Panasonic PT56WX33G rear-projection television problem...Wavy vertical lines and basically two-colors blue-green and red. My uderstanding when checking this out awhile back, consensus seemed to be replace the low-ohm concergence resistors (6) and maybe the convergence lcs
    Champion:
  • 247 Answers
Check the convergence ics they are usually stk type ics they are fa
faulty
Posted on Jul 11, 2013
  • 1153 Answers
SOURCE: 61" Sony Projection Television
You replaced stk's, have you replaced return resistors in same area? And is set in Convergence Setting mode or is it has sound from picture?
Posted on Sep 10, 2007
  • 317 Answers
SOURCE: jvc av56wp74 blue shadow
my suggestion would be...to replace the focus block..john
Posted on Sep 11, 2007
ctf1800
  • 4402 Answers
SOURCE: jvc av56wp74 rear projection tv
http://home.earthlink.net/~oleg.filippov/ConvergenceFix.htm
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
Posted on Jan 18, 2008
SOURCE: I have a 6 year old 53" panasonic rear projection tv
what color is out of alignment?
Posted on Aug 05, 2009
  • 30 Answers
SOURCE: 50H82 red wavy convergence (stks didn't fix)
If the tin can module you are referring to is the hyper module, it is common to replace all 11 caps because the factory caps ****. Check for bridged solder connections at STK's search the forum at electromaniacs for 50h81 :)
Posted on Mar 02, 2010
I have a 46" magnavox projection screen tv that has the red, blue, green colors on the left side of the screen when first turned on. After a few minutes of being on, the screen resumes to normal colors. ...
Projection TV sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the video to look normal. When its out of alignment the video will look 3D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the TV menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
This is a very common failure on these projection sets and a fairly simple DIY fix. All projection sets including Samsung, RCA, Sony, Philip Magnavox, Panasonic, Pioneer, Akai, GE, JVC, Toshiba, and others at some point will have the same problem.
You can get a repair kit with parts and instructions from www.TvRepairKits.com
Sep 23, 2010 | Philips 60PP9352 60" Rear Projection...
Blue, red and green are separated and i cannot find convergence from main menu
Sep 22, 2010 | RCA P52939 52" Rear Projection Television
MODEL # PT-52LCX15. GREEN AND BLUE SPOT ON SCREEN.
Hi , it seems you are experimenting a light engine problem.Here's how your tv works: http://www.youtube.com/watch?v=ZLLHnQ4y-wo Basically there's 3 LCD chips that create the colors and image by blending together.When these chips start to melt you will get those blue spots, pixilation even vertical lines.You will need to replace the light engine.You can find it here: http://www.discount-merchant.com/PANASONIC-521A2C52-p/1177904.htm Have a blessed one!
Mar 22, 2010 | Panasonic PT-50LC13 50" Rear Projection...
My Panasonic rear projection TV color is off
hello it sound like convergance ic might be the trouble it's a big job to do yourself a lot of testing and a lot of desoldering and soldering get a quote from an engineer
regards
shaun
Jan 19, 2010 | Panasonic PT-47WX49 47" Rear Projection...
Red, Green convergence lines are wavy
Projection TV sets have two very common problems listed below.
Problem #1) Convergence
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. This is called convergence.
When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired. Convergence problems are very common on all Projection TV sets including Sony, Samsung,JVC,Philip Magnavox,Panasonic,Akai,Pioneer, Hitachi,Mitsubishi,Zenith and others.
You can get more information and a DIY convergenece repair kit with instructions from the link below.
Here are some of the most common problems with these sets...
*Screen Looks 3-D
*Colors wont align
*Screen may look distorted or warped
*No Audio/Video - TV Shuts down - May also make a constant chirping sound
Problem #2 - Another common problem is dull or washed out video.
Your set may have one or more of the following symptoms....
*Dull looking picture
*White looking picture
*Halos around objects
*Red/Orange looking picture
bb0cf99.pngYou can see some more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Sep 16, 2009 | Akai PT4298HD Rear Projection Television
No picture but has blue green and red light down middle and sound
Most likely a blown Vertical deflection output IC. In most (but not all) Panasonic, the vertical IC is an AN55XX.
Repairs should be fairly easy with basic knowledge of electronic circuitry and components and a little soldering. I would expect the IC to be readily available at any electronics part store. Should you be uncomfortable doing a DIY, perhaps your best bet would be to seek the services of a qualified professional.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
Apr 28, 2008 | Panasonic PT-51HX43 51" Rear Projection...
Pioneer sd-643hd5 rear projection 64" tv has green geometry grid problems
Sony Convergence
http://www.techlore.com/blog/entry/19694/Sony-Convergence-Repair-My-Sony-TV-has-a-distorted-picture-/
http://www.techlore.com/article/19631/Sony-Convergence-Procedure/
Jan 25, 2008 | Pioneer SD-643HD5 64" Rear Projection...
Picture shows only about a 2-3" blue,green,or red vertical line down the middle
If your seeing vertical line across the screen you need to check the components in the vertical stage as well as the vertical IC could be bad, or the yoke could open.
Also check if any voltage reaching the vertical stage.
Good luck.
Was this help full.
Oct 31, 2007 | Panasonic PT-47WX53 47" Rear Projection...
Green horizontal deflection
Change both STK convergence IC's for reliability. They amplify/control both horiz and vertical. re-align after replacement.Locate them on the largest heat sink in your set!
Sep 26, 2007 | Panasonic PT-53WX42 53" Rear Projection...
Televison & Video Logo
Top Televison & Video Experts
Electro Med Services...
