Question about Drills
Startrite mercury Drill Manual - Drills
I am looking for a user manual for a Ram Machinery drill press model no. 0019B. Thank you
go google and type in ---user manual for ram drill press-- and download ant pdf versions
remember that many brands of drill press are all made in the one factory with just a different name so any drill press that has the same drill head operation will probably have the same user manual if you cannot find what you want
Sep 18, 2016 | Drills
Is there a repair manual to replace timing cover of 1997 mercury mountaineer?
Repair manuals are available at any auto parts store and some libraries.
Jul 04, 2016 | Mercury Cars & Trucks
Startrite super 260 combination woodworking machine dose anyone know where i can get a new drive wheel or rubber for the thicknesser.
http://www.tphmachinetools.co.uk/prodinfo.php?catcode=60&typecode=70&sizecode=00&uniqcode=6375&machine=U
Apr 27, 2015 | Crafts & Hobbies
2001 Mercury Grand Marquis the transmission torque converter doesn't have a drain plug. I want to drill a hole for a drain plug. Is there a perfect place to drill the hole ?
If it was me Id just get as much out as you can and go from there,not a hole lot in torque con. and you might be getting into something you don't want to,draining the trans will be enough to get your fluid back into good quality and changing filter,and with every trans change I put a pint of lucas with the change! good stuff!
Dec 14, 2014 | 2001 Mercury Grand Marquis
How do I remove ignition switch without a key? 1985 mercury marquis
you need a steering wheel puller, take off the steering wheel, then you'll see it's obvious
Jul 19, 2013 | Cars & Trucks
What to do if water pump bolt breaks,97 mercury mountaineer
You have to drill the remainder of the bolt out of the hole. Start by taking a center punch and punch the dead center of the piece stuck in the hole, then take a small drill bit and get to work on the punch hole. Use a little wd40 on the bit to keep it from overheating and go about half speed on the drill (time consuming prosses). After you drilled deep enough grab the next size bit and continue to do this until you can fit a good size extracter in the hole to pull it out. If you do not have an extracter then continue to drill untill the bolt is completly out then retap new treads and find an oversized bolt.
Sep 14, 2011 | 1997 Mercury Mountaineer
Electric window assembly removal
assume you mean window motor.
remove trim panel. long screws (2) AT ARM REST. dRILL 3/8 INCH HOLES (3) AT THE DIMPLES in the inner panel, for access to the 3 bolts holding the motor in.
from 1994 manual.
Removal
  1. If front door window glass (21410) is in the down position and is inoperable, the following steps must be taken; if front door window glass is operational, proceed to Step 2.
    1. Remove front door trim panel (23942) and front door trim shield (237A04). Refer to Section 01-05 .
    1. Mark inner door panel and drill three holes 12.7mm (0.5 inch) as shown.
Oct 28, 2010 | 1992 Mercury Grand Marquis
It's a startrite super 260 combernation machine i am unable to work out how to tighten the drive belts for the saw unit i have taken the machine apart but can not find any ajustmant points are you able to...
Hi Steve there is a screw above the height adjuster if you need a manual i can email you one I have a problem with mine that you may be able to help with regarding capacitor size if you could look for me let me know doggone1@hotmail.com
Jun 13, 2009 | Saws
I lost my keys and i need to know how to replace my key cylinder on my 1993 mercury cougar xr7. I have a new one.
remove screws from steering colum and remove cover,
you will need a drill, needle nose plyers and a very small screw driver phillips.
step one. drill 1" into cylinder.
located on bottom of colum is a small hole with a pin in it.
step 2, push pin up, if it does not move drill 1/2" more in to cylinder.
stop if you reach a small shaft that is kinda loose and has a brass washer or steel washer on the outside of it. remove small shaft with plyers. once the cylinder is drilled it should unlock, turn it and push the pin up untill it comes out
May 16, 2009 | 1993 Mercury Cougar
Drills Logo
79 people viewed this question
Top Drills Experts
Are you a Drill Expert? Answer questions, earn points and help others
