Question about Toys
How to charge a YIBOO UJ1003 UH-60 - Toys
My yiboo elicopter not respond from radio control
need new radio to try to match it translate this letter or receiver on the helicopter
Nov 29, 2014 | YIBOO Toys
Yiboo uj422 helicopter won't charge
Sounds like your batteries have gone bad.
Nov 10, 2014 | Toys
My yiboo heliocopter uj4702 wants to fly backwards.
you have stuck up controller and receiver contact points, means you need to check both on the controller and the copter where the stuck up sensors are, or you may recalibrate your controller, reason why you push throttle forward but will not fly forward.
Dec 27, 2013 | YIBOO Toys
Need to find out what model of yiboo helicopter this is to find the blade
Measure the length and width of the blade you have and then go on line to the Yiboo Helicopter website and talk to the technicians. Have the helicopter handy if they have other questions..don't forget to ask them for a parts list for your model (You'll need it if you fly it)!
Dec 28, 2012 | Toys
Helicopter charging red light not blinking
The charger may not be plugged in all the way in either the helicopter or the wall.
Aug 22, 2012 | Toys
Me and my dad have 2 yiboo Uj4708 helicopters. We need to know how to change the frequency on them so we can fly them simotaniously. We can change the frequncy on the remotes, but don't know how on the...
Turn both helicopters and remotes off. Then switch the remote to another channel, either a,b, or c, turn on HELICOPTER FIRST, turn on REMOTE second. Move throttle up and down, helicopter should start responding.
Dec 26, 2010 | Toys
It says FREE tech support...Uh, where is the free in this?
If you would post a valid question, usually someone will try to answer your valid question, Uh, at no charge. Myself and others on here answer questions and give tech support for free everyday.
Oct 18, 2010 | 2007 Suzuki Reno Hatchback
My Yiboo Micro Blade Rc copter won't charge. I've tried disconnecting and reconnecting the batteries, but every time I plug it in the charging light doesn't come on and it goes into transmitting mode....
Well my K11 helicopter that I bought from Paddys Markets Sydney Australia last week for $45 gave up after three flights. I suspect the battery is either dead or not charging or a burnt out wire. I suspect your micro RC helicopter has a similar issue. I smashed open my charger with a dumbell weight to see if the wiring inside it was ok. All looks good, but when it is plugged in, it does not even produce heat, which chargers always do to a certain amount. I also dismantled helicopter and took out battery. For $45 it is not worth me buying a voltmeter, another charger (which I cannot find online) and my manufacturer has a dodgy website as well! I recommend keeping your toy for parts and maybe getting another one?
Sep 10, 2010 | Max 2 Tail Rotor Blade For Yiboo Shark Rc...
MY YIBOO CHINOOK HAS A BROKEN MAIN BLADE HUB. WHERE CAN I FIND REPLACEMENT FOR MAIN BLADE AND SHAFT?
I found this on xheli.com. Syma S022 big CH-47 chinook.
Looks like the same heli as Yiboo. Lists all spare parts.
Good Luck. Please post results if you order from this site.
I also have the Yiboo CH-47, have not needed parts yet, just got it for xmas from my wife.
Sep 15, 2009 | RC Toys
Toys Logo
41 people viewed this question
Top Toys Experts
ray gallant
Are you a Toy Expert? Answer questions, earn points and help others
