Question about Garden
I need bolt torques and valve clearences for pressure washer?
Greetings: I have a generac 2700psi gas pressure washer. I'm in the process if assembling a new cylinder head. I need the head bolt torques, valve clearences, and head cover bolt torques. I called generac and litterally begged them for the specs and they said they don't have them to give out to consumers. I'm at the tail end of this assembly to get the pressure washer running, and i'm stuck at this juncture. Nobody seems to want to assist me. Many thanks to all.
  • Richard Moskowitz Jul 09, 2013
    I forgot to mention that it is in fact a Generac motor, and the model is 0061490, and the serial is 6287274.
emissionwiz
  • 76164 Answers
SOURCE: 2005 Tucson
camshaft sprocket bolt 58-72 ft. lbs. crankshaft pulley bolts 108-132 ft. lbs. crankshaft pulley center bolt 80-94 ft. lbs. cylinder head bolts cold engine 65-72 ft. lbs. warm engine 73-80 ft. lbs. cylinder head rear cover bolts 69-86 in. lbs. flywheel/Driveplate bolts 94-101 ft. lbs. intake/Exhaust manifold nuts/Bolts 11-14 ft. lbs. jet valves 13-16 ft. lbs. main bearing cap bolts 36-39 ft. lbs. oil pan bolts 51-69 in. lbs. oil pan nuts 43-60 in. lbs. oil pan drain plug 33 ft. lbs. oil pump cover bolts 72-84 in. lbs. oil pump relief valve plug 29-36 ft. lbs. oil pump sprocket nut 25-28 ft. lbs. Rear oil seal retainer bolts 84-108 in. lbs. rocker arm shaft bolts 14-15 ft. lbs. rod bearing cap nuts 23-25 ft. lbs. silent shaft sprocket nut 22-28 ft. lbs. spark plugs 15-21 ft. lbs. thermostat housing-to-Engine bolts 86-114 in. lbs. timing belt tensioner bolt 32-40 ft. lbs. valve cover bolts 43-61 in. lbs. water pump-to-Engine bolts alternator brace bolt 14-20 ft. lbs. all others 9-11 ft. lbs. water pump pulley bolts 72-84 in. lbs.
Posted on Sep 08, 2008
SOURCE: need to know cylinder head bolt torque specs
Head Bolt Torque For your 1994 Oldsmobile Cutlass Supreme (3.4L SFI DOHC): clearpixel.gif Foot pounds (Final torque) clearpixel.gif Note: Torque sequence --------- | 6 2 3 7 | | 5 1 4 8 | --------- Step 1: torque in sequence to 33 Ft/Lbs Step 2: turn an additional 90 degrees Recheck final torque in sequence *** CAUTION ***engine uses Torque To Yield head bolts (TTY) thatpermanently stretch during the initial installation.New head bolts must be used when cylinder head isreplaced or re-installed to obtain proper torque. clearpixel.gif clearpixel.gif clearpixel.gif Foot pounds (Final torque) clearpixel.gif Note: Torque sequence --------- | 8 4 1 5 | | 7 3 2 6 | front --------- of engine | 6 2 3 7 | | 5 1 4 8 | Step 1: torque to 40 Ft/Lbs --------- Step 2: turn an additional 90 degrees Recheck final torque in sequence *** CAUTION ***engine uses Torque To Yield head bolts (TTY) thatpermanently stretch during the initial installation.New head bolts must be used when cylinder head isreplaced or re-installed to obtain proper torque.
Posted on Feb 07, 2009
  • 25 Answers
SOURCE: 87 samurai bolt torque specs for engine
The haynes book is not recommended since there are numerous mistakes and they still will not update. One of the biggest is the firing order.
The factory service manual is the only way to go.
Head bolts - 46 - 50.5 lbs (there is an order sequence for the bolts)
Intake & exhuast manifolds- 13.5 - 20 lbs
Flywheel - 41.5 - 47 lbs
Clutch cover - 13.5 - 20 lbs
Posted on Mar 17, 2009
  • 109 Answers
SOURCE: on a generac pressure washer that works fine.
Oil level in pump and motor OK? Spark plug not fouled? Has it sat for a while - carb dirty? Running (loaded) throttle rpm not high enough?
Posted on Mar 27, 2009
  • 28 Answers
SOURCE: I need the owner's manual for Generac Power Washer
Here is the link for your machine.
http://www.generac-portables.com/document/index.cfm?doc=1439_0EN3W_LO.pdf
Posted on Apr 11, 2009
My 2700 psi Generac pressure washer will not start.
Just pull out plug w cable on and crank engine..shud see fire. If not then bad connect or magneto. I think u let engine set w ethanol gas n now carb is gummed. Always drain tank n float. U will need an outboard chemical at a boat shop to fix. Or carb needs overhaul
Jun 16, 2015 | Generac 2500 PSI Residential Pressure...
Oil
Contact company, they should be able to answer this. Rule of thumb 10-30 is a good all around oil.
Apr 13, 2014 | Generac Generator 5989 2,700 PSI 2.3 GPM...
Engine rpm serges sometimes and powernosle pressure drop some times
Gas engine surging and losing power sounds like dirty carb to me.
Pressure washers are often used and then sit for months before being used again. This often creates blockage in carb passages. If you have or install a fuel cutoff valve you can reduce this problem. When you are done pressure washing, turn off the fuel valve and continue spraying water until the carb empties ( the engine will sputter and go out) Next time you want to wash turn on the valve and you should be good to go.
Mar 09, 2014 | Annovi Reverberi Sjv3g27d Pressure Washer...
Pressure washer surges
This could be your unloader valve taking in account the engine isn't surging. Does the engine run smooth? Do you have at least 50 psi water pressure feeding the pump? Inlet screen clogged? ALL tips act same way or no change?
Sep 08, 2012 | Generac 2700 PSI 2.3 GPM Gas Pressure...
Pressure washer pump pressure kills gas motor
the pressure regulator valve is stuck take it apart and clean it
Jun 04, 2012 | Annovi Reverberi Sjv3g27d Pressure Washer...
GENERAC POWER WASHER PUMP
Check the pressure limiting bypass valve. Also make sure the replacement bolts are "rated". They must be a certain "grade" which defines their load rating. Make sure they are torqued to spec.
Sep 10, 2009 | Plumbing
Escort Mk2 1600 valve and torques settings what are they
cylinder bolt torque settings stage 1 15 ft pounds
stage 2 50 ft pounds
stage 3 85 ft pounds
valve clearences 0.15 - 0.20mm inlet
0.22 - 0.27mm exhaust
these are the figures i have been supplied with, you can also use
cylinder bolts stage 1 10 ft pounds
stage 3 + 90deg.
with my exp, i would use the first guide as the degree method has a tendancy to snap head bolts, especially on older vehicles.
May 12, 2009 | Ford Escort Cars & Trucks
Garden Logo
76 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
