Question about Fellowes Powershred 420 Shredder
HOW OFTEN AND HOW MUCH OIL DOES THIS SHREDDER REQUIRE?
  • 4 Answers
I have found that the best way to oil the unit is from the top flap(near disk area), which exposes the top of the blades. You must also give the oil spout a shot so the unit "oil light" goes off.As far as how often, monitor the unit and after each heavy workout, give it a top shot along the exposed blades. Get to know your machine and it will treat you right!!
Plz N' Thnx, Bogie
Posted on Sep 20, 2013
Oil for cross-cut shredder
Normally, shredders do not require lubrication.
Apr 11, 2013 | Shredder Secure Shred Shredder
I have the CX6 shredder, the paper get jammed in the feed,can i oil the feed?
How to Oil a Paper Shredder shredder_oil.jpg Paper Shredder OilProper shredder maintenance is required by all paper shredder manufacturers to maintain warranty coverage. Perhaps the most effective way to care for your shredder is to oil the cutting heads regularly. Why should I Oil my Paper Shredder?
The frequency of shredder oil applications is determined by a number of factors. First of all cross cut shredders must be oiled more often than strip cut shredders do. A cross cut paper shredder will require regular applications of shredder oil while a strip cut can go for a longer period of time without decreased performance. Secondly, paper shredders that are used more will need more lubrication. A paper shredder under heavy usage will need oil about once every four hours, while one under normal use will only require oil once or twice a month. Most manufacturers recommend oiling the cutters once every 30 minutes of accumulative shredding, but an easy way to remember is just to oil your paper shredder every time you change the bag. The type of material as well as amounts fed at once can also effect performance and lead to the need for oil.
Directions
You should only use specifically designed shredder oil to oil your paper shredder. This oil is designed to lubricate precision heat treated shredder cylinders, and any other lubricant or oil will void the manufacturers warranty. So don't use WD-40 or the like to oil your paper shredder.
Shredder oil can come in both liquid and aerosol varieties. However, the most common is liquid shredder oil.
The first way to oil your shredder is to spray or squirt lubricant into the opening and onto the cutting heads. The oil is packaged in a squeeze bottle and is applied directly onto the cutting head in a fine stream. This is done through the paper entry throat. Take 1-2 seconds to oil from one side of the opening to the other. Turn the machine in reverse for about 10-15 seconds to allow the oil to transfer to all parts of the cutting head. The final step is to shred a few sheets of paper to remove any excess oil.
The other, and perhaps most common, way to oil your paper shredder is illustrated in the image above. Simply spread a small amount of shredder oil onto a piece of paper in a zig-zag type motion. Make sure that you spread the oil over the entire sheet. (NOTE: you don't need to soak the paper in oil, just ensure total and even coverage.) Feed this sheet through the shredder and then operate the machine in the reverse mode for a few seconds. This will make sure the oil is dispersed throughout the shredders cutting cylinders. The final step is to shred a few sheets of paper to remove any excess oil. You may want to repeat this procedure depending on the results, and is recommended for up to three applications to be assured of thorough oiling.
You should oil your cross cut shredder on a regular basis. If you are shredding a small quantity such as only 50 sheets a week or if you are using a small shredder, then you should oil your shredder every other day. If you are shredding a large quantity such as hundreds of sheets, then oil after 30 minutes of usage or after you empty the bag.
Start oiling your paper shredder now. The shredder will run smoother, faster, and put less strain on the overall motor, gears, and bearings.
Oct 03, 2011 | Office Equipment & Supplies
Have a tech solutions 4500. how do you lubricate it?
  1. Cross cut shredders require more frequent oiling versus the straight strip shredders. The more paper and use it gets the more oil it requires. A good rule of thumb is to oil the machine each time you change the bag.
  2. Use only shredder oil designed for the specific brand of paper shredder you have. Manufacturers design paper shredder oils to be heat tolerant for the cylinders and blades, and they calibrate them specifically for their machines.
  3. Spray, squirt or run a bead of oil across the blade opening. It shouldn't take more than a second or two to reach from one end to the other. Any more than that may result in too much oil applied. Quicker than that means there isn't enough oil to adequately lubricate the machine.
  4. Turn the paper shredder to "Manual" and run the gears in reverse for a few seconds, then turn the shredder on "Forward" or "Standard" mode. This ensures that you distribute the oil throughout the machine, and going in reverse first forces some of the dripping oil back up, and then the forward moving blades push it back through the gears.
  5. Oil a sheet of paper rather than the machine. Don't just run a bead of oil across the bottom of the sheet because the paper soaks up the oil and the oil may not reach all of the necessary parts. Instead, spray the whole sheet, or run a zigzag line across the paper and immediately send it through the shredder to oil it.
Jan 28, 2011 | Tech Solution TS-4500 Shredder
Should the shredder ever be oiled? if so...where
Directions
Dec 16, 2010 | Office Equipment & Supplies
This shredder overheats after 1 to 2 thin weight sheets of paper. Says it does up to 10 sheets but can not handle more then 1 sheet at a time. I have cleaned and cleaned the cutters with no improovement
Have you "oiled" the machine ever.????
