HOW TO RESET HITACHI BLURAY MODEL HBD316 TO FACTORY
How to reset to factory settings hitachi model 50ex11bv
If you want to make it a system reset [Factory Reset]; you have to enter its service mode option, and select the factory reset option. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Service mode entry, adjust and exit procedure to many popular brand TVs are given. Never forget to exit the service mode, after all adjustments have been done.
Oct 14, 2014 | Televison & Video
One station only has lost sound but piture is great. All other channels work fine.
Have you tried retuning the TV? You may need to do a Full Factory Reset tuning rather than just a rescan.
Rescan simply looks at the place holders where the old channels were stored and refreshes them. A Factory Reset (A.K.A. Shipping Condition) wipes the channel memories and starts again fresh.
Sep 09, 2014 | Hitachi Televison & Video
Factory reset hitachi tv
To do a factory reset (System reset); you have to enter its service mode option. Like older model TVs, there is no switch marked "Reset"; to latest model sets.
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. Do a search by type in the brand name of your device at its search box and press "Enter".
Jul 23, 2014 | Hitachi Ultravision P50S601 50 in. Plasma...
Hitachi 57F500 dvi input no picture or sound
I had to go to amazon and buy a convertor to convert the hdmi to regular to get my bluray to work with my tv
Jun 08, 2014 | Hitachi 57F500 57" Rear Projection...
My hitachi tv 36ux01s is stuck on pip. need to reset factory settings
Enter factory mode, and do a factory settings. If you wish to get some details; check the site linked here. Viewing it in "Mosaic" will make surf easy.
Mar 20, 2014 | Hitachi 36UX01S 36" TV
My samsung BluRay Player BD D5700 will play DVD's but will not play BluRay DVD's.
I had a similar issue. Try resetting your resolution. By default it should be at the highest level. I reset mine to 1080i and now the BluRays will play.
My TV is a few years old, I think it was bogging down because it was getting too much information from the player, but that's just a guess.
Jan 28, 2014 | Samsung BDD5700 BluRay Player
Hi have a hitachi c29-f100, how do I reset it
Hello
I'm not sure about what preset option you are asking for. If it is to reset the parentia passcode reset; key in '7777' will reset the set to its factory preset code '0000'. You can reset the passcode afterwards. If you wish to picture, sound etc; to return them to factory preset, select each window, hilight the reset option and pres enter. This will reset the that window settiing to its factory preset. OK.
Jun 27, 2011 | Hitachi 32UDX10S 32" TV
My BDP S550 was working playing most blurays. The other day I put the original release avatar bluray in and it came up as disc unknown, which had worked before. Now no blurays work in my bluray player...
If nothing is playing, you either have a dirty lens or it's out of alignment and will need service. Try a DVD lens cleaner that uses fluid, they usually cost 20 or so and can be purchased just about anywhere these days. If it still won't play, it's a service issue and needs repair/replacement, depending on cost. Get an estimate first. Hope the cleaner works!!!
Jan 24, 2011 | Sony BDP-S550 Blu-Ray Player
A better pic
Yes there is. You can buy an HD Disc player. There is two types out there, HD and Bluray. I would recommend Bluray because it seems like HD DVDs are falling off. So buy a Bluray player and Bluray discs instead of traditional DVDs, traditional DVDs will not put out in HD. Also, if you have cable, get an HD receiver and you can pick up the special HD channels. Good luck. If you need anymore help, let me know.
-Andrew Hawkins
Sep 26, 2008 | Hitachi 53UWX10B 53" Rear Projection...
Televison & Video Logo
73 people viewed this question
Top Televison & Video Experts
Electro Med Services...
