W10280546b whirlpool The washer sounds like the bearings went out of it, How much are the replacement parts for this issue?
    New Friend:
Depends mostly 75$ to 150
Posted on Jul 09, 2013
  • 1073 Answers
SOURCE: Help with bearing
i do hope that you have been using he detergent if not it will take the bearing out, if you have then the bearing just went bad i would call whirlpool at 800-874-4698 they may be able to offer assistance if you dont have an extended contract on the washer
Posted on May 13, 2008
onthejob5130
  • 640 Answers
SOURCE: whirlpool duet washer tub bearing
wow ,,that unit must sound like a jet ..this is a job,,i can talk you though but i cant tonight,,if you can wait i will help tommorow at 6 after work..if you need a little head startgo to cematters.com
Posted on Jan 09, 2009
jimappliance
  • 42 Answers
SOURCE: NEED bearings for washer. Where do I find the parts??
Call 888-474-8362. Provide them with a model number and the parts you need and they can ship it out that same day if in stock. :)
Posted on Aug 01, 2009
  • 867 Answers
SOURCE: The bearings on my Whirlpool
Yes you can just replace the bearings but be careful. they say to replace the entire drum as the materials they are made out of is not very strong and you can distort or damage the drum when removing the bearings.
Posted on Oct 25, 2010
  • 670 Answers
SOURCE: Whirlpool Front load washer - wfw9400sw01. Sounds
A loud rumble noise during the spin cycle is a good indication that the bearings have failed. The bearings are located in the rear outer tub. See link http://www.appliancepartspros.com/part_details.aspx?part_id=4426951 There are actually two bearings an inner and an outer bearing plus a seal. Water must have leaked past the seal causing the inner bearings to corrode. Once they start to rust, it just gets louder and louder. You are correct that Whirlpool does not sell the bearings and seal separately, but you must buy a new rear outer tub currently the price is over $400.
I had it happen to a different brand of front load washer and was faced to either, replace the rear outer tub, junk it or figure out how to replace the seal and bearing. I opted for the last and did some research on finding replacement bearings and seals. I had to tear the washer apart to get the bearings, then pound out the old ones to replace with new ones. It been working find for the last 2.5 year so far.
I found a website that might help you locate bearings and seals for your machine. http://www.hometask.com/washerrepair.aspx The site has a video on how to tear down your machine and shows you how to remove and replace the bearings. He might have the ones that you need on his site. Hope this helps you.
Posted on Apr 25, 2011
Testimonial: "Excellent feed back! Not were the required repairs confirmed, but a cost effective option was also shared! Thank you!"
Why do I have this Clicking Noise after bearing and seal replacement
  1. Ft. Cabrio Top Load Washer‎
    Adwww.sears.com/‎Black Friday Sale Save Over 40% on Select Appliance
    Hot Buys. Free Delivery Over $399.
  2. Appliance Hot Buys
    You'll Save More When You Shop Hot
    Appliance Buys on Select Products!
Search Results
    Whirlpool WTW6400SW Cabrio Washer Makes clicking ...
    www.fixya.com > ... > Whirlpool WTW6400SW Cabrio Washer
    Whirlpool WTW6400SW Cabrio Washer, makes clicking noise spin cycle related issues. Get free help, solutions & advice from top Whirlpool experts.
Nov 26, 2015 | Whirlpool WTW6400SW Cabrio Washer
When the washer spin it has a load noise, it sounds like a plane is comming down. I have a duet sport whirlpool washer
the bearing probably went bad, thats the sound it makes, may even sound like a freight train at times.
Feb 11, 2011 | Whirlpool Duet GHW9150P Front Load Washer
Makes grinding sound on spin cycle
Most likely the bearing is bad. The outer tub w/ bearing would need to be replaced. The part cost is about 199.99 plus shipping. I would call whirlpool and see if they would cover the part. have the model , serial numbers and a date of purchase. 1-800-253-1301.
Feb 04, 2010 | Whirlpool Cabrio WTW6600SBT Top Load...
Whirlpool Duet WFW9200SQ02 - high speed spin extremely loud!
I have the exact same washer, its also 2 years old, and this last week my bearings went bad too. I actually pulled my washer apart and replaced the stock el cheapo bearings with some better quality ones by Toyo. No, theyre not titanium, I'm a mechanic and I've never even seen titanium sealed bearings before. Not doubting they exist, but I highly doubt youll find them in any residential appliances regardless of make. Upon disassembly, I found what I believe is the issue with the seal, hair. Hair works its way to the drive shaft, slowly works its way into the seal, and then acts as a conduit for the water to enter the bearing cavity. Both sealed bearings eventually have thier grease forced out by water, and fail. This repair is time consuming, but it can save you a LOT of money. Whirlpool only sells a whole new rear tub, at a cost of $408 just for the part. I took it apart and found that the bearings are simply pressed into the steel hub on the rear tub half. I knocked them out, and a local bearings and drives shop had some replacements for me, for $20. I put it all back together, and its running fine. If you attempt this repair, make notes, and mark where everthing goes. You'll need to disassemble a substantial amount of the machine to get the tub assembly out. If youre not able to do the repairs yourself, I recommend buying a new washer, its just not worth spending $6-700 to have a shop do it.
Jan 23, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Squeeking noise on whirlpool washer duet ghw9100lw2
replace your belt in back easy.every year if still has smell buy warranty your rear bearing is going bad."less soap plz"
Nov 13, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Help with bearing
May 13, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Washing Machines Logo
232 people viewed this question
Top Washing Machines Experts
