Question about Garden
50981-DC It is a tractor carburetor what is this hole for and will it work on a farm all super h tractor
  • 389 Answers
When you look up the number on that carburator, it says that it is for a Farmall Super H so I am assuming that carb should work.
That carb is what's referred to as an updraft carburator where the air comes in from the bottom and goes into the engine through the top. So the air filter hose will go to the bottom air intake and the top side bolts to the intake manifold.
Good luck
Posted on Jul 11, 2013
I hav a 1961 fordson super major with white wheels all round tin on the front could this be original
Could be the same colours but I doubt a tractor working on a farm would still have good paintwork. Check the registration document and chassis/engine numbers.
Aug 01, 2017 | Cars & Trucks
Brand new Craftsman model #247.37430.1 starts but wont stay running.(first time trying to start it)
May sound funny..does it do this every time or only once and how long does it run..you may want to see if it has a fuel shut of in the fuel line and make sure it is in the full open position..also check the the inline fuel filter was applied in the correct position arrow pointed in the flow direction,,in it may be starving for gas...also some engines have a low oil shut off on the side of the engine one wire connector..check your oil,,if ok..find the wire going to the low oil shutoff and TEMPERARLY disconnect it..if it is bad the mower will start and run..just remember to connect it again..it is an engine saver...if that doesn't work your farm is messed up Good luck..
Oct 07, 2015 | Craftsman Garden
Tractor hydrolics low
check on back under seat or around there
Jun 24, 2013 | Ertl International Harvester Farmall Super...
Lawn mower was working fine then just cut out. have changed fuses and plugs but still not working
most engines have a carburetor with a brass screw at the very bottom of the float bowl. If yours has this unscrew it and clean out the jets which are 4 holes. They clog up and cause the problem you have. I would use a wire to insert to each jet hole to clean
Use a quick shot of carburetor clean in each hole as well while cleaning
If you have the new plastic carburetor you will need to have it rebuilt
Jul 17, 2011 | Garden
Have a farmall super c when the guy repainted it he power washer the old grease and dirt out from the fly wheel now after i start it i cant get it into gear
worked on a farm-all not too long ago and soundslike he may have knocked something into the yokes or knocked something loose. pull the inspection plate off the front of the trans housing and see if it is jambed or loose up in there.
Sep 14, 2010 | Farmall Tractor A-i,av,super A ,super Av...
How to check oil level on a 1953framall super a
It holds 6 quarts of oil. You really need a shop manual for your Famall Super A.You can get one here: http://www.amazon.com/exec/obidos/ASIN/0872881016/tractordata-20 Here is some more information on your tractor. http://www.tractordata.com/farm-tractors/000/2/9/292-farmall-super-a.html
May 30, 2010 | Pool & Spa
I have a Ford 3500 backhoe year is mid 70's. I need to replace the transmission fluid. Any idea what tyoe of fluid?
Officially, it's listed as M2C53A trans & hydraulic oil. Hope you can track down an equivalent where you are
Apr 11, 2010 | RTO Ford Tractor 2000 3000 4000 5000 Water...
Checking fluids
look for a tank reservoir with a dipstick. Locate the pump or cylinder and follow the line back to the tank.
Dec 22, 2008 | Ertl International Harvester Farmall Super...
Garden Logo
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
