to run any PC game I have, my monitor will freeze and then the screen will go black. Sometimes, this will result in my...
Hi caeggleston,
"every time I try to run any PC game I have" Running the games before, do you encounter the same problem you posted. If not there's a problem, have you read the system requirements of the game your playing before installing, unless its a mini game like book of worm etc. but most game now a days requires a decent video card considering you're using a AGP video card. try to run 3D Mark 2003, 3D Mark 2006 or FurMark (for stability) if there's no problem with the card it should stand the stress test or just a simple test. If you see garbled image during testing, your video card have problems consider replacing them.
Hopefully this information helps.
Thank you for using FixYa.
Sep 17, 2011 | VisionTek RADEON 9250 128MB PCI Graphic...
It went black but the power is still on
Computer Crash
One of the more complicated reasons why laptop screen goes black is a crash. This could occur for a variety of reasons and is often very difficult to fix. You will have to take the machine to a computer repair shop, and they will open up the laptop there to find the cause. Needless to say, this could set you back by a few hundred dollars as well. The crash could be caused by overheating, or maybe even a loose power supply cable. One solution for you is to play an audio file if the laptop screen goes black. If it does not play at all then something is wrong with the entire system, but if the audio file plays then it is just the laptop screen that is troubled.
Virus
There are a few computer viruses that can cause this problem, but most antivirus programs can effectively deal with such a virus. Update your antivirus software regularly and make sure you download all possible firmwares, and this sort of virus will be successfully thwarted. If your machine is infected with such a virus then your video drivers will most certainly be affected, and even your video card could get contaminated. All this results in your computer screen going black, and in some instances, your laptop screen may even go blue.
Drivers and Programs
The video drivers are crucial for making the computer monitor function properly. On some occasions though, these programs can stop functioning due to some reason. If your laptop screen goes black after startup on a consistent basis, then maybe it is your video drivers that are malfunctioning. To avoid this situation, you should constantly upgrade your video drivers, and should also refrain from using pirated video drivers. Spend those extra bucks on getting licensed drivers, and you will save a lot of unnecessary expenditure in the future. Read more on how to upgrade laptop video card.
Jan 06, 2011 | HP Pavilion F1503 15" LCD Flat Panel...
When I am working on my computer, all of a sudden, I notice a patch of vertical colored block on my right side of the screen from top right till bottom right. The rest of the screen is fine, but anything...
Try degaussing the monitor first using one of the buttons on it, then Stress Test your video card with this program "VideoCardStabilityTestSetup.exe" at this site
http://freestone-group.com/video-card-stability-test.htm
It appears from what you said your video card is dying.
Mar 02, 2010 | NEC 1560M-BK 15" Flat Panel LCD Monitor
HELP!! my computer screen keeps going black when i play games :(
There is probably something wrong with the card. You updated the drivers
after the problem ,,right.
You have 3GB ram so that is ok. Your cpu and video card are just fine,
so the most possible would be the card is failing.
http://www.ozone3d.net/benchmarks/fur/
I have posted a stability test and a benchmark/ stress test for you to check the card, download the one for your OS, xp, vista.
If the card is going, it will act up when you test the card.
Feb 08, 2010 | Microsoft Video Game Consoles & Games
My Toshiba P25-S670 Video Card
I'm not positive, but I believe your video adapter card "IS" part of the motherboard. This is not something you want to undertake unless you are familiar with the proceedure. Sorry I couldn't be of more assistance.
Jul 26, 2009 | Toshiba P25-S670 Notebook
Acer 22 in monitor
From what you say, I'll assume you see stuff on the monitor like the BIOS info,and the Windows splash screen. Then it goes black.
This happens when Windows loads the video drivers for your video card. Up until that point, you are using generic VGA drivers. I would guess the drivers are corrupt and the video card just stops working when it tries to access them.
You'll need new drivers for your card (you'll need to determine that--you can ask me directly by clicking on my name if you need help there). Then you'll need to start your computer in safe mode and remove the video card from the device manager. Depending on the directions you have for your video card, you may have to tell the computer not to install drivers when you restart your computer, but run the install program first.
Feb 27, 2009 | Acer Computers & Internet
Monitor goes black suddenly
nvdia 6600 requires a minimum of 450 Watts of power to ensure that everything works properly. So if you want to continue using your nvdia card, an upgrade will be necessary.
If you want to test to see if it is the nvidia card, you need to remove the card physically from the system, then boot with the onboard video. This action will eliminate any conflicts between the two video cards. Before doing this you may need to go into device manager and make sure the onboard video card is not disabled.
Jul 26, 2008 | Gateway 838GM (RB838GM) PC Desktop
Black screen
80% or more of the issues with your DVR can be resolved by unplugging the box for 90 seconds and plugging it back in. There are some features that will be avilable immediately, and others that will take time to download. IE: all of the quide. I can't stress this enough - reboot your DVR occasionally - just like your computer its hard drive might need this.
I have also seen the hard drive inside this box appear bad when it was actually a problem with one recording. In my case it was a recording on the wrong channel, one that did not broadcast anything in my market. I was unable to access any of my recorded programs and when I tried to play the one in question, the screen went black. I deleted the program and all was well.
Jan 02, 2008 | Arris DCT6200 DTV Receiver
Alienware PC Systems Alienware Aurora High Performance Gaming Desktop Computer  Logo
56 people viewed this question
Top Alienware PC Systems Computers & Internet Experts
Martin Murray
Larry Chandler
Jerry
Jerry
Are you an Alienware PC Systems Computer and Internet Expert? Answer questions, earn points and help others
