Question about Lexmark T632 Laser Printer
933 error printhead - Lexmark T632 Laser Printer
4 Suggested Answers
  • 85 Answers
SOURCE: optra t610 error 935/933/934
replace printhead - scanner assembly. The scanner motor is not working correctly. Need to remove side covers, back of printer assembly, the top cover. Printhead is below the top cover
Posted on Mar 13, 2009
don_farr
  • 1011 Answers
SOURCE: Lexmark T630 has a 933 error. I have replaced the
933 - Mirror Motor - Locks/Lost Hsync* (*Horizontal Sync) Have you gone through this exercise yet: These errors usually indicate a failure in the HYSNC signal to the printhead. Check the continuity of the cables connected to J5 and J4 on the system board. If incorrect, replace the defective cable. The voltage at J4-1 measures approximately +5 V dc. If incorrect, replace the system board. The voltage at J5-7 measures approximately +24 V dc. If incorrect, replace the system board. If correct, replace the printhead assembly. Don
Posted on Jun 07, 2009
mariolands
  • 2296 Answers
SOURCE: I have an error on
Printhead error message indicates that the printhead (laser scanner) unit inside the printer is not working correctly.
First step trying to fix this is to turn printer off, and back on after 10 seconds. If this won't clear it, try and plug the printer in a different power point straight into the wall. If the error does not clear, the printer will probably require service to correct the issue.
Posted on Nov 16, 2010
Printerhead error 933.00 what can I do to fix it??????
933 error is the high sycn failure on printhead you can strip printhead down and clean all mirrors whilst stripped try the mirror motor to see if it spins ok if not i am afraid its a new printhead. to get to printhead left and righ covers need removing take screw out of each side of top cover and remove carfully to get left cover off redrive has to be removed and screw top of frame undone and screw inside where toner is.
Sep 06, 2011 | Lexmark T644 Laser Printer
933 SERVICE PRINTHEAD ERROR
sounds like you'll be replaceing the laser printhead... not sure what model or anything so this is all I can tell you... get paid to
Jul 29, 2011 | Office Equipment & Supplies
What does this mean and how do we correct it? 933 printhead error
It means that there is a problem with the printhead(s). For more specifics your will need to post the exact model of printer.
Thanks, Jim
Feb 22, 2011 | Office Equipment & Supplies
I have an error on my Lexmark T632 printer saying 933 service printhead error, can you tell me what this means
Sep 28, 2010 | Lexmark Optra T610 Laser Printer
Error message 933 service printhead error
f the printer continues to post a 930 Printhead Error, it thinks the wrong printhead unit is installed.
  • If the printer was recently serviced, make sure the correct parts were used. This is especially true if the parts replaced were either the printhead unit or the printer's engine/system board. It is in one of these two parts that the printer is detecting the problem. Note: If you are the person repairing such a printer, please be aware that parts from different, though similar, printer models may not be compatible with this printer. Also make sure to check the laser cable going from the printer's engine board to the printhead unit, as it reads that signal.
  • If the printer was not recently serviced before this error occurred and powering the printer off and on does not help, the printhead unit and possibly the laser cable or the engine/system board to this printer may need to be replaced.
Mar 03, 2010 | IBM Infoprint 1352 Laser Printer
PRINT HEAD ERROR
there are several different printhead errors 931 933 scanner motor died scanners bad. 932 934 935 are loose lock errors these can be caused by either the scanner or the engine board
Nov 09, 2009 | Lexmark Optra T614 Laser Printer
Apr 30, 2009 | Lexmark T632 Laser Printer
Optra t610 error 935/933/934
Jan 03, 2009 | Lexmark Optra T610 Laser Printer
Lexmark T632 Laser Printer Logo
29 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Roopesh S
Roopesh S
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
