Question about Air Purifiers
Turn on chart with ma friends - Air Purifiers
Waldah I love u so much
Posted on Jul 09, 2013
Dryer display blinks on ND OFF WHEN TURNING DIAL or pressing start and does not turn on
I appreciate your post, friend!
From the information you have provided your Electrolux dryer's displays blinks on and off when you turn the dial and it does not start. This sounds like a possible issue with your door latch or control panel. I would recommend for you to check the door strike and door latch to make sure there is no visible damage. If you do not see any damage this could be a wiring issue within your door latch or control panel. This is not a simple DIY job and I would suggest having a professional out to perform an accurate diagnosis. I hope this is helpful information. -Matt
Mar 01, 2015 | Electrolux EIMGD55I Gas Front Load Dryer...
Why does my car just turn over but wont start
A suggestion would be to check your fuel filter to make sure it is not stopped up. Your fuse to the fuel pump may also need to be checked. Chevys are notorius for bad fuel pumps.
Jun 03, 2014 | aFe 2001 Chevy Cavalier - 2.4L 4-cyl....
My display is blank
The front panel (LED) panel needs to be replaced. Depending on where you are, you may be able to send to a local person to repair. The home office/factory offers a trade in at this time or a flat rate of repair depending on which unit you have. I'm happy to help you further. Message me on my site.
Vollara Home
Mar 27, 2014 | Ecoquest Fresh Air Air Purifier
It doesn't turn back on when I put the water catcher in it and I found this piece for it and I don't know where it goes.
I don't know the final solution but do want to brainstorm with you so you are not alone in the fixing process....
White Westinghouse Dehumidifier - Model Number >>> ????
http://www.searspartsdirect.com/partsdirect/brands-products/White-westinghouse-Parts/Dehumidifier-Parts
Sears is your friend here. They often have blow-up diagrams of how these units work. Just find your model number and look at the parts diagram if you can find it. 9/10 Sears has given me the answer through their online manuals.
Post your answer if you've figured it out.
Feb 10, 2013 | Air Purifiers
My professional series ionic breeze gp s1830/961 will not turn on
if it does not power up, then it means its having a power problem. it might have worked fine in the past, but that's electronics for you. Power surge, irregular power supply, excess power supply, etc can affect the unit thereby not making it to power on.
This unit must have a power supply board in it where power enters from the mains. A capacitor, fuse, diode, etc may have been defective on the power board and maybe that's why its not making the unit turn on. There might also be some disconnection or something, inside the unit which is not making it to power on.
To actually find out what's wrong, you need to disassemble the unit with a screw driver and check what's wrong. You will be needing a meter in order to test the components on the power board, once you detect any bad component, you can make necessary replacement at any electronics accessories store withing our vicinity. This is the only way by which you can detect the problem.
Of course, testing the power board with a meter will require someone that has the ability. So it you can't, then you might be needing the help of a repairman or you can call a friend that has the ability to help you out.
I wish you the best of luck.
Regards.
Nov 17, 2011 | Sharper Image Air Purifiers
My freshair 2.0 turns on and right back off. the screen lights up and then goes out.
The most common reason for surging or changing power levels is a loose connection somewhere.
1) Make sure the plug in the back is inserted firmly and the wall socket is live. The wall socket should not be powering a high-use appliance such as a furnace or refrigerator.
2) Make sure the plate is inserted firmly and correctly in the top and bottom "tracks" inside the machine. The metal contact fingers should be pressing firmly and evenly on both sides of the plate, in the metal screen area.
3) Inspect the interior of the machine, looking for loose wires, corroded clips, any broken wires or connections. (You or a handy friend may be able to repair the loose wires or clips; it's a pretty basic fix.)
If none of these troubleshooting steps solve the problem, the problem may be in the computerized system. For that, you'll need to get in touch with Vollara (formerly EcoQuest) customer service. 800-989-2299.
Jan 11, 2011 | Ecoquest Fresh Air Air Purifier
Hi, i need help because i really like the brother my friend
talk to her if anything see him outside of the house get his number have him hangout away from the house stop making urself feel dull if he likes u too he will tell u and sweety if she dont want u at her house theres a clue she dont want u dating her brother
Jan 25, 2010 | Love-Less Loveless Ash MU405 Cougar Quiet...
Living Air XL 15, no ozone
My XL-15 had the same problem a few years ago. I had a broken wire on the fan, and the Ozone problem turned out to be a problem with the power supply. I had to send it in to have it repaired.
Mar 18, 2008 | Ecoquest Living Air Classic Air Purifier
Air Purifiers Logo
19 people viewed this question
Top Air Purifiers Experts
Are you an Air Purifier Expert? Answer questions, earn points and help others
