Compaq presario cq 56
Hey. I have disassembled my laptop to clean the fan and when i put it back up my wireless card wasnt working. After opening it up again and having fixed that, the monitor started flickering. I have opened the display (without opening the whole laptop again as in the laptop's book) and after seeing all cables seemed secure and not taking any of them out or moving them too much, it has now completely stopped working, stays black and it will not come on at all when i start the laptop. not too sure what this means or what I should do....
    New Friend:
Unplug the power and remove the battery. Next, hold the power button for about a minute. Than, reattach the power and attempt a boot.
Posted on Jul 10, 2013
Testimonial: "no, it's not that and it's not the ram either . I'll open it up again today and have a look at the connection, maybe i missed something or they got messed up when i closed it up"
SOURCE: Compaq Presario V6000 Laptop-Black Screen
i have the same problem, booted with lcd monitor... think it might be capacitor... pain in the but to doit yourself $300 at the shop. having this problem with two hp computers
Posted on May 28, 2008
Whisperwolf
  • 110 Answers
SOURCE: my laptop monitor flickers
Don't worry about embarrassment, there's a world of difference between software and hardware.
The flickering is most likely either a loose wire or more likely a partially snapped dry solder joint where the florescent panel behind the screen is connected. Since the laptop lid is opened and closed frequently, even the smallest of movements over several years can stress a dry solder joint to the point where it cracks.
Unfortunately it's not a user serviceable thing, but you may not need to return it to HP - a local specialist in flatscreens or more ideally monitors is likely to be able to mend it. Since it's so far out of warranty anyway it's not too much of a risk to use someone not HP approved since they can't invalidate a warranty that's long expired, so get your local phonebook out and start searching for someone who can give you a quote on a flatscreen backlight repair.
Posted on May 29, 2008
bunnydawg
  • 5158 Answers
SOURCE: Compaq Presario 1700 Laptop screen flickers and locks up
it sounds possibly that it is going into hibernation. a single press of the power button should bring it back alive.
also feel the bottom of the laptop.... if it is getting close to meltdown you need to clean the dust and dirt from the heatsinks. the fan area may appear to be clear but all the junk gets blown against copper heat sinks so you need to remove the covers to get at it.
Robert
Posted on Sep 05, 2008
SOURCE: Compaq Presario F500 Monitor Problem
http://h10025.www1.hp.com/ewfrf/wc/document?lc=en&cc=us&docname=c01480071&dlc=en
This might fix your problem. There is a problem sith the bios on select F500 models. Yours might fall in that category.
Posted on Sep 10, 2008
leecom72
  • 4806 Answers
SOURCE: compaq presario laptop screen flickering
Hi there.
It sounds like you may have a loose inverter cable or the ribbon cable behind the screen is loose.
Is the machine in warranty? I
Posted on May 29, 2009
Compaq presario CQ56-115DX with windows 7 turns off while working, won't come back on.
This is usually caused by excessive heat build up causing the motherboard to go into thermal protection. Make sure your fan openings are clear and blow out any dust that might have built up.. Also if you can hear the fan running (sounding like a plane taking off). Put your hand by the exhaust ports and see how much airflow is being pushed.. The fans can move allot of air when they spin fully up to speeds to allow max cooling. If you are getting hardly any airflow from it then you can either try to disassemble the laptop to clean out the blockage or take it to a qualified repair center or local computer shop to have it checked out..
May 03, 2014 | HP Compaq PRESARIO CQ56-115DX Laptop...
Compaq cq-56 wont turn on
Have you cleaned the Laptop thoroughly? Have you tried another Cord/Charger with the EXACT same power specs as the original? It may require opening the Laptop to examine/replace the Thermal Paste on the CPU and GPU? Have you done ANY updates recently? Graphics adapter? Have you tried a boot to safe mode, is it possible? Can you get to the BIOS setup? OR it may be a component on the Mobo, hard to say from here.
Apr 16, 2013 | Compaq Presario CQ56-115DX Laptop
Problems with compaq presario cq56
open f10 go to diagnostics 10008 bios code means the hard drive is fried new one for cq 60 160gb hard drive 90 dollars but might as well upgrade 500gb only 115 i would think the cq 56 should be about the same price
Apr 01, 2012 | HEWLETT-PACKARD Computers & Internet
Hi, My notebook is Hp presario cq series While i start the machine the cooling fan is not revolving and i hear some error message regarding the seriousness of the fan problem, A couple of days back...
Compaq notbook Presario 1626 is now officially retired at HP
https://support.hp.com/us-en/retired-products
beep codes, count them report them>>?
how to fix something but but dont touch it>? the is impossible
think that trough?>
most pcs pack in lent every year, its needs service
if not up do doing that your self, try a shop?
the fan must blow and keep the CPU cool or it overheats and fails
the CPU will shut its self down, if it overheats. ending all things..
until its cleaned fully.
google or you tube this. act.
hp forum is here.,
https://h30434.www3.hp.com/
Jul 17, 2017 | Compaq Presario 1626 Cooling Fan Case...
How many usb ports on compaq cq 56-101sa
It has 3 USB 2.0 ports. Hope this helps
Feb 11, 2011 | Compaq Presario Notebook
Laptop overheating and shutting down prematurely
Laptop heatup is mainly due the clogged heat sink and fan etc, which requires to be cleaned. Laptop shuts dwon automatically when reaches the temperature limit to prevent damage. It is strongly recommended that you clean the heat sink etc yourself or seek help from authorized professional at the earliest to avoid any damages to the PC.
If you are familiar with working inside such electronics, then you can do it yourself after studying the following useful links about CQ-50 Disassembly. On the contrary, if you dont have sufficient experience/ idea about opening/ repairing laptops, DONT try it and get assistance from a professional,
Dissassembly CQ-50
Maintenance & Service Guide CQ-50
Hope it helps! Do convey your feedback
CreativeTECH
Jan 27, 2011 | HP Compaq Presario CQ50-210US Notebook
Compaq presario laptop cq50 110em ///over heats and switches off ..however fan works fine .. dosnt make sense to me the laptop only gets hot in one particular part exactly where the fan is
If you touch the laptop while it is running & you find it too hot, make sure that the fan is running properly & that the air ways are not blocked.
You can blow compressed air into the cooling vents of the fan. If you notice clouds of dust coming out, then it might be a good idea to disassemble the laptop, clean the fan & air ways, & reassemble it back. If the fan has failed & is no longer running, it might need to be replaced.
If none of this solves the problem, or is not the case, then you might have a bad motherboard.
Sep 28, 2010 | HP Compaq Presario CQ50-110US Laptop
Fan has stopped working
Go to http://h20000.www2.hp.com/bizsupport/TechSupport/DocumentIndex.jsp?contentType=SupportManual&lang=en&cc=us&docIndexId=64179&taskId=135&prodTypeId=321957&prodSeriesId=3466274
Download the Service Manual. It will walk you through the disassembly process. You can easily install a replacement fan assembly yourself.
Good luck.
Feb 07, 2009 | Compaq Presario Notebook
Computers & Internet Logo
35 people viewed this question
David Payne
David Payne
