Question about Onkyo TX-DS696 Receiver
Left rear surround channel sometimes doesn't work
The left rear surround channel of my Onkyo 696 sometimes works and sometimes doesn't. If I run the audio test, and it's not working, sometimes by increasing the volume on that channel I can get it to kick in and work, or I might get it to kick in if I turn it off and then turn it back on. I've also had this problem with the front right speaker, but not nearly as frequently as the left rear one. Someone mentioned cleaning the contacts, but I'm not sure if they meant the external speaker contacts or some internal ones. I have no problem opening the receiver up and doing some work if it would clear up the problem whatever it might be. So thanks to anyone who might have a solution to this problem... Sincerely, soinie.
If your receiver has speaker protection relays and they are intermittent due to bad contacts you might be able to repair them if they are not sealed. Most are but take a shot. They make small files for this purpose. Replacing them can be daunting because yo may not have good access. Tap the relay with the receiver playing and see if it helps.
Posted on Aug 27, 2007
No surround sound on rear speakers and cant access speaker set up functions. left front channel not working when rears set up without surround
from the problem description, it sounds like a wiring/setup problem with the speakers. check to make sure you are only using the main 'a' front r & l speaker connectors. if you select speaker set a + b on the front, you will not have the rear channels. please see the speaker connection guidelines in the manual on page 13-15. make sure the audessey mike and/or headphones are not plugged in when trying to use the speaker set up function.
manual: http://www.uk.onkyo.com/downloads/1/1/9/7/8/21637363_df4adc7f5e.pdf
Jan 21, 2015 | Onkyo TX-SR307 A/V Receiver
ONKYO TX-SR701 - Hi When using the speaker config I can get output from all speakers but the Surround back speaker R does not work. I do get sound from Surround back L. It's a bit confusing as the...
Register and download the manual for free at retrevo.com
http://www.retrevo.com/support/Onkyo-TX-SR701-Receivers-manual/id/365ag222/t/2/
7.1 would have Surround Back L and R.
6.1 would have just one back there (SB). It defaults to the Left output on the Pre-Outs if you ever go that route.
This being a 6.1 receiver it does not support two SB channels BUT you can configure those amp channels for a separate Zone supporting 2 speakers. Confused?
The manual shows a single SB speaker connected to the left side on Page 27. THAT would be consistent with a 6.1 configuration.
Jun 04, 2011 | Onkyo TX-SR701 Receiver
I have 1 center channel pre-out on back of my kenwood receiver. how do i hook it to the inputs on onkyo m-282 amp and then to center channel speaker?
Unfortunately can't connect it that way. The pre out is only meant to go directly into an amplifier that has all of the same inputs (front/rear, center and surround), not a standard receiver. (Pre amp to amp only, not pre amp to receiver) If your Onkyo doesn't have all the same inputs as your Kenwood preamp has outputs you will just use your standard left/right outputs from the Kenwood to your Onkyo input (CD, Tape, Phono,DVD etc) then use the outputs (front/rear, center and surround) from your Onkyo receiver and connect directly to your speakers..
Jan 01, 2010 | Onkyo M-282 2-Channel Amplifier
Onkyo TX-SR576 7.1 Rear Channels problem
Have the same amp and speakers, had some trouble getting the imput signals sorted from the HDMI input as im using a PC with HDMI output from the mother board and Windows Media Centre. havent tryed using the mic set up yet.
Did you resolve the issue? have you tried the 7.1 outputs
Jun 21, 2009 | Onkyo Audio Players & Recorders
Speaker Detect error Left Rear
Hey there.
I had the same problem until i figured out that if u dont have surround speakers connected it will be a error when trying to configure the rear surround speakers.
So if u are running a 5.1 system and have hooked up ur surround speakers to the back surround speaker port u have to change them to the surround speaker port.
Hope this work for u
Jan 11, 2009 | Audio Players & Recorders
Audyssey won't initialize the left rear channel speaker input during set-up
had the same problem found that the rear speakers were connected to the wrong inputs on the receiver, try changing them i think you will find that this will work
Aug 28, 2008 | Onkyo TX-SR605 Receiver
Left Surround Channel
Try to tighten the screws at the back where you insert your A/V jacks.
Thanks!
Apr 10, 2008 | Onkyo TX-DS575 Receiver
Rear left channel not working on Onkyo NR801
Sounds as if it's time for a shop visit, unless you want to try this yourself. The panel connection on the rear of the receiver, or the protection relay have apparently come loose from the circuit board. It happens sometimes when stress causes the cabling to pull on the back of the unit..accordianman
Feb 16, 2007 | Onkyo TX-NR801 Receiver
NO surround sound coming from our harmon/kardon speakers when set up to our onkyo tx-sr601 receiver. wires connected in correct areas, front left, right and center speakers work, subwoofer works. setup for...
So your saying that you have no rear channel. Some recivers use a single stereo output ic for both sides on the rear speakers. you could have a defect with this IC . Anther thing Im sure you check3ed the obvious ie : the switch is on suround sound? If there is a front to rear fader is it in the middle? Good Luck
Jun 04, 2006 | Onkyo TX-SR601 Receiver
Onkyo TX-DS696 Receiver Logo
164 people viewed this question
Top Onkyo Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you an Onkyo Audio Player and Recorder Expert? Answer questions, earn points and help others
