Question about Hoover H130E Front Load Washer
Incomplete programme cycle
This one has got me baffled. The main drum supports on my Hoover H130E failed as a result of corrosion - a common fault as they are alloy attached to a stainless steel drum - electrolysis does its worst. I had to dismantle the machine to effect the repair. Prior to this fault the thing worked perfectly. Now it seems to have a fault with the way it works through a programme. Basically, it often does not initially take in wayer although the drum starts to agitate. Eventually it will take a bit in but nothing like enough. Eventually it pumps out but then shuts down - all lights off and no spin. I have checked the brushes - they are absolutely fine. Moreover, the pressure switch does not appear to have any effect. Even with the flexible tube removed which should cause the machine to overfill, it barely takes in any water. All hoses are connected and there is plenty of pressure - no blocks or kinks. If you select the rinse cycle, it pumps out and then shuts down as above. If you select the spin cycle, it pupmps out, agitates but no spin. Every now and again it works through a programme ok but this is now very rare. Everything is connected up ok. Any ideas?
  • juanitaochoa Nov 12, 2007
    Hotpoint WF530 washing machine. Programme does not complete. Water does not empty. Water does not pump out (drain). Intermittent problem.
    Is this the main memory programme board?
    Sergeant:
  • 351 Answers
Check to see if theres any dry solder joints on the main board,or the board is probably faulty.hope this helps
Posted on Mar 04, 2008
SOURCE:
I have a hoover vision tech washing machine and the belt keeps slipping off.
Sorry to be the bearer of bad news, but 99% of "Belt coming off" problems are a result of the main bearings goingin the drum. I'll take a guess that the spin has become substantially noisier recently (As the bearings fail). When this happens the drum, and therefore the pulley on the back of the drum shaft, starts to rotate off true and as a result, the belt gets out of line and falls off. Price to do bearings is usually pretty much an uneconomical repair at about £140
Sep 24, 2015 | Hoover Washing Machines
Hi the belt on our hoover hnl 6166 nextra will not stay on. The motor and the drum seem to be out of alignment and there are no broken screws or bolts or wobbles. Any ideas please? Thanks Robert.
I would suggest that the drum is out of alignment because the main bearings have failed, or the drum shaft has collapsed due nto corrosion.
Spin the drum by hand, and listen for any noise, there should not be any, and see if the drum rotates centrally in relation to the outer drum
Feb 02, 2011 | Hoover Nextra HNL 3166 Z Front Load Washer
Into the spin dry cycle a loud hammering noise appears. Immediately goes away when powered off and drum speed drops. Can you please advise. Regards Geoff
When my washer did that, I found that the shocks that hold the tub were bad...
Check out this tip I wrote about the noise and vibration that front load washers can make..
Washer Problems Washer noise when spinning
heatman101
Oct 05, 2010 | Hoover H130E Front Load Washer
Hoover H130E 'Superwash' and start light flashing after cycle....
You might try unplugging the power cord for 5 minutes, then restore power again. Try the machine again--if still has problems (beat son severely), you may have to replace the control unit.
Aug 11, 2009 | Washing Machines
I have a hoover hsp15 select 1500 that wont spin or drain properly. Where is the filter so I can check that out?
The filter on most hoover machines is behind the kick plate at bottom front of machine.
Post back if further assistance required.
Thanks for using fixya.
Nov 29, 2008 | Hoover H130E Front Load Washer
Door on the Hoover washing machine, model H130E
make sure the tap is not broken off ,if the tap is good that means you switch is bad, replace it. hope this information could help you.
Apr 23, 2008 | Hoover H130E Front Load Washer
Hoover 1300 washing machine
hi there this is a common fault you will need to replace the control module and selector switch/timer
Dec 01, 2007 | Hoover H130E Front Load Washer
Hoover H130E Front Load Washer Logo
115 people viewed this question
Top Hoover Washing Machines Experts
Gerry Harvey
Gerry Harvey
Poppa Maddo
Poppa Maddo
jimorris77
Are you a Hoover Washing Machine Expert? Answer questions, earn points and help others
