Question about Thule 2012 Toyota Tacoma - Double cab - Xsporter Truck Rack
P1604 WHAT DOES THIS MEAN - Thule 2012 Toyota Tacoma - Double cab - Xsporter Truck Rack
Toyota senna 2011 code P 1603,P1604,P1605 car not star
These codes are indicating a starting problem and rough idling. Code p1604 is a very vague code and diagnosing it without having a symptom is very complicated. And code p1605 is rough idling which means that the computer have noticed a rough idle situation usually this code is accompanied by other codes or if it's alone then I would suspect a fuel pressure issue. These two codes involve diagnosis and we'll need to dig into this problem deeper to find out what's causing them, Unless you are an experienced technician who need assistance then I will suggest that you take your vehicle to your local toyota dealership and they should be able to find the problem.
p1603 should help by reading this below
http://corolla-club.ru/doc1/c61151d7ba7b9bee3c247e42b685b253.html
Feb 12, 2016 | Toyota Cars & Trucks
Showing code 1604 what does this mean?
In order for me to help u I need to know is it a po1604 or p1604 and I need to know what car or engine then I can tell you right away
Sep 10, 2015 | 2002 Dodge Stratus
Not starting,we diagones fault code p1604
P1604 is startabilty malfunction
check:
1.starting system
2.glow system
3.fuel system
Mar 20, 2015 | 2010 Toyota Fortuner 3.0D-4D
Toyota d4d fortuner not starting fault code p1604
For a Toyota, it indicates a startability problem, it is a very vague diagnostic troubleshoot code and therefore not component specific.
Components to check, Crank Shaft Position sensor, Spark Plugs, MAF sensor, fuel pump... etc.
My Toyota fortuner not starting,when we diagnose it shows us p1604 fault code
code p1604 refers to starting system --malfunction===causes--wiring---connections--vacuum leaks--MAF sensor--ignition system--engine coolant temperature sensor--fuel supply system--throttle body--variable valve timing system---A/C system--- power steering control control--- ECM
Try to think back to the symptoms before the engine failed to start
were you in snow, did it get hot, was it lagging in high rpms,
did it just stop or was it misfiring
each symptom will point to an item in the list of causes.
Mar 20, 2015 | Toyota Fortuner Cars & Trucks
P1604 startabili
normally this is just remote battery but check fuseable link in fuse panel and loose connection
Mar 29, 2014 | 2007 Toyota RAV4
P0700/p1603/p1604/po613
fco.lozano, mi carro cirrus 2005 lxi turbo 2.4 triptoni, a veces no entra la tercera c bloquea y nada mas entra segunda lo apago cuando ya esta medio frio lo enciendo y entran bien las velocidades pero c vuelve a calentar pasa lo mismo kien me puede ayudar xfa. gracias
Jul 18, 2012 | 2003 Chrysler PT Cruiser
2001 volvo v70 error code p1604 Cannot drive over 25mph. When the code is cleared runs fine for 20-40 miles then reverts to problem. I found a code match for internal throttle signal but not sure what...
if you look that up on a normal OBD code its listed as P1604 Code Word Unregestered However for a volvo thats a code for Control Module Self Test, Speed Monitoring which would indicate the ECM or a wiring problem ( usually just a loose connection,, so check the connections on the ECM, which you can have scanned by the dealer, Volvo codes vary from the normal coding on most cars, so be careful when getting codes and their meanings
Jul 14, 2011 | 2001 Volvo V70
Thule 2012 Toyota Tacoma - Double cab - Xsporter Truck Rack Logo
282 people viewed this question
Top Thule Boating Experts
Tom Chichester
Kar Volk
Richard Warren
Richard Warren
Are you a Thule Boating Expert? Answer questions, earn points and help others
