Question about Arcam Audio Players & Recorders
Hooking up a subwoofer to my Arcam AVR350
I can't figure out how to hook up a subwoofer to my Arcam Avr350. the back of the subwoofer only has one terminal - "LFE in" Any thoughts?
SOURCE: JVC RX-809V
hey i have a bose sub too. in order to get the best sound out of it using the motorola reciever, you need to hook all your speakers together and run them into the sub, then from the sub, run them to the receiver. it pounds hard
Posted on Dec 07, 2007
smarthome2
  • 1114 Answers
SOURCE: HTR-5740 Subwoofer Hooking Up Issue
You can use a hi-level to low-level adapter. Just remember, the Yamaha does not send power (wattage) to the sub, just signal. You need to use a subwoofer that has an amplifier either externally or built in.
Posted on Jun 26, 2009
SOURCE: Cannot get my LFE output to send signal to my
Having the exact same problem. Any solutions out there?
Posted on Nov 25, 2009
dunnbiker
  • 8546 Answers
SOURCE: No sound when hooking receiver to subwoofer using
Probably not if it takes RCA input, but the receiver needs to be informed of the sub's presence and hw you want to share low frequencies among the rest of the speakers and itself. Then you need to set the relative levels using test tones, which also proves the sub works.
http://www.retrevo.com/support/Sony-STR-DH700-Receivers-manual/id/23341dj691/t/2/
Page 102
Set the subwoofer to YES (Page 43)
Posted on Jan 17, 2011
dunnbiker
  • 8546 Answers
SOURCE: hooking up our onkyo ht-r340 the subwoofer has 2
First would be to name the subwoofer so we can look at its "Line OUT's". The IN's would be more important as far as ITS function goes. I'm sure a manual exists for the unidentified subwoofer.
http://g-ecx.images-amazon.com/images/G/01/electronics/detail-page/htr340large.jpg
This receiver has direct subwoofer amplifer for a passive (unpowered) subwoofer as well as a Subwoofer Line Out for controlling an active (powered) subwoofer amp.
Posted on Jul 24, 2011
Hook up pyramid subwoofer
if you are hooking up to a stereo reciever make sure the ohms & wattage are correct or it could cause problems if you are hooking up to a car head unit i dont advise it could damage both headunit and sub
Feb 21, 2013 | Pyramid Car Audio & Video
I am setting up 4 bose 901s to my home stereo and am unsure how to connect my components to tha 901s active equilizer. the 4 901s are connected to 4 marantz ma 500 amplifiers. the amplifiers are...
Hi -
Sony CD player Red / White RCA - > CD input RCAs on the Arcam.
From the Arcam Preamp Output RCA's, go to the Bose "Input". From the Bose "Output", you need RCA splitters to make them into four outputs to run your amplifier connections.clmrt5000_2.jpgclmrt5000_3.jpg
Jan 15, 2011 | Bose 901 VI Main / Stereo Speaker
I've hooked up amps before but I just recently got this Amp and I cant figure out how to hook it up to my subwoofers. Ive tried changing the channels and hooking it up to each one but all it does is makes...
try switching it to lp the from one sub if its 4 channel left + and right - this will bridge it see if you get better sound if u dont the amp is stuffed
Aug 11, 2010 | Car Audio & Video
How do i hook up the wires from and to a sa wms 315 subwoofer
what r you hooking it to is #1 rca wires r the way to go when hooking up a subwoofer up .some subwoofers have 2 rcas on them one input and one output the in put is mono if what your going to hook it to has rcas on it then the left one is a mono output but if its an audio system then it mit have a subwoofer output on it
Jun 29, 2010 | Sony SA-VA1 Rear Speaker
How to hook up a computer sub to a hometheater amp
http://www.arcam.co.uk/_ugc/file/avr280e_manual.pdf
If you have the whole Z5500 package you could run the Arcam's optical- or coaxial digital audio output to the corresponding input on the Logitech.
But I'd be careful about letting BOTH the Arcam and the Logictech perform Digital Sound Processing on the sound. DSP's aren't meant to be stacked. My money says the Arcam is better in the DSP department than the Logitech.
If you have just the sub, run the Sub PRE out from the Arcam to the Sub/Center input (adapt it to 3.5 mm) on the Control Center and set the switch to "6 ch direct".
Mar 06, 2010 | Jensen JW250 Main / Stereo Speaker
I am getting nothing but feedback from my car subwoofers
Check for crossed wires.... that is the only thing that would cause a steady bass note. Feed back is caused by cross talk between wiring.
Apr 02, 2009 | Car Audio & Video
Hooking power amp to back of sub
Contact Velodyne.
Should have been a sheet in the box with amp for this
Feb 28, 2009 | Velodyne SPL800R Subwoofer Speaker
Help!!
I need help hooking my speakers to my computer
May 11, 2008 | Coby CSP-94 Speaker
61 people viewed this question
Top Arcam Audio Players & Recorders Experts
Electro Med Services...
 Grubhead
Grubhead
berggei
Are you an Arcam Audio Player and Recorder Expert? Answer questions, earn points and help others
