Question about Vehicle Parts & Accessories
How super cat rx 103 works - Vehicle Parts & Accessories
Exhaust glows red hot
Mazda rx 8 creates a lot of heat, to fix this you must change out the coolant every 20k miles, with the mazda brand coolant i think its called mazda f22 coolant, the engine stays hot due to the high RPM engine, you may want to check: ignition coils, cat, coolant, and do a compression test.
Apr 19, 2014 | 2004 Mazda RX-8
Yaesu ft-950
There are numerous possibilities. You really need to go through the steps in the manual very carefully. Some of the possible issues:
1. Cable wired incorrectly - tx/rx switched, etc
2. Communication rate set wrong on computer (or different from radio).
3. CAT not enabled on radio
4. Wrong version of CAT software.
Oct 03, 2013 | Radio Communications
"smart cycle extreme" electrical cord
Here you go. The cord is the last item on the list. Hope it works out!
https://store.mattel.com/ProductParts.aspx?cat=139&sec=8713&productid=N9628&tx=103
May 08, 2011 | Fisher Price Fisher-Price Fisher Smart...
Where is the fuse # For the Power Windows? 2001 F-150 Crew Cab 2x4 5.4 I had Driver side dual switch break and short out leaving both windows and back sliding dont work. I have Checked all fuses in Dash...
if you have super crew in battery junction box fuse #601 30a fuse and fuse #103 50a if not super crew then fuse #110 30a and fuse #103 50a there is also check in the central junction box there is a #14 15a fuse. your power for the windows and back wnidows comes from the acc delay relay in the central junction box if you look at relay and jump or test for power,the 30 and 87 terminal if it works check the battery saver relay next to it with the #14 fuse. hope i didn't confuse you i get that alot lol.
Jul 13, 2010 | Ford F-150 Cars & Trucks
Cannot send or receive a fax. I can hear a click when I hit tone and that?s it. It worked before but after I fixed error 6502 nothing.
(2) Service error codes
on.
- Logic board
#001 TX Document jam
#003 TX / RX Document is too long, or page time-over
#005 TX / RX Initial identification (T0 / T1) time-over
#009 RX Recording paper jam, or no recording paper
#012 TX No recording paper at the receiving machine
#017 TX Redial time-over, but no DT detected
#018 TX Auto dialing transmission error, or redial time-over
#022 TX Call failed (no dial registration)
#037 RX Memory overflow at reception of an image
#085 TX No color fax function supported in the receiving machine
#099 TX / RX Transmission terminated mid-way by pressing the Stop/Reset button
#995 TX / RX During TX (sending): Memory transmission reservation cancelled
During RX (receiving): Image data received in the memory cleared
Error code TX / RX Meaning
##100 TX Re-transmission of the procedure signal has been attempted the specified number of times, but failed.
##101 TX / RX Sender's modem speed does not match the receiving machine.
##102 TX Fallback is not available.
##103 RX EOL has not been detected for 5 seconds (or 15 seconds in CBT).
##104 TX RTN or PIN has been received.
##106 RX The procedure signal has been expected for 6 seconds, but not received.
##107 RX Fallback is not available at the sending machine.
##109 TX After DCS transmission, a signal other than DIS, DTC, FTT, CFR, or CRP has been received, and re-transmission of the
procedure signal has been attempted the specified number of times but failed.
##111 TX / RX Memory error
##114 RX RTN has been received.
##200 RX A carrier has not been detected for 5 seconds during image reception.
##201 TX / RX DCN has been received in a method other than the binary procedure.
##204 TX DTC has been received even when there is no sending data.
##220 TX / RX System error (main program hang-up)
##224 TX / RX An error has occurred in the procedure signal in G3 transmission.
##226 TX / RX The stack pointer has shifted from the RAM area.
##229 RX The recording area has been locked for 1 minute.
##232 TX The encoder control unit has malfunctioned.
##237 RX The decoder control unit has malfunctioned.
##238 RX The print control unit has malfunctioned.
##261 TX / RX A system error has occurred between the modem and the system control board.
1-7
Oct 13, 2009 | Canon PIXMA MP830 All-In-One InkJet...
on.
- Logic board
RX8 Melting Cat , Missfire
1 of 4 coils you have, dont keep doing this cos now you need a new cat as well as the coils to buy get the coils first tho'
Apr 07, 2009 | 2004 Mazda RX-8
87 mazda rx 7 n/a cutting out at 4000rpm
Sounds like plugged up pre cats, my NA had the same problem I got a Racing Beat header that eliminated the pre cats and it went away. I've also seen them on eBay for cheaper. Either way you can't lose the stock header is like a cast iron stove attached to the engine it's heavy and massive.
Dec 03, 2008 | 1987 Mazda RX-7
Vehicle Parts & Accessories Logo
67 people viewed this question
Top Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Are you a Vehicle Part and Accessory Expert? Answer questions, earn points and help others
