Question about Kenmore 24 in. 17482 / 17484 / 17489 Built-in Dishwasher
Dishwasher 587 16259
Thermostat
Thermostat tripping
I just fixed my Maytag's bi-metal switch. I smacked it with the plastic end of a screwdriver. Problem solved. You may have venting issues in the dishwasher if it's continually overheating.
Jan 30, 2014 | Maytag Dishwasher
Dishwasher thermostat
Please check the link below for a diagram of a dishwasher, the thermostat is near to the heating element and the connection can be traced to it.http://www.espares.co.uk/advice/dishwashers/a/3/169/identifying-dishwasher-parts.html
Mar 11, 2012 | Bosch Dishwashers
Replacing a thermostat on a dishwasher
you are most likely referring to item 16 in this diagram. You can order the part and replace it. This is the limiting thermostat which protects the unit from overheating.
However the heater thermostat is item 41 in this diagram. this controls the heater temperature.
Oct 30, 2011 | Maytag MDB7100AWB Dishwasher
Dishes are not dry anymore after cycle?
Hello there:
If` you ahve already checked all of the filters and they are ok than your drying cycle has problems to check these check these: Heating element Drying fan Thermostat Heating element Your dishwasher has an electrical heating element that helps to dry the dishes. If the element is burned out, the dishes won't dry properly, and you need to replace the element. Drying fan Many high-priced dishwashers have a small fan that blows air or heated air into the dishwasher to speed up the drying process. If the fan is defective, you need to replace it. Thermostat Some dishwashers have a thermostat that monitors the drying temperature. If the thermostat is defective, the heating element may not cycle on or off properly. If that's the problem, you need to replace the thermostat. there:
Normally if you have just started to have this problem and you have checked all of the filters and are sure they are ok than
Jul 06, 2010 | Whirlpool Gold 24 in. Built-In Dishwasher...
The water does not heat up and the dishes do not dry
A dishwashermag-glass_10x10.gif that suddenly stops going through the cycles or never completely dry dishes probably has a faulty thermostat. The thermostat controls the heating elements for water and drying. If the thermostat is stuck, the dishwasher won't go to the next cycle because the minimum water temperature requirement is never met. Drying dishes also requires the temperature to get high enough to do the job.
  1. Step 1 Remove the front plate of the dishwasher and locate the thermostat. If the thermostat is not located in the front of the unit pull the dishwasher out and remove the back access panel.
  2. Step 2 Disconnect any wires or other parts that are in the way. Separate the wires with a flat blade screwdriver carefully to keep the wires from breaking.
  3. Step 3 Take out the screws attaching the thermostat to the firewall and remove it from the dishwasher. Verify the replacement part matches the original, including the wire connector.
  4. Step 4 Place the new thermostat into place and secure it with the screws. Connect the wires and replace any parts or cables. Attach the front or back plate and replace any molding.
  5. Step 5 Run a hot water cycle and verify the water is heating and the cycle is able to complete. Check the drying cycle and prepare the first load of dishes.
Nov 15, 2009 | Dishwashers
Dishwasher cycle runs: tablet is not dissovlved, dishes dirty
If the dry cycle has a problem, check these:
Heating element
Drying fan
Thermostat
Aug 29, 2009 | Frigidaire Dishwashers
Indesit DI620UK Dishwasher fault
Heating element
Drying fan
Thermostat
Jul 19, 2008 | Dishwashers
Wet dishes
Heating element
Drying fan
Thermostat
Jul 19, 2008 | KitchenAid 24 in. KUDP01IL - Multiple...
Kenmore 24 in. 17482 / 17484 / 17489 Built-in Dishwasher Logo
14 people viewed this question
Top Kenmore Dishwashers Experts
Ken Johnston
Ken Johnston
Level 1 Expert
Fred Sops
vince
Are you a Kenmore Dishwasher Expert? Answer questions, earn points and help others
