Question about Whirlpool Duet GHW9150P Front Load Washer
Flashing F2 I just bought this washer and dryer 3 weeks ago and now these last couple of times its been flashing F28 what does that mean and how can I fix it?
    Top Expert:
  • Whirlpool Master
  • 12,223 Answers
See the details and fix it. God bless you
If the drain time exceeds 8 minutes, the water valves are turned off and F02 is flashed.
Press PAUSE/CANCEL twice to clear the display.
NOTE: After 4 minutes the "Sud" error will be displayed, then 4 minutes later the F02 error code will be displayed.
Potential Causes
• Check the drain hose and make sure it is not plugged or kinked
• Check the electrical connections at the pump and make sure the pump is running.
•check the drain filter pumpfor foreign objects
• If the above does not correct the problem replace the pump
Posted on Jul 10, 2013
canbruce75
  • 1776 Answers
SOURCE: My Cabrio dryer is flashing f1. What does this
This is from a service bulletin. This may be of interest to you. There have been many problems with these machines in this area. Anyway, I sympathize and hope this helps. Best wishes.
CORRECTION:
HE Top Load Washers
Models:
F1 Error Code
WTW6200S WTW6300S WTW6400S WTW6600S WTW6700T
MTW6300T MTW6400T MTW6500T MTW6600T MTW6700T
Serial Numbers: CT01 – CU52
There are four areas of concern that can cause the F1 Error Code. Each area must be sequentially addressed to ensure
that the diagnosis is correct and the proper repair is completed.
A) Air leaks in the air pressure (switch/sensor) hose.
a. Inspect the hose for cracks, pin-holes or loose connection.
b. Replace the hose and harness assembly (W10058730) if it is compromised.
B) Moisture in the air pressure (switch/sensor) hose.
a. Inspect the hose for evidence of water.
b. Replace the hose and harness assembly (W10058730) if water is detected.
C) Lint or flashing in the air dome hose connection port.
a. Inspect the air dome hose connection port for lint or flashing.
b. Use a small round device (small screwdriver) to ensure that there is nothing blocking the air dome outlet on
the tub.
D) The control needs to be replaced.
a. Replace the control only after you have completed steps A – C above, and verified that there are no issues
with the air pressure system.
Comments: - I don't know what satifaction they will give you, but you could contact Whirlpool. I don't know if it's fact, but some folks with this problem said that they were able to get the cost of repair covered in some cases, while others complained that they got no proper assistance from the manufacturer at all, so I really don't know for sure what good it will do, but it's worth a try. I'm sorry for your trouble and hope you find a good resolution to your problem. Best of luck and best wishes.
Posted on Sep 10, 2009
  • 220 Answers
SOURCE: What id a F28 code on a whirlpool duet washer
Can be the machine control or the motor control here is a link to the Repair manual....
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/6545d78b3f479480852571650061b1ba/$FILE/8178558.pdf
Posted on Sep 13, 2009
localwonder
  • 6784 Answers
SOURCE: washer giving F2 error during wash cycle, cycle doesnt finish
HI. this code represents a Long Drain issue.
NOTE: After 4 minutes the “Sud” error will be displayed, then 4 minutes later the F02 error code will be displayed.
Potential Causes
• Check the drain pump filter for foreign objects
Posted on Oct 26, 2009
techbuster
  • 5081 Answers
SOURCE: I washed a large load in our Whirlpood Duet
The error code F28 means one or both of these parts are bad.
Motor Control Unit (8540135)
Microcomputer Machine Control Unit (8540788)
It would be a good idea to order both, as both components have been problematic for error code F28
If you find either the MCU or the CCU(Microcomputer Machine Control Unit) fixed it.
You can download the online repair manual in the below link
On page# 4-20 it shows how to access your MCU.
Posted on Jun 27, 2010
blueextc3221
  • 15935 Answers
SOURCE: WHIRLPOOL DUET SPORT WASHER FLASH FAULT CODE F28
F28 is a serial bus error from the CCU (Central Control Unit) to the MCU (Motor Control Unit).
All you need is some Electronics contact cleaner spray and a 1/4 inch socket to remove the top of the machine and the back of the machine.
The CCU is the computer looking box at the top front right hand corner.
Find connector M13, (has red marking on it and only 3 wires) disconnect it by pushing the retainer tab back and pulling gently on the connector.
Spray the contacts of the connector and computer with connector cleaner.
Then re-assemble connector.
The MCU is in the back lower left corner.
Find the connector with 3 wires and red mark, and remove this connector in the same way you did the other, spray it and re-install.
Put the back and top back on.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question&&&&
Posted on Sep 28, 2010
Its flashing f28 and lock i have something in the washer also this is only my secind time using it i unpluged it and its still doin it
If your washer is a Kenmore The F28 error code on this model of washer indicates a communication error between the motor control unit and the computer circuit unit that results in the washer stopping during a cycle.
Read more: How to Unlock a Kenmore Washer HE2 Code F28 ' eHow.com http://www.ehow.com/how_7727221_unlock-washer-he2-code-f28.html#ixzz1GUHtruhM
Mar 13, 2011 | Washing Machines
I washed a large load in our Whirlpood Duet Washing Machine and it stopped with a flashing F28 code. I unplugged it for 5 minutes and it still will not run a cycle without stopping with a flashing F28...
Jun 27, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Sunbeam Queen Size Electric Blanket Flashing F2
it means there is some sort of problem somewhere with your blanket .
Oct 08, 2009 | Kitchen Appliances - Others
HE2 front loadable washer doesn't move fm wash to rinse to drain
Sounds like the door lock. It will not advance to spin if it thinks the door is open. There is a instruction sheet inside the unit behind the lower panel. That will give the error codes for the flashing lights.
Sep 04, 2009 | Kenmore Elite 45986 Front Load Washer
Oil light flashing, last oil change 7 wks ago
I belive they didn't reset the oil light timer. I belive the sequence is 1. key on (not acc with engine off)
2. step on the brake pedal 5 times within 10 seconds. 3. key off. 4. start car. 5. check if the light went out. you may have to try it a few times to get it.
Jun 25, 2009 | 2003 Pontiac Grand Am
Whirlpool front loading washer and dryer F28 keeps coming up
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question####
Mar 17, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question!!!!
Jan 18, 2009 | Whirlpool Duet GHW9150P Front Load Washer
F2 flashing on display screen washer won't continue cycle????
This means that the drain time has exceeded 8 minutes and the water valves have turned off. After 4 minutes the suds error is displayed then 4 minutes later the F2 error.
Potential causes
1.Check drain hose for kinks or cloggs
2.Check electrical connection at the pump and make sure the pump runs.
3.Check inside of pump for foreign objects
4.If none of the above fixes the machine replace the pump.
Oct 12, 2008 | Kenmore 46462 Front Load Washer
Sound, but no picture. Standby light blinking 5 times
A few weeks ago my set started flashing to a black screen. Now a couple of weeks later, i have no picture, but the set turns on and i have sound. The standby light is flashing. I purchased the set in 2000 so it is seven years old. This is the first problem. Could it be all three of the bulbs? Could it be all three of the bulbs? no as you say that sound is ok that means your power supply &high voltage section is ok. please check chroma ic luminance section or system control section stand by ckt ihanks
Sep 11, 2007 | Sony KP-53HS10 TV
Whirlpool Duet GHW9150P Front Load Washer Logo
54 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
