Question about CTL Nexus NX3200 Television
No power TV does not turn on. Power cord was disconnect for about five minutes. Power button does not turn on TV.
    New Friend:
What is the proble
Posted on Aug 31, 2013
PANASONIC PLASMA MODEL TYST42PH20 TURN IT ON AND GOES INTO SHUT DOWN
Resetting the TV
If the buttons on the remote AND the buttons on the TV case do not work (channels do not change and you cannot open or navigate the menu), the TV has stopped responding. Reset the TV as follows:
NOTE:
Some TVs have a reset button. If available and accessible, try using the reset buttons before using the steps below. Using the reset buttons can save time.
1. Unplug the TV power cord from the power outlet.
2. Unplug any connected devices (DVD, Set-top boxes, etc...)
3. Press and hold the TV power button for five seconds.
4. Plug the TV power cord back into the power outlet and turn on the TV.
5. Open the on-screen menu to confirm that the TV is responding again.
6. Turn off the TV and reconnect the devices.
7. Turn on the TV.
Aug 05, 2008 | Panasonic Televison & Video
Tv will not turn on
its the power pack in the tv that has gone out...contact the manufacturer for either the part to replace it your self or for a technician to repair it.
Nov 14, 2007 | Toshiba TP50H50 50" Rear Projection...
Sony kp-65wv600 projection tv error code. My tv blinks 7 times.
The Standby LED blinks when the TV is turned on, then shuts off when the picture is displayed. If the LED blinks continuously, this may indicate that the TV requires service. Before getting the TV serviced, try power resetting the TV and factory resetting. Try the below steps also: Connect the TV to a different wall outlet and check if it helps. This is to check if the issue is with the Power. Disconnect the TV from the Power Strip or the Surge Protector and connect it directly to the Wall outlet and check if it helps. To Power Reset the TV, disconnect the Power cord for a short period of time (approximately 1 minute). Then, reconnect the Power cord and power ON the TV. To factory reset the TV, turn it ON. Then while holding down the RESET button on the Remote Control, press the Power button on the TV front panel. The TV will turn OFF and then turn ON again. Then release the RESET button to complete the reset procedure. If the issue persists, service may be required.
Good Luck!!
Nov 09, 2010 | Sony KP-65WV600 65" Rear Projection...
Power went out and when it come back on the tv took a long time to start and the screen was verticle stripes (multi-color)
Check if the issue is with the TV by connecting any other device.
If the issue is with the TV, then try resetting the TV to the factory settings by performing the below steps:
To reset the TV, turn ON the TV, then while holding down the UP ARROW button on the Remote Control, press the Power button on the TV front panel.
The TV will turn OFF and then turn ON again. Then release the UP ARROW button to complete the reset procedure.
If the issue still persists, try Power resetting the TV.
To Reset the TV, please disconnect the power cord for a short period of time (approximately 1 minute). Then, reconnect the power cord and power on the TV.
If the issue still persists, service is required for the TV.
Jul 12, 2010 | Sony Grand WEGA KDF55E2000 55" Projection...
Please tell me how to turn off tamper proof on my Sharp tv/vcr combo without original remote. The remote I have doesn't have a toggle button. Thank You!
As you know, the Tamper Proof function is activated and de-activated holding the Toggle/Source/Input button for about five seconds.
If your universal remote does not have this button (under any name), then try all buttons.
Try also disconnecting power cord for five minutes, this will reset most TV functions.
If still no luck, then you will need a different remote to get rid of the function.
Try all buttons on your remote. If the Tamper Proof had been activated using this remote with this codes, then it can be turned off using the same remote.
Dec 12, 2009 | Sharp VT-G14 14 in. TV/VCR Combo
Hitachi 50vs69a blue oval circle in the center of the screen
Just try to reset HDTV. If available and accessible, try using the reset buttons before using the steps below. Using the reset buttons can save time.
7. Turn on the TV.
Regards:
VOTIT
Jul 08, 2009 | Hitachi 50V500 50 in. HD-Ready LCD...
I loose my picture but i still get sound
Just try to reset so picture will come again, some LCD TVs have a reset button. If available and accessible, try using the reset buttons before using the steps below. Using the reset buttons can save time.
1. Unplug the LCD TV power cord from the power outlet.
3. Press and hold the LCD TV power button for five seconds.
4. Plug the LCD TV power cord back into the power outlet and turn on the TV.
5. Open the on-screen menu to confirm that the LCD TV is responding again.
6. Turn off the LCD TV and reconnect the devices.
7. Turn on the LCD TV.
Hope it may help you;
Regards;
VOTIT
Apr 22, 2009 | LG 42LC2D 42 in. LCD HDTV
Black Spots
Resetting the TV
NOTE:
7. Turn on the TV.
Regards,
VOTIT
Sep 24, 2008 | Mitsubishi WS-55809 55" Rear Projection...
CTL Nexus NX3200 Television Logo
29 people viewed this question
Top CTL Televison & Video Experts
Are you a CTL Televison and Video Expert? Answer questions, earn points and help others
