Question about Nortel Meridian M7208 Corded Phone
Extension change phone will not recognize an extension number
When transferring a call to an extension off campus which is actually a cell phone, the caller is not transferred when it's on "night mode"
Assuming this is a corporate/school phone system, they probably have restrictions on forwarding calls to a phone number not owned by the company/school. You might want to call your support organization to allow you to route calls to a outside number.
Nov 15, 2017 | The Computers & Internet
Why when I try to type name for extension, only numbers come up?
Probably the system only recognizes extensions by number rather than name.
Mar 14, 2016 | Panasonic KX-T7730 Corded Phone
Change internal directory on optipoint 500
The extension name and extension number are set in the system programming. Use manager 'e' and change them in the station view. If you are swapping people around and want them to keep their extension numbers and names, you should re-patch the cables feeding to the wall sockets rather than change the programming (if you can).
Oct 20, 2014 | Siemens optiPoint 500 Standard Corded...
Need to change extension numbers
Guessing you mean add or change extension numbers under the buttons, since you don't "add" or change extension numbers on the phone. From your set, press program dial 99 and the button you want to program. then , dial 1+ ext number and press STORE.
Do that for all the buttons you want to change then pick up the handset and drop it back down to exit programming.
Apr 10, 2013 | Panasonic KX-T7433B Corded Phone
Change a call forward phone number on extension, toshiba dkt3020sd
you have to obtain the voicemail users guide for administrators. This can be found at http://www.telecom.toshiba.com/ and if you have a problem a dealer may be located who can do this for you.
Feb 20, 2013 | Toshiba DKT3020SD Corded Phone
I have panasonic kx-t7730. How to set the intercom name and number?
Changing the name and extension number can be done through system admin programming from a phone extension allowed by the class of service assigned to that extension by the phone system installer. Typically the attendant phone is allowed this ability. From the programming phone press **1234(1234 is the default password) to access programming. Once in programming dial 003 for extension numbering then press . Enter the current extension number of the phone you want to change followed by the new extension number then press . Lift the handset to end programming. Access programming again by pressing **1234. Dial 004 for extension name programming then press . Enter the new extension number you programmed then enter the name for the extension. Press then lift handset to end programming.
It is possible that your phone has not been assigned an extension number, in that case system installer programming would need to be accessed to assign the port an extension number. The port number the phone is connected to would have to be determined. This could require tracking the wiring back to where it is connected into the phone system. If this is the case I advise calling a qualified service technician.
Dec 08, 2010 | Panasonic KX-T7730 Corded Phone
Change the extension name? For examlple change from 109 to 122
Is that a name or a number?
Extension numbering and name are in system programming and that's a function of whatever system you have, not the phone. Generally, it's in system program 003 and 004 for number and name respectively.
In number change, most Pana systems require you to change one extension to a number not being used. In a TA-x24, the numbers are still assigned in software to 124, so you would change 109 to something out of the universe like 133, then change 122 to 109 and 133 to 122 :-)
If you have voice mail you may have to manually assign it via the owner's mailbox 999 or from the maintenance console or hyperterm.
Carl
Oct 21, 2010 | Panasonic KX-T7730 Corded Phone
Moving extention number
you must change the number by programing the PBX or phisicaly change the jack in the PBX.Both solutions must be done by authorized personal.check who is serviceing your pbx and make a request.
Sep 15, 2009 | NorStar T7316E Corded Phone
Changing names assigned to extension numbers
I just worked it out.
Press Program
Then **
followed by your passcode (usually 1234)
Then 004
Then press next till you find Mark
Press Shift then the button under Clr
Then enter the name so for Claire start with 2 and swing the jog button round till you get a C, then press 5 and swing the jog button round till you get an l etc..
If you make a mistake press Transfer
Then when you've got your name correct press Auto Dial.
Aug 20, 2008 | Panasonic KX-T7433B Corded Phone
CHANGE OF PHONE NUMBER
You need to contact your system admin...
Dec 10, 2007 | Avaya 4610
Nortel Meridian M7208 Corded Phone Logo
20 people viewed this question
Top Nortel Lands Phones Experts
David Burbee
David Burbee
Oloyede Monsuru
Computer Repairing
Computer Repairing
Are you a Nortel Lands Phone Expert? Answer questions, earn points and help others
