Question about Mr. Coffee ECM10
Frothing tube hello. I use my mr coffee espresso machine daily. It has always worked great, without a problem. This morning, I was cleaning the machine and the plastic and metal parts of the frother, which I do periodically, When I went to brew my espresso it worked great! but when I tried to froth the milk, the tube became hot but no steam shot out of the tube. I added more water to make sure I had enough to froth, but it still hasn't worked! Please help, Sheryl
Sheryl,
It sounds like the tube is clogged.  Remove the silver tip on the bottom of the tube.  Hold it up to the light and see if you can see through it.  If you can not, take a tooth pick and clean the tip out.  This seems to have worked for mine.
Adam
Posted on Oct 24, 2007
  • Tracy Leca Nov 25, 2013
    does the tip unscrew? mine does not seem to
  • natalie
    natalie Dec 08, 2013
    fill a cup with 3parts water and 1 part vinegar,place under the tip and soak for a 1 or 2 hours.this will loosen caked on milk and make it easy to unscrew tip with the coffee scoop tool
SOURCE:
When brewing coffee about half the water comes out of the frothing nozzle instead of the coffee spout. The nozzle also leaks after the brewing cycle.
I would say that something has a hole in it, but if it doesn't it might have bad quality, and if it isn't that because the place where you bought it from sells good machines, then it still might have something that went wrong or something was misplaced. I'm not sure either, but that's what i think is the most likely reason. You could always try ask the place manager and ask him if there is anything wrong with your machine.
Hope it ind of helped!
May 30, 2015 | Jura Capresso Impressa E8 Espresso/Coffee...
Cafe barista not frothing
the frother gradually gets milk buildup and loses suction- an air blast through the milk tube and up the spout (can get an aerosol at hardware store) will help as well as the cleaning cycle. Also I used a q tip to the top of the spout several times but just had the q tip top come off and may have blocked it completely
May 05, 2014 | Sunbeam Mr. Coffee Cafe Barista Espresso...
ESAM6600 will not froth milk
Use a really small screwdriver to carefully clean the white tube both from the front and the little hole underneath
I had frothing problem as mentioned above and noticed this tube was blocked, its 4 years I have had the Gran Dama 6600.
Cleaned as mentioned and did some purge as I went along, now it works as new. Its a maintenance that should be done once a year. You learn as things happen. LOL
Mar 17, 2012 | DeLonghi EAM3500 Espresso Machine/Coffee...
The steam wand is bubbling the milk, not frothing
THere is a little black tube inside - make sure its pushed out enough - about 1/16 an inch from the bottom. And you may have to clean it out. Happens to us too and after I do the above it works
Feb 13, 2010 | Gaggia Titanium Espresso Machine
Poor frothing
You need to check (or replace) the air-intake nozzle which is located inside the coffee outlet. You will sure loose the good froth if that part is not clean or replaced. There should be proper amount of air input to produced the proper froth.
Rihel Calma Philippines
Aug 22, 2009 | Franke Saphira Espresso & Coffee Maker
If you need a Franke trained coffee machine engineer to repair, service or for training, i can be there within 24hours, Email me for any questions great prices! 50mile radius of CV21 3SH
Hi
I have just bought a Franke Flair coffee machine second hand. It looks like new and the seller said it was in good working order - however it does not have the grinder blocker and I think we need one. I wouldn't mind also getting the once over from an expert and then maybe some kind of ongoing contact should we have problems with it. What are your rates?
Jun 15, 2009 | Franke Saphira Espresso & Coffee Maker
General question about the Mr. Coffee Espresso ECM10
Greetings!
Put desired amount of water in resevoir (plus a little extra to be used to steam your milk for latte) and close up tightly.
Put espresso grind coffee in basket and tamp down with a tamper. If grounds are not packed, steam will seep through and will cause an erosion of sorts instead of just letting the steam hit the grounds.
Put the basket with handle group in recess rotating to the right as far as it will go.
Rotate the ON/OFF switch to the symbol for "Brew" until you get out the desired amount of espresso.
Then, take a caraf of milk and immerse it with the plastic black steam arm. Rotate switch to "STEAM" and froth milk. In the beginning, ensure that you have enough water for the espresso AND enough left to froth without having to shut off machine, refill with water, just to froth.
Be careful when you open the water resevoir cap after brewing because there is a vaccuum created and a burst of steam will shoot out the lid and may burn you.
The gasket above the grounds hopper eventually will deteriorate and more steam will escape than espresso is produced. There is no replacement parts for this machine since it was made in China according to a Mr. Coffee representative that I called this morning at 1-800-MR-COFFEE (800) 672-6333.
Good luck with your machine. Hope this helps! If you don't have a tamper for the grounds, I found one at Bed Bath and Beyond. It is stainless steel with 2 sizes. The smaller size works for this model.
Jan 17, 2009 | Coffee Makers & Espresso Machines
No froth
Make sure the small metal tube is clean as well as the holes in mounts into. The tube can be removed easily from the rubber ends and cleaned. I've had my unit for a year now and we use it ever day without this issue ever happening. I did have the constant beeping water leaking from the seat/valve problem which I fixed by opening up the unit and tightening the screws.
Jan 03, 2009 | Krups XP2070 10 cup Coffee Maker/15 bar...
Open Questions:
Mr. Coffee ECM10 Logo
647 people viewed this question
Top Mr. Coffee Coffee Makers & Espresso Machines Experts
Pierre Laplante
msschnip
Level 1 Expert
Are you a Mr. Coffee Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
