Airlux error codes E7
Does anyone know what error E7 means ?
    New Friend:
I emptied the water from back and under unit, this fixed it for me
Posted on Aug 14, 2016
    New Friend:
This is probably a "mode conflict" where one of your units is trying to heat while one is trying to cool. You should switch one of those to fan instead or have them both on heat or both on cool.
Posted on Nov 05, 2015
How do I fix a hot point fridge freezer FFUXL 4DK displaying error code 7?
Hotpoint Refrigerator Error Code E7 = Environmental temperature sensor fault
There may be a number of things affecting the temperature in your refrigerator if you see this error code displayed
Jul 22, 2016 | Refrigerators
What's your question? My Sharp photocopier AR-161 display E7. and can't make copies what is the problem?
Here is a list of error code meanings for your device. You need to find out the sub code should be E7-?? To find the root cause. Sharp AR 161 Error Codes Trouble Codes
E7 03 LSU trouble
E7 04 CCD white level trouble
E7 05 CCD black level trouble
Sep 25, 2015 | Sharp Office Equipment & Supplies
I am getting an E7 error code on two new AM 04 heater fans what does it mean
E7 error was an engineering code from an old batch of fans and that they had since fixed the problem.sell the old batch
Nov 09, 2014 | Dyson Hot Heater Fan AM04 - Blue
What is the Singer sewing machine error code E7?
Hello, you didn't say what the model was? But here is a website to see what e7 means and download manual. Error Code E7 Singer 7258 Stylist Support
May 28, 2014 | Singer Sewing Co Machine Model 6199...
Code error E7
I'm not sure if NewAir is made by Gree -- they supply many. On Gree units, E7 simply means one unit is requesting heating while another is requesting cooling and you can't have both at the same time. So that's the first thing to check. Very simple, very common, doesn't indicate that anything is wrong with the system.
Apr 05, 2014 | NewAir ACS-1200H Split System Air...
Error Code E7 on Singer 6180
E7 means the machine has 'had enough' and that error flashes to let you know it needs a break. I found that out by trial and error and after phoning Singer as well.
Nov 04, 2012 | Singer 7258 Sewing Machine
Have error code e7-80 on a Sharp ARC260M copierwhich is 'ICU - SCN Communication Trouble'. Any one know what it means or how to fix it???
Usually E7 errors have to do with the scanner or the optics. You should get a hold of a technician to see what can be done to fix it.
Aug 05, 2008 | Sharp AR-275 Copier
E7 problem
E7 codes deal with the optical scanner unit and or the laser unit. It could also be the lamp in the scanner unit. The E7 is the main code. There is a sub code associated with it. To view the sub code hold down the start button. Below is a list of specific codes and their meanings:
E7-02: LSU trouble
E7-10: Shading trouble (Black Correction)
E7-11: Shading trouble (White Correction)
E7-12: Shading Trouble
E7-16: Abnormal laser output
If it is a laser (LSU) issue then the LSU may need replacing.
If it is a shading error the first step is to remove the platen glass carefully (with the power off because the inverter board). There is a thin white strip on the bottom side of the platen next to the slit glass. Clean this white strip with a soft cloth and a small amout of isopropyl alcohol.
Dust on the optics can also cause shading reference errors so gently blow off the mirrors with canned air.
Perform the following key procedure to reset error:
"#" key, Interrupt key, "C" key, Interrupt key
"1" key, "4"key
Start key, "CA" key.
See if unit cycles and comes back up. If not turn off and then back on the main power.
If error reappears on site technical service may be required.
Jan 06, 2008 | Sharp AR-5316 Advanced Digital Imager...
Heating & Cooling Logo
291 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
