Question about Cameras
How to set date on vivitar vivicam 46
Can't figure out how to set date so right date appears on photo as date taken.
SOURCE: vivitar vivicam 35 software
i want to download the software
Posted on Oct 28, 2008
  • 102366 Answers
SOURCE: How do I set the date on the Vivitar Vivicam 5022?
Get the manual at http://vivitar.com
Posted on Dec 28, 2009
SOURCE: i have a vivitar vivicam t324, i cannot find where
hit the M key scroll over to were it says setup srcoll down its between digital zoom and auto power off it will say date
Posted on Jan 10, 2010
  • 102366 Answers
SOURCE: how do you set date and time on a vivitar vivicam
There is no date and time to be set on the 5022.
Posted on Jan 20, 2010
  • 4 Answers
SOURCE: How do you set the date on the Vivitar Vivicam
1. Turn on the camera
2. Press the SET button (lower right).
3. Press the "trashcan" button ( to the right of the SET button) to scroll through the setup menu, 15 times, to get to the calendar icon.
4. Press the "ViviLink" button (below the SET button) to scroll down to "date setup."
5. Use the buttons surrounding the SET button (Scene, Trashcan, Flash, and ViviLink) as left,right,, up, and down arrows. Use up and down to change the month, then right to get to the date and up/down to change it, then right again to get to the year and up/down to change it, and so on through hour, minute, second, and AM/PM. Once the clock is set, press MODE to accept the settings.
6. You can scroll up and change whether you want the camera to timestamp the pictures - I turn this off.
7. Press mode again to exit the setup.
Posted on Sep 11, 2010
I asked before how to remove the date/time stamp from photos already taken. The answers I received which is to go into settings and turn off the date/time stamp, only works for photos that will be taken...
Yes. You do it the same way you would get rid of any other unwanted element in the photos.
Once the camera stamps the date onto the photo itself, the date is as much a part of the photo as the faces or anything else in the photo.
Aug 04, 2014 | Vivitar Vivicam X014n Digital Cameras
How can I remove the date stamp from the front of the actual photos after they are taken?
There should be a "Date/Time" option in your setting menu. Most likely it will give you an on-off option.
Aug 04, 2014 | Vivitar x014n - Vivicam X014n 10.1...
Delete date from photo
That is correct. The date setup only affects pictures when they are taken; it will not alter pictures that have already been taken.
If you want to remove the date from a picture that already has it, you have to remove it the same way you would remove any other unwanted object from the picture.
Feb 21, 2013 | Vivitar Vivicam T027 Digital Camera
How do I change the date and time on a vivcam8225
Hello and welcome to FixYa!
This following steps allows you to set the system time which will be displayed on the photos.
  • Press the Up or Down buttons to select the Date option in the Setup menu.
  • Press the OK MENU button.
  • Press the Up or Down buttons to select a Date option from the menu that appears
On selecting "On" the date will appear on the photo once it is taken.
On selecting "Off" no date will appear on the photo.
On selecting "Set Date" the Set Date settings screen will appear. You will be able to change the date settings that will appear on the photo once it is taken.
To Set the date:
  • Press the Up or Down button to enter the Set Date option.
  • Press the Right/Left button to select and highlight the Year, Month, Day, Hour, Minute, Second and Date Format type.
  • Press the Up or Down button to set the Date and Time digits.
  • Select the first option of the Date format and press the Up or Down button to set the date format that appears on the top line: YY MM DD; DD MM YY; MM DD YY.
  • Press the OK MENU button to confirm, save the changes and exit.
You have done it.
I hope this solution helps you
If you have any more query or issue regarding your problem do inform me.
Thank you for using FixYa!
May 16, 2011 | Vivitar Vivicam 8225 Digital Camera
Trying to set date/time for the first [ what is the wrench button?]
The "wrench" is NOT a button, it is an icon in the menu.
Press the MENU button. Press the Right/Left button to select the "WRENCH" icon The Setup menu appears in the center of the LCD. 3. Press the Up/Down buttons to select the Date option in the Setup menu. Press the MENU button. Press the Up/Down buttons to select a Date option from the Menu that appears: On selecting "On" the date will appear on the photo once it is taken. • On selecting "Off" no date will appear on the photo. • On selecting "Set Date" the Set Date settings screen will appear. You will be able to • change the date settings that will appear on the photo once it is taken. To Set the date: Press the Up/Down button to enter Set date option. 1. Press the MENU button. 2. Press the Right/Left button to select and highlight the Year, Month, Day, Hour, Minute, 3. Second and Date Format type. Press the Up/Down button to set the Date, time and format
May 07, 2011 | Vivitar ViviCam X327 Digital Camera
Please...which is the wrench button? vivitar x327 trying to set up date/time. for the 1st time
Have found where I can set date/time on my Vivitar CAM6300 Digital Camera but stamp doesn't appear on actual digital photo. How can I set the date/time to appear on the final image?
The date and time (and a lot more) are stored with every picture in its EXIF metadata. Any photo viewing/editing program should be able to display this data. To print this data, please consult the documentation for whatever program you're using to print your pictures. Depending on the program and printer you may print the date on the image, in the margins, or on the back.
Jan 13, 2011 | Vivitar ViviCam 6300 Digital Camera
Cannot set the date on Vivitar Vivicam F328.
Press the HOME button to bring up the main menu. Touch the pliers-and-screwdriver icon function area to enter the Setup menu. Touch the down-arrow function area repeatedly until "Date" appears. Touch the calendar function area to enter the Date menu.
Jun 16, 2010 | Vivitar VIVICAM 7388 Digital Camera
How to delete the date from photos
Cameras normally have a setting where you can turn the date stamp on or off. Just browse through the menu. It will be there somewhere. In he case of the photos already taken with the date stamp you will be able to remove it with the brush tool in Photoshop.
Hope this helps!
Cheers
Sep 27, 2009 | Vivitar ViviCam 5385 Digital Camera
Date stamp will not appear on photo. i was told that there is on/off setting for this in the general setup menu called "date stamp" however,the model "vivicam 3765" has no such setting. how do i get the...
Jun 13, 2009 | Vivitar ViviCam 3765 Digital Camera
Cameras Logo
65 people viewed this question
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
