Question about Garden
How to adjust a carb on a poulan pro pole saw 446t
Replaced carb now it starts and dies.also replaced fuel lines/new primer
  • Gary Weber
    Gary Weber Jul 09, 2013
    cant adjust h/l cause it will not run long enough to do so
5 Suggested Answers
  • 17 Answers
SOURCE: Husqvarna 350 running problem
Pull off the exhaust, does the piston look ok?
If scored thats not good.
If ok check fuel filter , pressure test lines or remove and check for cracks. Just a start but check easy stuff 1st or get back to me with more info, cheers
Posted on Dec 28, 2008
fphandyworks
  • 56 Answers
SOURCE: Poulan 1950
tighten the left screw and right screw all the way.
losen the left screw 1 full turn and the right screw 1.5 turn and that should be the factory setting good day.
Posted on Jan 03, 2009
dontbother10
  • 2220 Answers
SOURCE: I have a Poulan Pro pole saw model sm446e. For
Without seeing the saw and pole we cannot answer your question.
Posted on Sep 23, 2009
dontbother10
  • 2220 Answers
SOURCE: I have a poulan pro 210 chainsaw both fuel lines
This should help:
http://www.fixya.com/support/r3706813-2_cycle_fuel_system_repair
This too:
The IPL (exploded parts list) for your saw is the only detail for fuel line routing and it is sketchy at best; components are listed but may be on different illustrations.
Poulan.com
I think this is your saw please ensure I am correct.
http://www.ordertree.com/modelinfo/PWE/PP210-Gas-Saw/75.PP210-Gas-Saw.1.59.1.html
If not your saw it can be found here:
http://www.ordertree.com/modelinfo/POULAN-WEED-EATER/75.59.html
The dash number of your serial number is the type. HTH
Lou
Take some pics first then a small sample of the different fuel lines to your local chainsaw seller. A little extra is agood idea, I have not found a good fuel line stretcher and I have been looking. Probably a good idea to replace the fuel filter too.
Posted on Jan 16, 2010
Carburetor change
Primer bulbs pull fuel from the carb, into the bulb and dumps it back to the tank, if you have re connected the hoses to the primer the wrong way around it will try to force fuel into the carb and make it flood.
Jun 01, 2013 | Poulan Garden
I have a poulon pro 42cc saw that wont start. dont think its getting gas cuz i tried to flood it with the primer but no gas on the spark plug.
The primer will not flood it, all the primer does on these saws is pushes fuel through the carb. If this is a new saw, it needs a carb adjustment, a very common problem on poulan products these days. It's covered by the warranty at any of their service dealers (you can locate one on poulan's website).
How old is the gas you are using? If the mixture is more than 30 days old, make a new mix and try again.
Check for spark. Pull the boot off of the plug. Hold the boot near something metal and pull the starter. If you see a spark, you are good. If you don't, you may have a problem with the coil.
Aug 26, 2011 | Poulan Pro 42CC 2 Cycle Chainsaw, 18"
Poulan 446t Will start, won't continue to
The diaphragm in the carb is likely ruined from the gas gelling onto it. This will put pinholes in it and then it won't work properly. Pick up a carb kit and rebuild it (if parts available) and then you should be good to go. If you can't rebuild the carb, a replacement will run you 30 bucks or more.
Aug 21, 2011 | Poulan Pro 42CC 2 Cycle Chainsaw, 18"
I have a 2250 Poulan. The fuel lines have been removed. Is this the correct routing for the fuel line? Starting at the filter in the tank,will the line go to the bottom of the carb.? Then the line goes out...
Is there a fix for bar oil running out of the saw all the time until the tank is empty?
there is bad oil line repalce it.
Is this the correct routing for the fuel line? Starting at the filter in the tank,will the line go to the bottom of the carb.? Then the line goes out at the top of the carb. to the primer\'s suction side? Then out of the primer to the fuel tank? This route the primer pulls gas through the carb. Does it make any difference which hole in the tank the lines go to?
YES that correct
Dec 29, 2010 | Poulan P3416 16Inch 34cc 2Cycle Gas...
I had to replace all my gas line on my Poulan 446t i need someone that knows how they hookup
Typical fuel system and a couple of tips. Leave the carburetor connections a little long so they can be swapped if need be. I think the upper most connection goes to the bleeder.
I think this is an IPL for your pole saw: (there are others, this may not be your saw):
http://www.ordertree.com/modelinfo/PWE/PP446T-Gas-Pole-Pruner/75.PP446T-Gas-Pole-Pruner.1.59.1.html
All Models:
Poulan.com
The dash number of your serial number is the type (true for chainsaw, my first pole saw. If uncertain try to contact them please.). HTH
Lou
Please reply back (below) with the final configuration. Help me provide better guidance to the next guy please.
Feb 09, 2010 | Poulan Pro 42CC 2 Cycle Chainsaw, 18"
I need info on a Poulan Pro 445 fuel line routing
I'm so confused. This is reported as a Poulan and McCulloch pole saw, which one? Is it a pole saw? That is the only 445 Poulan I can find. It is reported as an electric but has a fuel routing problem.
If it is a Poulan Pro gas pole saw it is here: PP445 Gas Pole Pruner
The fuel system routing is terrible, but it is all there is.
Fuel Routing follows:
Tank to carburetor (hose in tank with filter on free end)
Carburetor to primer (primer draws fuel from the tank through the carb)
Primer to fuel tank (returns any excess fuel to tank when pushed) HTH
Lou
Oct 11, 2009 | McCulloch 10" Electric Pole / Chain Saw
On a Poulan Pro pruner(446T), it wouldn't start so I put new fuel lines on and cleaned the carb. Then it wouldn't fire, so I replaced the coil pack but still nothing. It doesn't try to fire even after I...
I have an earlier model of Poulan Pro Pruner with a similar problem. It is a PP258 and looks identical to the 446T. My unit had about 3 hours of use max.This was the second year. It had some compression but I was not sure it was enough. It would not start and had good spark. I pulled the plug and put about an ounce of oil in the cyl and put the plug back in. Pumped the primer bulb and put carb to Start. On the first pull I could tell the compression was better. It started on the second pull and would only run wide open and smoking from the oil. Something was wrong in the cylinder. I dissasembled the engine and discovered a tiny piece of metal had gotten caught between the cyl wall and the piston. The cyl was scored and the ring land pinched the ring. Time to get some new parts. I also had to use my air cut off saw to get the clutch drum off because the screw wouldn't budge. About $60 will fix it. Overall it isn't a job fopr the average homeowner. What a pain.
Mar 27, 2009 | Poulan Garden
I may have lines on Backwards??
filtered line from tank goes into top inlet at carb. bottom inlet receives line that goes to carb side of primer {draw side} 3rd line goes from push side of bulb bach to fuel tank.
Mar 25, 2009 | Poulan Pro 16-Inch 38 cc Anti-Vibration...
Garden Logo
351 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
