Question about York Exercise & Fitness
Xc350 manual one of the wheel cranks has broken how do I remove the wheel front
    Problem Solver:
  • 8 Answers
Do u still need a manual for york x c350 gym ??
Posted on Oct 24, 2013
Wheel speed sensor broke off in the knuckle how to remove
Wheel speed sensor removal? Stuck on tight! - North American Motoring
www.northamericanmotoring.com/.../191868-wheel-speed-sensor-remov...
Jun 29, 2010 - I've read here that having my DSC/ABS/Tire lights going off and on .... of the sensor before putting it back in the hole on the steering knuckle,
Chilton's Auto Repair Manual, 1993-1997
https://books.google.com/books?isbn=0801979196
Chilton Book Company - 1996 - ‎Technology & Engineering
Top off the master cylinder reservoir to the proper level with DOT 3 type brake fluid only. ... Remove the front wheel(s) of the wheel speed sensor(s) requiring removal. 4.Remove the speed sensor cable routing bracket from the steering knuckle. ...Carefully inspect the tone wheel for broken or missing teeth which can cause .
Nov 23, 2015 | Cars & Trucks
Xc350 manual york
please download from www. fitness.manualsonline.com + www.retrevo.com
God bless you
Jul 09, 2013 | Exercise & Fitness
I need to replace the crank shaft sensor
Yes. Jack the car up securely. you need to take passenger wheel off.remove caliper off . remove rotor. remove shock assembly and wheel bearing assembly slide.axleshaft out of the way.take serpinetine belt off. remove cover so you can see and access harmonic balancer.use impact to take bolt out of harmonic balancer.use wheel puller to take off harmonic balancer. Crank sensor should be right under harmonic balancer.
Jan 05, 2012 | 1994 Oldsmobile 88
Flywleel moving but the crank is not moving
Sorry to tell you this - The flywheel is broken from the crankshaft and you will need to replace the crankshaft/flywheel.
Aug 05, 2010 | Ford Ranger Cars & Trucks
How do u change the timing belt on a 1990 4 cylinder honda accord?
Disconnect the wire harness at the distributor.Remove the spark plug closest to the drivers side front tire. Place the palm of your hand over the valve covers empty spark plug hole and have a helper crank the motor over until air pressure pushes past your the palm of your hand. Next, look at the cam shaft wheel and note the direction that the arrow is pointing, the arrow should be pointing straight up IN RELATION TO THE ENGINE not the earth. If it is not, you will need to manually rotate the engine till the cam wheel is infact pointing straight up. Next, Jack up the front of the car and support it with jack stand and remove the front drivers side tire.Next, support the weight of the engine with a floor jack remove the motor mount closest to the drivers side tire To remove it you will need a deep 17mm socket on a heavy duty breaker bar. Next, loosen and remove the power steering belt and alternator belts. To loosen and remove the belts you will need a 10mm wrench and a 12mm wrench. And also a 14mm or 15mm wrench. Next, use a 19mm socket AND an air powered IMPACT wrench to remove the bolt holding on the crank shaft pulley. Next, remove the crankshaft pulley. Next, use a 10mm wrench and/or 10mm socket and remove the bolts holding the plastic engine side cover. Next, loosen the 14mm or 15mm bolt which secures the 2 belt tension wheels. Next, LOOSEN the 10mm bolt that is on the balance shaft tensioner. The balance shaft is the cogged wheel with a small timing mark dot on the side of the wheel. Next, loosen the 10mm bolt on the timing belt tensioner. It's obvious what wheel is the timing belt tensioner. Next, remove the 12mm bolt on the back side of the block (near the balance shaft) a little bit of oil will drip out, this 12mm bolt will allow a long bolt to be inserted into a recessed channel of the balance shaft. This recessed channel is needed to lock the balance shaft in place. A bolt from the air conditioner works great for locking the balance shaft in place. You're basically just pushing the bolt in a hole to keep the balance shaft from spinning.890a27a.jpg Next, remove both the balance shaft belt and timing belt. Then reverse the procedure to complete the new belt installation. EXTREMELY IMPORTANT!!!!!!!!! PLEASE NOTE, the oil pump wheel furthest to the left (closest to the radiator), has a timing mark on the flat face side of the wheel, that timing mark has to be pointing directly to the 9:o'clock position in relation to the engine. The cam wheel has an arrow on the side of one of the "spokes" ...make sure it is pointing straight up in relation to the engine...straight away from the crank shaft. Put the crank wheel on with the arrow pointing straight up to the center of the cam wheel.
