Question about Refrigerators
Fridge cuts off and never starts again,what could be faulty
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • 48 Answers
The defrost timer. Getting stuck in defrost. If its mechanical they are usually located bottom rear back of fridge or sometimes behind covers in the fridge roof. You can turn the little dial a bit and see if it turns back on. Could also be defrost termination sensor but unlikely.
Posted on Jul 10, 2013
My Samsung side by side RS2534WW is flashing 6 on freezer side and it feels like food is starting to thaw...what can I do?
needs to be minus-17 ..... 6 degrees should be fridge' temperature,
compressor may be hot and cut-out, pull away from wall at least 30cm and let some air to circulate behind to cool Compressor Motor
(possible Faulty Capacitor or Thermostat, )
it may also 'Reset' if turn fridge off for 10 minuites and back on again...have a listen and see if you can hear the Motor going?
if not.....I think your in Trouble!!!!
Aug 19, 2016 | Samsung Refrigerators
Kelvnator fridge motor clicks on and off repeatedly but not cooling it comes on roughly every 3 mins for about 4 seconds then clicks back off again. This fridge is over 20 years old and I'm not sure...
20 Years is a long time and we need to suspect quite a number of components. It is possible that the compressor is quiting as it overloads and then restarts when as the temperature is not maintained. Please check the capacitor to the motor, check the relay . Also if the pressure switch is faulty it can cut off. So a full check up starting with the compressor , the gas pressure and the electrical switching relay must be confirmed.
Sep 29, 2011 | Kelvinator KBM5100MB
I have a Matsui MUL1107WW fridge and the motor appears to be cutting out when the fridge gets too cold. Is this normal ? or does the motor need looking at ?
The compressor motor only needs to run to cool the fridge down.
Once the fridge is cold enough the compressor motor will switch off.
The compressor will start again when the fridge warms up
May 02, 2011 | Refrigerators
It runs all the time
Switch the fridge off for some time till the frost clears off. make sure the compressor has cooled off before you start the fridge once again.Switch on and checck if there is any ICE formation in about 1-2 hours. If so your compressor, gas and performance is good.
Now we need to check to see if the thermostat is cutting off. Having kept the thermostat in normal mode , the compressor must cut off in less than 3-4 hours. If not the thermostat is faulty. Also if you look on if the fridge does not shut offf in baout 8-9 hours of running then your thermostat, timer can be suspects.
However if there is no cooling reached in the first place then it is possible that the compressor or the gas pressure is down.
Check for leak if the fridge is old before you waste money on filling and losing .
Sep 01, 2010 | Refrigerators
ITS NOT KEEPING FOOD COOL......LEAKING WATER FROM LEFT AND RIGHT SIDE. ICE CREAM MELTING
The model is not mentioned but I think that the fridge is defrosting from the evaporator to leak the water out.
Set your thermostat to normal and see if the fridge is cutting off when the ice forms.
If not switch off fride fully for about 6 hours and start again . If cooling is good then check for auto defrost timer, the thermostat or poor lining of the gasket .. faulty gaskets.
If food is not cooling then check on gas pressure, pumping of comrpessor., if poor reading change gas or overhaul compressor.
Estimate and decide.
Aug 27, 2010 | Refrigerators
Where can i find the defrost cycle in my freezer? The coils were frozen up so I have defrost everything with a hair dryer. The fan is working but I want to check the defroster.
This timer is generally located in the under the fridge in the front or back. It's generally looks link a small square box about 3 inches square with a single round slotted dial. When you locate the timer using a flat head screwdriver simply turn the dial until you hear the compressor turn off a click. If the fridge is not running you can open the door long enough to warm it up and get the compressor started then turn the switch to make sure you have the defrost timer in the defrost mode. I would also suggest that you check the fridge hourly and make sure that it has started running again after a few hours. If you have a faulty switch this could keep the fridge from starting again. If the switch is faulty and the fridge fails to start by itself then simply rotate the timer until the fridge starts.
Also if your fridge is opened a lot or you live in a high humidity area this too can cause excesive icing.
www.appliance411.com/faq/howdefrostworks.shtml This link will give you a better understanding of fridge operations.
Aug 04, 2010 | KitchenAid KTRP22EK Top Freezer...
FRIDGE COMPARTMENT FREEZING
i had the same problem the sensor starts at the back of the pcb and snakes its way dow the back of the fridge into the freezer conpartment i ordered a new sensor thinking it was a temp sensor but turned out to be a defrost sensor compleat and utter hassel to fit due to the expanding foam i had to eventualy cut the block off that conects to the pcb and then reconecting it once i got the cable through the foam first 2 days seamed to work fine while there was nothing in it as soon as i put food in it again the fridge started to freeze everything again then about a week later it still ices up at the back the fridge but doesnt seam to freeze the food so much now so still unsure about it all
btw it was the exact same model and before i changed the sensor the light and the super light used to flash on and off
Dec 02, 2008 | Hoover HCA390FFK Bottom Freezer...
Fridge freezer upright
Replaced the thermostat
Jun 22, 2008 | Freezers
Compressor problems
it varies with door oppenings stuff like that sounds like you may have a faulty cold control the cold control has two settings a cut on setting and a cut out setting you cut in setting may be bad id replace the cold control
Mar 15, 2008 | Refrigerators
Refrigerators Logo
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
