Question about Konica Minolta Magicolor 4695MF All-In-One Laser Printer
Terrible copies down the sides !
I have removed all drums,transfer belt,cleaning blade assbly and cleaned. After a complete cycle without coping the transfer belt is clean. For the life of me I can not see where the toner (black) is dropping on the belt and tranfering to the paper. Never worked on this model before but did get the book. Copier is in a church. The preacher said he thought someone had just changed the toner. That is oem and installed correctley. Thanks Ken
    Filmmaker:
    Uploaded 5 video answers.
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
  • 45 Answers
Terrible copies down the sides ! - 759a6310-c94d-4cc9-8251-468d69129a1d.jpgIF IT LOOKS LIKE THIS, LONG STORY SHORT REPLACE BLACK IU
SEAMS TO BE TRIGGERED BY HIGH HUMIDITY
Posted on Aug 30, 2013
  • 214 Answers
SOURCE: Faded left hand copies
Pleas check that you inserted the K toner correctly, check, that transfer belt and/or drum cartridge is installed correctli. also check that 2transfer roller, its one big black roller.
Posted on Jan 24, 2008
SOURCE: Konica Minolta 2400W Error Message
remove the opc drum.
there are two black plastic flags that detect paper jams. one is high up just below the fuser unit. The other is roughly half way up the printer between two small transfer rollers very close to the opto sensor. Apparently it frequetly gets jammed behind the plastic cover, and once jammed you would never realise it is there.
I managed to prise it out from behind the cover and the "paper jam at transfer roller" message was cleared.
Unless you know it is there and hiding it is not obvious at all that anything is wrong.
Ian
Posted on May 27, 2008
  • 214 Answers
SOURCE: Black bullets down left side of paper
inspect the pc drum, if there is no dots, then its ok, also inspect fusing unit rollers and transfer belt for dots and clean laser glass.
Posted on Jul 02, 2008
firecontrol7
  • 6168 Answers
SOURCE: Minolta copier 1030, changed toner makes no copies
take the toner bottle out. turn off the machine then turn it on with the bottle out. once the machine, ask for toner install the bottle.
Posted on Jul 25, 2009
  • 1297 Answers
SOURCE: Toner is not fusing to paper right after changing drum.
Verify the fuser ubit components ,mechanical part,the pressure roller lever in close position and the transfer corona position.
Posted on Mar 05, 2013
There is a Black line on the Ricoh Aficio 3045 Drum Help for Remove ????
if you can clean the black line with a cloth, than you need just to replace the cleaning blade, but if the black line is not removing without a cloth, then you need to replace the opc drum and the cleaning blade or both blades, some machines of this type have only one cleaning blade but some have two cleaning blade.
Sep 28, 2016 | Ricoh Aficio Office Equipment & Supplies
How can i fix konica minolta bizhub c6500 error code c-2804
WHAT EVER YOU DO DO NOT PLACE ANY PRESSURE ON THE FOUR LARGE SHAFTS THE TURN THE DRUMS
Pull out the Drum and Transfer belt section. then from the right side gently clean the three sensors that site across from the belt. all three have metal covers BE CAREFUL they also have tiny springs don't lose them. Just lift them and clean the sensors with a dry rag. AGAIN do not touch those large shafts. if the cleaning them does not work remove the assy. two screws one connector. Don't lose the screws. Also clean out the Transfer belts cleaning blade unit remove hard toner remove the assy. and disassamble. Then run the gamma procedure in 36 mode.
Aug 19, 2015 | Konica Minolta Office Equipment & Supplies
Aficio 1018 dirty copies
Remoe the image unit,remove the OPC drum ,clean the opc drum cleaning blade(if necessarry change),remove the transfer unit clean the transfer belt cleaning blade,and clean the polygon glass.
Jan 31, 2013 | Ricoh Aficio 1018 Printer
Ricoh Aficio 450 back side is dirty?
Problem on charge roller,Upper drum unite,please clean or change it then solve your problem.
With the best luck.
Jan 20, 2010 | Ricoh Aficio 450 Copier
Ft 7950 light copy
Clean the transfer/separator corona unit,the optical unit components and if you have make more 1200000 copies change the developer and OPC drum,drum cleaning blade and the charge corona wire.
Dec 10, 2009 | Ricoh FT7950 Copier
My copier is Aficio MP4500 with background after replacing drum and developer.jj
swan this model doesnt have a transfer roller its a transfer belt and even if the trasfer belt is damage the problem it would cause is that the back of the paper would be dirty.
Jun 08, 2009 | Ricoh Aficio MP1600SPF Copier
Faint red line across page when making color copies or printing in color from computer
Some possibilities are:
1) Dirt on the glass, dirt on the glass strip for the doc feeder, or dust on the mirrors. This would be the case if the line only showed when copying and not printing.
2) Toner dropped onto the charge sawtooth.
This may be possible if the line is intermittent and only showed up for 1 or 2 colors.
Open the front door and remove the waste toner box. To the left of each drum there is a green organ-stop type stem. Pull and reinsert each stem. You will hear a zipping noise. These are your charge scrubbers.
This may be not as likely if the line shows up in the same place on all 4 colors
3) Toner or dust on the lens
In the area where the waste toner box goes, look for a grey stick with a white cushion on the end. This is your lens scrubber. Look in the area under the charge scrubber on each drum cartridge for a gap. Insert the scrubber cushion side down into the gap and run it forward and back to clean the lens.
4) Transfer belt blade not cleaning
This is best handled by a service tech since the mylar belt is very fragile. The squeegee blade that cleans the transfer belt between copies is missing a spot. The blade needs to be taken off the belt, cleaned and repowdered. Recently, Sharp made changes to the composition and thickness of the mylar in the transfer belts. Overpowdering the blade or belt when it was changed may cause improper cleaning of the belt creating lines across the copies. Often the condition clears up after a couple of days as the gap between the blade and belt is sealed.
This is most likely the cause as the line shows up in the same area for more than 1 color.
5) Transfer belt and/or blade is worn out
If the belt is worn the blade must be replaced but not vice versa.
6) Clogged waste augers in the drum cartridges.
Waste toner may cake up in the drum cartridge and knock loose on the drum.
It may be time for full maintenance on the machine.
Jun 02, 2009 | Sharp MX-2700N Color Copier
Gestetner 2722z copier, new drum, new transfer belt, smudges yet
The image is not transferring properly..........
remove and clean all corona wires (thin wires that create the latent image) use a q tip and dip in rubbing alcoholhot
Also make sure the fuser rollers are hot(insert or trick safety switches to determine if the fuser lamps are lighting usually upper and lower
Also check the imaging lamp to be sure it does not have any dark burn marks on it and clean the mirrors and the glass under the coy area
Dec 30, 2008 | Gestetner Office Equipment & Supplies
Developer....
When developer goes bad you use more toner for one thing, but the main sign is a gray background in your copy. The print should be black but appears to be gray. The ricoh 350/450 was always noted to leak toner and developer as it runs. Check your machine and see if you see any small piles of toner, which also has developer in it, in the machine. Ther are small seals made of felt that need to be replaced if you have this problem. These seals rub against the drum sides....Good luck.
Jul 20, 2008 | Ricoh Aficio 450 Copier
Mita dc 1860 copy machine
Check Drum from scratches,check cleaning blade.Also check Heat roller.
Nov 15, 2007 | Office Equipment & Supplies
Konica Minolta Magicolor 4695MF All-In-One Laser Printer Logo
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Adorjani Laszlo
Ben
Ben
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