Jun 28, 2010 | 1990 Honda Accord
Broken wheel stud on the left front wheel-
Try spinning the hub around to different spots to see if you can wiggle it out.
Apr 08, 2010 | 1998 Honda Civic
Front drive shaft not fully engaged in 4WD, with truck on stands all 4 wheels do rotate but if i stop front wheels the front drive shaft is not engaged
Do you have auto locking hubs on the front wheels, or manual locking hubs?
If you have auto locking hubs chances are they are not engaging properly and will need to be removed and spline sets checked for broken teeth on locking hub and locking shaft.
If you have manual locking hubs then check that they are firm when turning to engage them in the lock position.If they are light when engaging them to the lock position then they my have broken/worn out the locking hub and spline. Also check that the engaging spring inside the hub has enough tension to engage the hubs they may be broken. If the hub are all ok then you have a problem in the transfer box, where the 4WD lever is not meshing the transfer box properly. Hope this helps, let me know how you get on.
Jason
Apr 04, 2010 | 2002 GMC Sierra C/K1500
Fly wheel location
Instead of trying to turn fly wheel, try to turn the crank pulley, located on front of motor it is the main pulley.
Jun 19, 2009 | 2002 Toyota Celica
Cant remove wheel hub
here is procedure
Section 04-01: Suspension and Wheel Hubs, Front 1996 Taurus, Sable Workshop Manual
REMOVAL AND INSTALLATION Wheel Hub Bolt Removal
  1. Raise vehicle on hoist.
  1. Remove wheel and tire assembly. Refer to Section 04-04 .
  1. Remove disc brake caliper (2B120), and front disc brake rotor (1125). Refer to Section 06-03 .
Brake Shoe and Lining Removal
  1. Remove brake master cylinder filler cap (2162). Check fluid level in brake master cylinder reservoir (2K478). Remove brake fluid until brake master cylinder reservoir is half full. Discard removed fluid.
  1. Raise vehicle on hoist. Refer to Section 00-02 .
  1. Remove wheel and tire assembly from front disc brake rotor mounting face. Use care to avoid damage or interference with disc brake caliper (2B120), front disc brake rotor shield (2K004) or front wheel knuckle (3K185).
  1. Remove rear brake pin retainers (2N386). ( I think it is a T 40 torx bit you need)
  1. NOTE: It is not necessary to disconnect hydraulic connections.
    Lift disc brake caliper from front disc brake caliper anchor plate (2B292) and front disc brake rotor (1125). Do not pry directly against metal caliper piston or damage will occur.
  1. Position disc brake caliper out of the way and support with wire to avoid damaging the disc brake caliper and front brake hose (2078).
  1. Remove outer brake shoe and lining (2001) assembly from front disc brake caliper anchor plate.
  1. Remove inner brake shoe and lining assembly.
  1. Position lug bolt (1107) to clear front wheel knuckle (3K185).
  1. Remove lug bolt from wheel hub (1104).
Installation
  1. Install lug bolt into wheel hub.
  1. Using a lug nut (1012), seat wheel hub bolt into wheel hub.
  1. Install front disc brake rotor and disc brake caliper. Refer to Section 06-03 .
  1. Install wheel and tire assembly. Tighten lug nut to 115-142Nm (85-104 lb-ft).
May 25, 2009 | 1996 Mercury Sable
Where is the battery located on a 1999 cirrus
The owner's manual says to crank the steering wheel all the way to the left. It is difficult and I had to lift the battery with one hand when replacing it, but you can get between the wheel well and tire, without removing the wheel.
Nov 22, 2008 | 1999 Chrysler Cirrus
Exercise & Fitness Logo
35 people viewed this question
Top York Exercise & Fitness Experts
Electro Med Services...
Tom Chichester
ray gallant
Are you a York Exercise and Fitnes Expert? Answer questions, earn points and help others
