Question about Baby Gear
Removing the hood clamp on a bugaboo bee
The hood clamps have been put on the wrong way round on my 2009 model (second hand) and i cant work out how to get them off to fix this any help greatly appreciated tia
  • 419 Answers
SOURCE: I just bought second hand bugaboo cameleon and it
I am afraid that this sounds like someone has put this into a hot tumble dryer, and cannot be rectified. I suggest that you purchase another hood or tailored fabric set.
Hope that helps.
Posted on Apr 11, 2010
macnutz
  • 541 Answers
SOURCE: do the 2009 bugaboo bee maxi cosi car seat
I haven't worked on a 2010 (yet) But I'm 99.9% certain you'll have no problem Bugaboo are good at keeping mounts standardized unlike some makes where each year it's virtually a different stroller. With chain store brands they usually are.
Posted on Nov 25, 2010
macnutz
  • 541 Answers
SOURCE: on my bugaboo bee 2009
There has been a lot of complaints about the Bee's wheels on the internet including Bugaboo's own Face Book page! Your Bugaboo is ether in or only just out of the 2 year Warranty so contact Bugaboo customer service about getting a replacement set. The rear wheels are held by Hex nuts and are easy to remove with a small hex key any hardware shop can sell you. I use Silicon grease (as used to lubricate taps) when I repair stroller wheels. I think the Bee is a neat little Stroller and my wife has one but it really is only a Shopping Mall Stroller and those little wheels won't tolerate to much rough suburban footpaths.
Posted on May 26, 2011
macnutz
  • 541 Answers
SOURCE: I have a bugaboo cameleon and try as I might, I
The Bugaboo canopy uses a clever two stage hub. A spring keeps the sections together in a twin set of wavy indents. As you pull the canopy out the first arch moves to the next indentation (60 degrees) than the second arch moves it's next indentation (90 degrees). If you have the fabric set to far back over the back of the frame and a arch can't reach it's next indentation it will jump back to it's first position. Check the arches can reach the indentations. If a spring breaks inside a hub it is not repairable but is available as a part for around 25 Euro for a pair.www.babycare.nl/bugaboo-canopy-clamp-cameleon-2pc-p-2467.html Ships Worldwide or Check out www.bugaboo.com
Posted on Jun 19, 2011
macnutz
  • 541 Answers
SOURCE: bugaboo bee handle clamp is floppy
Your hub lock has failed. I use to have a good tip section on this site but they mixed up or lost all my photos. I now have a face book page called bugaboo repair guy check it out.www.facebook.com/BugabooRepairGuy
Posted on Feb 17, 2012
Bugaboo bee clamps
Hi, All you need to do is to contact www.bugaboo.com and they will be able to sell the part to you directly. Hope that helps.
Feb 17, 2013 | Bugaboo Bee Stroller
Bugaboo bee handle clamp is floppy
Jan 02, 2012 | Bugaboo 192 Cuddy Cabin ORDER TOD Baby...
Bugaboo Bee 2009 back wheel won't come off
Not sure if your problem is removing the Hex bolts or pressing the axel out. Either way what you have tried is all you can do at home. Pop down to your local engineering work shop. They can press is out in no time. Max they'll charge is half an hour around $40 they may do it for free if in a good mood.
Nov 05, 2011 | Bugaboo Bee Umbrella Stroller
I have a bugaboo cameleon and try as I might, I can't get the hood canopy to stay taught at the back, it's loose / baggy. I've tried different hood fabrics as well as reversing the clamps but...
Jun 19, 2011 | Bugaboo Baby Gear
On my bugaboo bee 2009 model the rear wheel makes a grinding noise gets worse if on a pavement that is slightly bummpy can anyone help please?
May 26, 2011 | Bugaboo Bee Stroller
The hood has never stayed up tight always looks slack.
This sounds like you have the hood clamps on the wrong way round. Take them off and swap them over, this should sort it out.
Hope that helps.
Jan 17, 2011 | Bugaboo 'Cameleon' Stroller
Do the 2009 bugaboo bee maxi cosi car seat adaptors fit the bugaboo bee 2010? Thanks
Nov 25, 2010 | Bugaboo 2010 Bee Stroller
Bugaboo Cameleon - 2 problems (Canvas Hood/Canopy and Shaky/Loose Handlebar
hi there
hope this makes sense....
the handlebars on all bugaboo cameleons are 'loose'... it is a safety feature, designed that if one or more wheels are off the ground the stroller will not fold.
You will notice when you take the seat frame off the chassis to fold it, it will only allow you to do so if you release the locks somewhere in between the tow positions of 'give' (if that makes sense)
it is basically so that IF someone does not have the seatframe on properly, thus not locking it into the starlock, and they accidentaly press the lock/unlock switch when goin off a kerb etc, that the chassis will not fold. its not a fault, just a design feature.
As regards the hood, this is difficult to explain online, but basically it sounds like the two clamps that attach your hood to the seat frame have the 'teeth' in different positions than each other.
they have to be symetrically aligned. ie if the plastic skeleton part that goes through the hood is further back on one side than the other, the hood looks 'floppy'
i appreciate this probably makes no sense, like i said its hard to explain online. if you cant sort it yourself check the bugaboo website for your local stockist, and go in. they will be more than happy to fix the hood for you.
This is really why companies like bugaboo like customers to buy strollers from retail stores, instead of having a box delivered and assembling yourself, as they can take you through it all, assemble it, and give you a decent demo of how it works.
cheers
Jan 04, 2008 | Baby Gear
Baby Gear Logo
114 people viewed this question
Top Baby Gear Experts
Dorel UK
Dorel UK
Are you a Baby Gear Expert? Answer questions, earn points and help others
