Question about Craftsman 10" Table Saw
Armature I need to replace the fan of the armature but I do not find where can I buy a new one. M#137.248830 and armature M# 0R1Y with 9teeth.
Why the High Speed Radiator Fan is too noisy?
Fan is shot. Try to spray lubricate the fan armature with the thickest oil you have to see if it makes any difference. Might buy you some time till you can replace it.
Oct 15, 2014 | 2004 Lincoln LS
Milwaukee 6153-20 grinder is running extremely hot.
Your grinder is either working too hard because of broken or seized bearings or the fan is broken or detached from the armature. Take the brushes out then remove the four screws holding the gear housing on the motor housing. Remove the armature and check the fan and both bearings. If the armature bearings and fan are OK check the bearings and gear teeth in the gear housing.
Jan 31, 2013 | Milwaukee tools Milwaukee Tool 6153-20
Bosch 4000 DIY 5-6 years old - My saw was working fine and then slowed up, I turned it off and the blade would not move freely, and I did smell a little burn. I took it to a Bosch service, and they told...
The reason they couldnt get the armature out is the field has probably melted around it a little. BUT not to worry. Remove the motor housing and with the assembly remove the brush caps. Turn the fan slightly and you will see 2 usually phillips screws that hold the field in the motor housing, remove them and then you can GENTLY tap the armature and field out of the housing, after you get it out a bit you will have to remove the wires from the field to the brush holders. After removing inspect the motor housing for damage from the heat. You will have to buy a new field and armature, and brushes. When replacing the armature make sure to replace the bearings. If you need any more assistance let me know and I will try and help.
May 23, 2011 | Bosch 4000 - 07 Electric Table Saws
Replace armature, I have it all apart except I can't see how to release armature from base.
The armature bearings fit very snugly in their holders. If you have the case split and the belt drive pully off, you just have to pry the armature out of the other bearing holder. If you are replacing the entire armature and the new one has a fan on it just pry it out. If the new armature doesn't have a fan on it be careful not to break the fan or any of the fins. It should pull out smoothly, if it doesn't come out with even pressure you still have something on the armature holding it in.
Mar 04, 2011 | Porter Cable Cable 363 4" x 24" 1500 SPFM...
I have a strider midi 4 plus mobility scooter and the ecectric motor (model no. 31300-LDB4-E20) has a chipped armature. Is it possible to replace just the armature or do I have to buy an new electric motor...
You should be able to find a local shop that specializes in rebuilding DC motors. The cost of a rebuilt motor is considerably less than a new one. The rebuild shop will turn the armature, replace the brushes, replace the armature bearings, clean up and replace the contacts, etc. The only downside is that the warranty will only be upwards of 90 days. In my experience a rebuilt motor may get you an additional 6 to 8 months before it needs to be replaced with a new one. You need to weigh the cost of each alternative and make a decision. If you have a free source of labor, the choice becomes easier.
Unfortunately, I cannot recommend any rebuild resources since I live in the U.S. Hope this helps.
Feb 03, 2011 | Electric Strider Midi 4 Wheel Mobility...
Armature winding started coming appart..replacement armature available?
I'm not familiar with this particular generator however I would suggest trying to find a local repairer to get the armature rewound, which may well work out cheaper than buying a new part anyway.
Try searching Google Maps http://maps.google.co.uk/maps?hl=en&tab=wl In the search box type in 'armature rewind' and your location
Jan 14, 2011 | Buffalo Tools 4,000 Watt 6.5 Hp Portable...
Need to oil Hunter Ceiling fan, Tyep G model 25539. Cannot find the place to insert oil. THANKS!!
There are only two places to lubricate a ceiling fan, the top and bottom of the armature that goes through the center of the motor. The blades in turn hook to this and rotate with it. The top of the armature, closest to the ceiling, is probably a little difficult to get at. The bottom of the armature is probably easier to get at. To do a complete job of lubricating both ends, the fan must be taken apart and cleaned of old lubricant which is then replaced with new. However, I have found that using a can of WD40 with the red extension nozzle is the best way to do it without taking the fan apart. Spray some WD40 at the lowest part of the armature supported by the motor housing. WD40 is better than oil because it penetrates better and it is less likely to cause a build up of dust and dirt that would cling to the oil.
Oct 13, 2010 | Hunter Dryers
Burning smell from motor when I plug cord in outlet. Also, blades do not turn.
if the smell is foul smelling the windings in the armature of the motor are shorted out against the metal housing of this armature. You need a new motor or replace the fan
Apr 08, 2010 | Lakewood High-Velocity Fan
I have a 2002 grand prix gt my gas gage goes from full to emty sometimes it goes 3/4 sometimes 1/4 do u no what the problem is
sounds like you need new fuel pump. fuel pump located in gas tank. before you go buy a new fuel pump first push up and down on trunk of car real hard to try to dislodge the little armature inside of tank. this little armature is what sends the signal to the gauge telling you the quantity. push up and down on truck to try to dislodge small signal armature then check your quantity. try this when you are having the problem and i am willing to bet the little armature is stuck. the only way to fix is to buy a new pump.
Dec 29, 2009 | 2002 Pontiac Grand Prix
Good armature maybe needs new brushes
You can replace the carbon brushes and most repair shops should have them. Also tho, the armature could be causing the problem, if you put in new brushs and it still arcs badly, then the armature is bad.
Apr 16, 2008 | Kirby G4 Bagged Upright Vacuum
Craftsman 10" Table Saw Logo
41 people viewed this question
Top Craftsman Saws Experts
Craig Butler
Craig Butler
Are you a Craftsman Saw Expert? Answer questions, earn points and help others
