Akg c414 xls problem
Hi, I just hooked up my akg c414b xls to my protools setup after recording with a different mic (that also requires phantom power and the akg lights up but is not picking up any sound at all! I know I tested this mic a year ago and it worked fine. Any idea what could be wrong? I used the same cable and setup as when I recorded with the other mic and literally didn't change anything except the track I was recording on. Thanks in advance! Dan
  • 13 Answers
SOURCE: SE2200A "wind" noises during recording
Its very descriptive and is quite a common problem with less expensive condenser mics. It's due to dirt or contamination on the capsule insulator or front end circuitry of the electronics. SE should be able to fix it for not much money.
Posted on Nov 30, 2008
  • 170 Answers
SOURCE: AKG Perception Microphone ony recording in mono but want stereo.
I have similar problems with inputing stereo sound. How do you know your mic port on the PC is set for stereo? What kind of a cable are you using? If it is an XLR, the connection is pure mono. Maybe you need a TRS cable, which looks like a 1/4 inch jack but is really stereo. Maybe you need a stereo mini. Usually a cable mismatch is the problem. Is your phantom power supply passing stereo? All the ones I have seen are mono. You may need two. Is your sound capture set for stereo? Are the input level controls set correctly for equal volume on left or right channel? I would try the mic with a regular amplifier to insure both channels are working. Then trace the signal from mic to power supply and power supply to computer.
Posted on Dec 03, 2008
  • 4 Answers
SOURCE: no recording?
In garageband when you have the gtrack set up , it will show you 2 options for input source 'USB Audio CODEC'. This is because you have 2 lines in, the mic and the jack. Make sure you have picked the correct one to record the vocals...otherwise it is expecting the jack input and will record nothing.
Hope this helps!
gypsykingthing (AKA alisondking coz there's not enough space for my trad tag!)
Posted on May 14, 2009
  • 12 Answers
SOURCE: Adobe Audition 3 Not Sensing Mic
Check the input and output settings. Look in the preferences or settings menu for "i/o settings" or "i/o setup." You're going to set it from the default internal mic input to this one. It sounds like it may be that simple.
Posted on Jul 29, 2009
Cableg Eye
  • 22 Answers
SOURCE: AKG Perception 200 Mic stopped working. I use it
The simple thing to check would be to see if your 48V phantom power switch on your mixer is turned on. Sometimes there is an individual button to turn it on and off for each channel strip. Good Luck
Posted on Oct 12, 2009
I have recently bought an AKG Perception 120 microphone and plan on recording through GarageBand on my Macbook Pro, but no sound is coming through. please help!
You say you have a XLR to USB the version of the 120 you have is the regular XLR version, right? Well if it is, it needs what's called "phantom power" to work. It looks like they have a straight USB version of this mic, and that's what you should have gotten if you didn't want to use anything else. If you still want to use this mic as is, I would recommend a Focusrite Scarlett 2i2. I have one and it's great. I do have a pc though and I'm not sure about Mac. But it's a usb powered preamp that gives you two mic pre's along with headphone amp, and a volume control for your speakers and has phantom power built in. Great unit and around $120. NFI.
May 14, 2014 | AKG Perception 120 Microphone
How would I go about hooking this mic to a Toshiba laptop? What would I need?
You will need an external mixer, interface, or phantom power supply.
Apr 22, 2013 | AKG Perception 120 Microphone
Hello There, I just bought the Rode NT1-A, and I am trying to record in protools, but i'm not getting any levels whatsoever. I'm plugged in to an MBOX, in the XLR, I have Phantom Power turned on,...
It sounds like you have done everything right. It would be a good idea to check both the mic and Protools system separately. If you can, verify that the mic works using another device such as a mixer. Also try getting a level into Protools using another mic, preferably a dynamic which doesn't require phantom power. If you are trying to use an original MBOX under Windows 7 or the latest version of OSX then it may not work at all.
Sep 19, 2011 | Rode NT1A Professional Microphone
Sometimes my AKG Perception 420 won't record properly, when played back it sounds like white noise with the faintest sound of what i'm trying to record in the background
All microphones have a signal to noise ratio. Basically defined as the level of desired sound to background noise (unwanted sound). Microphone phones also have self noise which should be considered when choosing a mic. There will be noise in every mic, some more audible than others. Condenser microphones require phantom power (48V). This can be supplied by mic prea
mps, mixers, and similar equipment. *Note that phantom power (mic pre amps) must be on or engaged, this can be specific to different types of equipment.
Troubleshooting:Has your microphone been dropped or exposed to moisture? Internal damage to your microphone will be hard to assess but this could possibly be the issue. Inspect the microphone cable, check for damages. Try using a another microphone cable-- preferably a new one. Next to check would be your mic's power supply. Make sure all connections are made properly (mic to cable to power supply). If you are using a mixer or pre amp with multiple inputs, test the mic on each input. (You should test by making recordings and comparing with each change to isolate possible causes). Also test the mixer or pre amp by slowly sweeping the input gain feature while recording an audible source such as singing into the microphone. Typically next in the audio recording chain would be your DAW (digital audio workstation) or computer, but problems with noise most likely precede this.
I could possibly provide more useful information if I know your exact setup.
Provided that you have your equipment setup properly, the microphone or mixer/preamp could possibly be damaged/malfunctioning. I suggest taking your equipment to a trusted repair shop, or if still under warranty, returning to the manufacturer for repairs or replacement.
Hope this helps
Apr 05, 2011 | AKG Perception 420 Microphone
The recording level to my Mbox is very low for some reason. I am running Pro Tools LE and I have a shure 87a microphone. Every time I attempt to record a track, the input volume is incredibly low...
Make sure you turn the Phantom power on the Mbox2 on as the Shure 87A requires it being a condenser mic.Make sure you use XLR mic cables. These are just things to check on.
Jan 29, 2011 | Digidesign *mbox2...
What is the switch for on the Phantom power unit at the end of my AKG C747?
Hi,the switch for the phantom power on the microphone is to activation of the mic.Without the phantom being activated, the mic will not work.
It can only be activated with a mixer console that has a phantom activation on it. After connecting the mic to the mixer,activate the phantompoweronthe mixer and switch on the phantom power on the mic,and problem solved.
Note: Mic will not work if no phantom activated on the mixer.
Oct 20, 2010 | AKG C747 Professional Microphone
Oct 06, 2009 | AKG Perception 200 Microphone
Akg c3000b Low output all of a sudden
Buy the Caig Labs De-Oxit kit and clean up/treat the XLR connections on the mic itself.
Apr 27, 2017 | AKG C3000B Professional Microphone
No sound from a Shure MX412D/C
Sounds to me like you may be missing a phantom power supply. The 570S is a Dynamic mic. The MX412d/c is a Cardioid and requires a 11-52v supply over pins 2 & 3 in the mic cable. Phantom power is a feature of most professional mixing consoles(usually 48v). If you do not have a phantom power supply on your system- then you can purchase single battery powered units to insert in the link between sound console and Mic. For example: AKG B-18
Hope this helps.
Feb 23, 2009 | Shure MX412D / C Professional Microphone
AKG Perception 100 not working, at all
The problem is that your amp probably doesn't have phantom power. This mic requires phantom power to be supplied to it via the XLR connector. Most mixers and mic pres have that feature, but most guitar amps do not, I believe. Hope that helps...
Jun 08, 2007 | AKG Perception 100 Microphone
32 people viewed this question
