What is the max memory a satellite A45-S150 will take
When I installed 2GB of ram in a Satellite A45-S150. I don't get no picture on the screen. Is it to much ram? 4allmemory ran a memory test said it will take 2GB. But no picture.
  • 369 Answers
Please try to connect it to other slot.
Posted on Jul 10, 2013
hughv
  • 196 Answers
SOURCE: Toshiba Satellite A45-S150 PC Notebook
The manufacturer of your hard drive will have a utility for this.
It's unusual to have to do this, so be sure it's what need to do.
Posted on Oct 11, 2007
TampaNative
  • 778 Answers
SOURCE: INSTALLATION OF DVD ROM DRIVE FOR TOSHIBA SATELLITE A45-S150
Underneath your satellite there should be either a spring loaded lock to unlock/release the drive, or there could be a panel to remove that will expose a single screw that holds your optical drive in place. Releasing the drive with whichever locking mechanism is securing it should allow you to remove and install the new drive (if it's a screw, don't forget to replace it after the new drive is installed).
I hope this helps, and Good Luck.
Posted on Feb 24, 2008
jepito
  • 216 Answers
SOURCE: upgrading ram in a toshiba satellite a45-s151
under a small pannel on the bottom or under the keyboard
Posted on Sep 03, 2009
budmrtn
  • 11361 Answers
SOURCE: how to install toshiba satellite A105 S4334 memory
http://www.irisvista.com/tech/laptops/Toshiba-Satellite-A105/remove-motherboard-1.htm
Posted on Nov 04, 2009
  • 5340 Answers
SOURCE: cant find ram chips in a Toshiba Satellite A45-S151
The memory is under the keyboard on this laptop. You should be able to pry up the keyboard with a small screwdriver between the keyboard bezel and the keyboard itself.
Be very careful not to break the wires connecting the keyboard to the internals of the computer.
I hope this helps.
Posted on Feb 22, 2010
I have a45-s150 and want to add memory. where does it go?
The following website explains how to add memory in detail.
http://www.insidemylaptop.com/adding-ram-memory-into-toshiba-satellite-a45/
I hope this helps!
Oct 22, 2010 | Toshiba Satellite A45-S150 Notebook
How do i add more ram
The Toshiba Satellite A45-S150 has 2 bank(s) which have 1 socket(s) in each bank for a total of 2 memory socket(s). This means the Satellite A45-S150 can support up to 2 individual RAM modules. Look on bottom of laptop and there will be place to take screw out and you will see the 2 modulars. Below is a visual representation of the memory bank(s) and socket(s) configuration for the Toshiba Satellite A45-S150.
Nov 28, 2009 | Toshiba Satellite A45-S150 Notebook
Changing the ram in my toshiba stellite a45 laptop
I don’t have a diagram for upgrading memory in this particular model, but it’s very easy. You can access both memory slots from the bottom of the laptop if you remove the memory cover. The cover is located in the middle, right beside the fans. All you have to do is remove 2 screws and remove the cover. I believe Satellite P15 memory is expandable to 2GB in both slots (Slot A + Slot B = 2GB) and you can use PC2100 DDR RAM, PC2700 memory should work too (it will run at PC2100 speed).
Check the laptop specifications before you buy new RAM module. I just discovered that different Satellite P15 models use different memory types. For example, according to Toshiba specifications Satellite P15-S409 uses PC2100 DDR memory, but Toshiba Satellite P15-S479 uses PC2700 DDR memory (I think it might be a typo, but not really sure).
Jul 31, 2009 | Toshiba A45-S121 Notebook
Replacing the cooling fan
You can find a guide with pictures there:
http://www.irisvista.com/tech/laptops/ToshibaA45/Satellite-A45-remove-hinges-1.htm
The guide is for display hinge, but you can follow until step 20 and the rest should be easier!
Aug 25, 2008 | Toshiba Satellite A45-S150 Notebook
I need recovery disc
I do have a satellite a45- s150 laptop I can make a set of copies for recovery cd's if u need 'em
May 29, 2008 | Toshiba Satellite A45-S150 Notebook
My laptop
Dear jennyjoy Please find below the following guide for the A45 laptop. It contains many photos and instructions to take out the whole laptop to pieces http://www.irisvista.com/tech/laptops/ToshibaA45/Satellite-A45-remove-hinges-1.htm Regards
Please don’t forget to rate this solution if it was helpful, it keeps us going!
Mar 17, 2008 | Toshiba Satellite A45-S150 Notebook
Screen problems
Your LCD backlight has burned out, It needs replaced.
Jan 06, 2008 | Toshiba Satellite A45-S150 Notebook
Computers & Internet Logo
35 people viewed this question
David Payne
David Payne