Cross-cut shredders require occasional oiling with "shredder oil" to help clear out debris that is made in the shredding process from the cutting mechanism. Get some shredder oil and pour it directly across the cutting blades where you insert the paper... this should help...the occassionaly pour some oil onto a sheet of the paper to be shredded prior to shredding it.
Oct 28, 2010 | Royal VF1000MX Shredder
Not a problem yet. Does this shredder require any oiling of the components? If so where and how?
Well considering your question about a shredder is posted under "fax machines" you have a problem...if it was/is a shredder then I would suggest that you occassionaly put some shredder oil on a sheet of paper and shred the sheet of paper to get oil into the cutting teeth....but if its a fax machine then oil on the paper will make a real mess if you put it into the fax. So I hope you know what kind of machine you have 'cause I'm not real sure.
Sep 25, 2010 | Office Equipment & Supplies
Shredder struggles to shred paper. Do I need to oil it? It is an SD5X shredder mad in China. Itasca of Illinois is also on it.
MOST STRIP CUT SHREDDERS DO NOT REQUIRE OILING...IF ITS A CROSS-CUT SHREDDER MOST CERTAINLY YOU SHOULD BE PUTTING OIL IN WHERE THE PAPER IS INSERTED.
May 17, 2010 | Office Equipment & Supplies
How do I remove excess EXCESS oil from my shredder? It won't shred.
Asking why you should keep your shredder lubricated is no different than asking why you should change the oil in your car every 3,000 miles. Not only is proper maintenance a requirement to maintain an active warranty, but all mechanical parts need a little oil to help them turn smoothly and to keep them clean. Applying shredder oil to the cutting heads inside a shredder lubricates them so that they efficiently destroy documents sheet after sheet. Fortunately, you will find that taking good care of your shredder is less expensive, faster and easier than caring for your car.
Every time you shred a sheet of paper a fine dust made of tiny paper particles is produced. This dust collects in the cutting assembly of a paper shredder. If allowed to build up, this dust will compact until it completely blocks the smooth turning of the cutting head. Shredder oil will actually break up the compacted dust lodged in the cutting assembly, allowing the parts to move and push out the softened dust.
Shredder oil is specially formulated to eliminate oil residue on the cutting head. Other oils, like WD-40, will attract dust, further clogging the cutters. When lubricating your paper shredder, only use oil specifically designated for shredder use or risk voiding your warranty and further clogging your shredder.
The frequency with which you should oil your shredder depends on several factors: frequency of use, shredder capacity, cut size and type of paper. Your shredder will need more oil the more you use it, the more paper you shred at once and the thicker the paper is that you shred. Also, shredders with smaller shred sizes require extra oil. A 1/4" strip cut shredder used only one to two hours per week will only require a weekly oiling. A cross cut shredder, on the other hand, requires oil after every half hour of use. If you remember to oil your shredder every time you change the bag you'll be in good shape.
There are two fast, easy ways to oil a paper shredder:
The first method involves applying the oil directly to the cutting head. Shredder oil is packaged either in plastic squeeze bottles or aerosol cans, designed for easy application. No tools are required, just aim the bottle directly at the cutting head, through the paper entry point, and apply a fine stream of oil from one end of the cutter to the other. Run the machine in reverse for 10-15 seconds until the entire cutting mechanism is coated. Finally, shred a few pieces of paper to remove any excess oil from the cutters.
The alternative method requires streaming oil onto a piece of paper. Do not soak the sheet in oil, but cover it evenly from edge to edge. Shred the oiled sheet of paper and then run the shredder in reverse for 10-15 seconds to allow the oil to coat the entire cutting mechanism. Finally, shred a few sheets of paper to remove any excess oil from the cutters. In any case, run a couple of sheets of paper through the shredder after oiling to remove excess oil. procedure may be repeated up to three times to ensure proper lubrication.
If you take a few seconds once a week or every time you change your shredder bag to oil the cutting mechanism in your paper shredder, you'll maintain your warranties and keep your shredder running smoothly and efficiently document after document.
click this link directly for more detailed help
---- http://www.howtocleanstuff.net/house/appliances-and-fixtures/how-to-clean-a-shredder/ --------
thanks.please do rate the solution.thank you for using fixya.keep updated.
Sep 22, 2009 | Royal 1280MX Shredder
Can you lube a shredder?
Yes you can lube a shredder. The larger one require lube of the cutter blades pretty simple just oil in where the paper goes. Smaller ones generally don't mention lubrication because they are considered throw away.
Mar 15, 2009 | Royal Cross-cut Shredder
Fellowes Powershred 420 Shredder Logo
74 people viewed this question
Top Fellowes Office Equipment & Supplies Experts
CheckitRight
CheckitRight
Jim Keysor
Are you a Fellowes Office Equipment and Supply Expert? Answer questions, earn points and help others
