Question about Garden
John deere made loud pop and now wont start - Garden
  • 11 Answers
SOURCE: john deere 2010 tractor. pto grinds and wont engage
The PTO usually has a clutch that has to be engaged so that you can select the PTO rotation setting. I had a problem like that on my tractor and all it needed was a little adjustment on the PTO clutch lever, so it could disengage the PTO gearbox properly.
Posted on Mar 11, 2009
  • 109 Answers
SOURCE: my 2007 john deere eztrak z225 wont crank even
If i understand you right the little square piece is the solenoid, and it should be replaced if it is making a buzzing noise
Posted on Apr 26, 2009
  • 10865 Answers
SOURCE: john deere 420 trouble starting getting gas and
The engine needs air, so be sure the air filter is clean. If it is not, replace it.
The engine needs spark. Replace the spark plug and be sure that the battery has a complete charge.
The engine needs good fuel so be sure the gas is newly purchased, not gas that has been sitting around for months.
Posted on May 19, 2009
  • 69 Answers
SOURCE: JOHN DEERE 318 LAWN TRACTOR WONT START
ok, since you have the points, I assume you have the B43g Onan
engine. Was it running before the new parts were installed?
Check your point gap and make sure it is .016, plugs ahould be gapped at .025 Make sure your plug wires are good too. Should be somewhere between 0 and 10,000 ohms per foot, when measured with an ohmmeter. Once everything is rechecked for gap distance, make sure there is no spark by pulling plug out, leaving wire on and ground the outside of plug to the chassis of the tractor.
Crank over and look for the spark. Coils are about $100, so you want to eliminate everything else first.
Diagnosing a points ignition for no spark is really simple. Do you have 12V at the coil? Do you get a spark when you connect and disconnect the negative terminal of the coil to ground? If not you have a bad coil.
SOURCE: I have a lx 255 john deere wont start
You have a defective ignation coil. When the engine gets hot, the winding in the coil opens and the engine stops. After it cools down, it will again make contact and start again. If you don't know where the coil is, follow the wire from the spark plug. The spark plug wire is attached to the coil from the factory. It's easy to replace with a 1/4 inch socket set. Set the magnet to coil gap with a standard business card.
Posted on Jul 27, 2009
John deer L110 17 1/2 Kohler engine fires but doesn't start, it just pops like a gun shot
given the info available , it sounds like either a hole in the piston or a burnt/stuck valve. the popping sound could be a backfire, from improper detonation of fuel ,a simple compression test will tell if this is in fact the problem.
Apr 24, 2014 | John Deere Garden
John deere tractor wont take up throttle
try some lucas gas treatment. may have something to do with the float in carb. Might replace it and try.
Jun 20, 2013 | Garden
John deere 420 has loud pop and motor quits
take off the valve cover and see if the valves are opening
May 21, 2012 | John Deere Garden
John deer 310 g wont start after it sitts a day
if its turning over check your spark. if you have spark remove the air cleaner and spray some carburetor cleaner to see if it start than stops- let me know
Oct 13, 2009 | John Deere 420,1020,2010,2020,2510,2520...
Wheel turnd left OK Wont turn right, Get loud
THE GEAR ON THE SHAFT IS STRIPED OUT NEEDS A NEW ONE
Sep 05, 2009 | Garden
John deere gator kas motor
fuel filter may be blocked
carby may need a good clean out & retuned
Cheers Rob
Mar 23, 2009 | Peg Perego John Deere Gator HPX
Garden Logo
Top Garden Experts
Dennis Key
Dennis Key
john h
