Question about Acomdata (HD320UFAPE5-72) (HD320UFAPE572) 320 GB Hard Drive
Help installing the hard drive...
Everything on the drive's been hooked up, but the startup screen never loads and I can't install the drive. The light on the drive stays red. What should I do?
  • Martin Noel Mar 03, 2008
    light stays in blinking mode [red/blue] like it contimually reading; does not feel like it is powering up properly [no heat on drive]. PC does not recognize device, of course. Any ideas?
    Thanks.in advance...
  • Anonymous May 04, 2008
    yes
    Problem Solver:
  • 15 Answers
REMOVE THE DRIVE FOM THE ENCLOSURE AND TRY TO DETECT IT TO A DESKTOP COMPUTER SEE IF DESKTOP COMPUTER WILL DETECT IT IF WON T HARDISK NEED REPLACEMENT
Posted on Aug 27, 2007
SOURCE:
Failed Windows XP Setup
sounds like a bad hard drive or it has bad sectors.hard drive regenerator software may help
Jun 25, 2017 | Computers & Internet
Acer aspire 5733z not working
Go to the BIOS configuration screen and tell the computer to boot from the DVD first, and hard drive second. Look for the "Repair Install" option n the install CD startup screen. If that doesn't work, you can at least start over with the installation.
I hope you backed up all of the work-related material before you started installation; If not, you may have to make a Linux trial/install memory stick and use it to copy your Documents folder to an external hard drive. Post a request for info on this to the comments if you need to do this (for example, if you wind up formatting the hard drive and doing a clean install of Windows 7).
Jul 14, 2017 | Acer Aspire 5733Z 15.6 Inch Laptop Intel...
Cant load roxio 2011 code error oood plaese tell me what to do its been 6hrs now cleaned everything please please
Please refer to the steps below and follow it carefully as it will help you resolving the problem.
  1. Disable your startup applications using MSCONFIG. This will disable any unnecessary background or system tray applications from loading.
    • Go to Start -> Run. Type "msconfig" (without quotes) then click OK.
    • Select the Startup tab.
    • Click the Disable All button.
    • Click the Apply button, then click the OK button.
    • Click the Restart button.
    To reverse this at the end of installation, go back into MSCONFIG and select Enable All and restart (that can be done once installation is complete).
  2. If you are installing from a physical disc, please try to copy the content of the disc to a folder on your hard drive then install from the hard drive. To do this:
    • Create a new folder on your Desktop.
    • Go to Start -> My Computer, then right-click on the Creator installer disc and select Explore.
    • Select ALL of the files in the installer window and copy to the folder you just created.
    • To install from the folder, double click the setup.exe file.
  3. If you are installing from downloaded files, please follow the steps below to delete the temporary files then try to reinstall again.
    • Go to Start -> Run. Type "%temp%" (without quotes) then click OK. The Temp folder will show up.
    • Go to Edit -> Select All.
    • Go to File -> Delete.
    • Reinstall software
Jan 06, 2011 | Roxio Creator 2011
Computer may or may not start up. When it does, it may or may ..
Go with a known good working hard drive, its the easiest thing to replace and instead of reimaging it, install windows from scratch and then load the drivers for whatever it doesnt find and then see how it runs, if the lockups stop happeneing then load the apps that you want and everything should be okay.
Jun 26, 2009 | HP Computers & Internet
Laptop not booting up after XP install
Can you press f10 to get to the HP recovery screens?
May 28, 2009 | Seagate FreeAgent Go 250 GB USB 2.0 Hard...
Set up did not find any hard disk drivers installed on computer
Your notebook has SATA hdd. Got into the bios (keep pressing F2 key on startup) then in the bios screen find HDD and press enter. Select IDE mode. Press f10 to save changes and exit. When this is done install XP.
Alternatively connect external usb floppy drive and unzip sata drivers into that. When booting from xp cd press f6 to load drivers.Follow onscreen instructions to load drivers and continue xp installation.
Please let me know if issue not solved for futher ts steps.
thanx
May 28, 2009 | Fujitsu LIFEBOOK P1510D Tablet PC
Dell Inspiron 1501 - tries to boot
Go into your BIOS by pressing F2 and make sure the cd drive is the first boot device. Install the operating system cd first and go thru that. Then you'll need to install the drivers and utilities disk. After that you can put the applications cd in and choose what programs you want to install off of that.
Thats the order you should install the cd's. Assuming your hard drive is good then everything should go thru. If you need more help then let me know and I'll help you as much as I can. I'll be here for a while.
When you boot up off of the operating system cd. It will say press any key to boot up off of the cd, be sure to do that so it boots up off of the cd and goes into the system setup.
May 26, 2009 | Dell Inspiron 1501 Notebook
Macbook just won't start
If you have the mac os install cd, try physically taking out the hard drive from your battery bay (http://www.youtube.com/watch?v=8c6ckjy-gdY) close up the bay and turn on your mac without the hard drive in place, while the chime is heard press and hold the alt/option key to get a list of bootable devices, ie. the install cd. Select the cd when the cd loads, go to the menu at the top and select startup disk, follow instructins to get your computer to atomatically start from the cd on next restart.
Select the restart option by cancelling th install.
AFTER THE COMPUTER SHUTS OFF IT WILL RESTART, DO NOT LET IT RESTART, TURN IT BACK OFF IMMEDIATELY.
Now take out the battery-bay again and put the hard drive back in. Put everything back together and turn the computer on again. This time it should automatically load the install cd if it is stil in the drive. When it loads the installation you should be able to find a way to either use disk repair to put a startup image back on the hard drive or completely reinstall the OS on the hard drive (which it will recognize now)..
If yu have any other questions let me know i can give you a more detailed explanation if necessary
Sep 05, 2008 | Apple MacBook 13"White /2.0Ghz Intel Core2...
Installing XP on a dell computer
try to go to bios and load bios defaults, esc then save and exit. boot from the cdrom by, tapping on F12 at dell screen. at boot menu screen, choose cdrom, press enter, when you see the message, PRESS ANY KEY T5O BOOT TO CDROM, hit any immediately, that should allow you to install xp directly from the cdrom.
Feb 13, 2008 | Dell Dimension 4600 PC Desktop
Acomdata (HD320UFAPE5-72) (HD320UFAPE572) 320 GB Hard Drive Logo
125 people viewed this question
Top Acomdata Computers & Internet Experts
Ekse
Joe Goldman
Joe Goldman
Are you an Acomdata Computer and Internet Expert? Answer questions, earn points and help others
