Repairclinic.com kohler engine model# 917257740 will start and run for about 5 minutes and will shut will not start until it is cool. what is the problem
  • 48 Answers
You have to check that the cooling system is working. Check the ventelator
Posted on Jul 10, 2013
I have a walker 18hp with kohler engine. Started it up and it ran for about a minute and cut off. turn the ignition and it won't make a sound. cleaned battery terminals and changed spark plug.
Running for about a minute sounds like fuel starvation. There could be an obstruction in the fuel tank, which allows the engine only the fuel that is in the fuel line, until it quits.
Why it won't start again is probably another matter.
Feb 09, 2017 | Kohler Engines New 18 HP Kohler Engine...
I have a 18hp kohler it starts and ruins for 5/ 10 seconds and them shuts down and there is a cloud of white smoke
Air cooled engine ok ,
When the engine shut off did it white smoke out the garden it could be the head gasket
Low compression and it won't start poor compression and it might start but run poorly stall easily and white smoke produce because of unburnt fuel escaping into hot exhausts and vaporizing
Jul 03, 2016 | Garden
My fan will not shut off when I shut the engine off
How long does it run? some cars will run the fan for a few minutes to ensure that too much heat does not build up under the hood. Wait for 5 minutes and see if it is still running when the engine is off. If it is you may have a bad temperature sensor. Does the engine temperature gauge work properly?
May 31, 2015 | 2001 Dodge Caravan
Why does my Kohler 7.3 generator start and runs great for about 5 min. then shuts downRestarts fine but shuts down seconds later. Upon removing rad cap, fluid is seen moving upon warm up. How do I...
change the oil to the correct specification first. As the engine runs the heat changes the viscosity and overheats or trips the oil alert switch. If its over 10 years old change the oil alet magnetic switch
Jun 12, 2014 | Kohler Electrical Supplies
I have a 1998 ski doo 700 Mach 1 that starts right up and will ride fine for about 5 minutes then will shut right down. It will start right back up again then stall after 2 minutes, and keep doing this....
When the engine overheats, a thermocouple sensor will shut the engine off to protect it from damage. After cooling for a period, you can restart it and run until it overheats again. Check your cooling system ports for clogs and water pump impeller and function.
Jan 22, 2018 | Boating
My gen starts and runs for 1 min or so then dies restarts then dies again and again. if i start it under load ( turn on air con) it will run for 10 min then die allen
Is there a fault?? All UL listed generators including Kohler are required to lockout on a fault on shut down. This really sounds like a problem with your 2-wire auto start connection between your automatic transfer switch and genset. RDT model automatic transfer switch it is the 2 middle wires on the green connector and terminals 3&4 in the generator. close to run and open to shut down. Any open at any time will cause the unit to shut down. The 12 will shut down instantly upon an open because your 5 minute cool down is built into the transfer switch.
Jun 27, 2011 | Kohler 12 kW Emergency Power System -...
Kohler confidant 4 generator will not run.
i got the same gen and with the same problem
mike
Sep 24, 2009 | Kohler Electrical Supplies
87 Ford Taurus 3L engine shut down when warm - will not restart
after it has shut down check for gas at the fuel rail with the key on their should be gas squirting out constantly it sounds like the fuel pump is going out
Jul 28, 2009 | 1987 Ford Taurus
Computers & Internet Logo
15 people viewed this question
David Payne
David Payne
