Question about Trek Mystic 20
Trek mystic 20 handlebar assembly
How to raise handelbar
3 Suggested Answers
SOURCE: Raise handlebars up 1"
Yeah, you'll most likely need to get a new stem with the rise. You can also get handlebars that have a rise to them. If your steering tube has space you can add some spacers under the stem but that seems pretty uncommon for a bike shop to assemble a bike with excess spacers on top of the stem.
Posted on Aug 27, 2012
jerry_kramer
  • 3904 Answers
SOURCE: raise handlebars
There is a bolt on the top of the goose neck that hold the handlebars in place. It should be a 1/2 inch, some are metric so just find the right size. Loosen this bolt about a half inch to an inch. It will be sticking up out of the neck. Tap it in with a hammer, it will go loose. Now just raise the handle bars where you want them and re tighten the bolt.
Posted on Oct 07, 2012
Raising handlebars
There is a single central connection to the handlebars This is called the "gooseneck". (Ther handlebars slide through the goosenect and then the gooseneck is tightened to hold the handlebars. The connector to tighten is in the front (so you do not get "injured" if you have a collison). Loosten the connector (it may be allen, or perhaps hex nut.). Raise or adjust the handlebars, then tighten. Make sure it is really tight (do not strip the threads). The handlebar has serrations to lock on to the gooseneck so the handlebar - gooseneck bolt will have to be loosened quite a bit to allow the serrations to "jump" to the next serration.
Sep 20, 2014 | Trek 7100
Lowering handlebar height on 2014 specialized secteur sport
You have two methods. You can remove spacers to drop bar assembly or you can buy zero rise stem. Alternatively you can buy or swop for deeper drop bar if you ride on hooks a lot.
May 28, 2014 | Trek 7.5 FX
Raising handle bars
Should be a set screw or release on the frame where the handlebar stem inserts into the frame. Lossen the connection and with a friend if necessary push down on the frame and pull up on the handelbars to rise the stem. You might need to spray some lubricant where the stem fits into the frame.
Apr 15, 2014 | Raleigh M80
Aug 12, 2012 | Trek 7.5 FX
Raise handlebars
Raising handelbar
http://www.sheldonbrown.com/handsup.html
A major limitation is the steerer tube length. No matter how many times you cut a steerer
tube it won't get longer.
Getting Riser Bars or simply flipping the stem over or getting one with a different rise and
reach might give you the added height you need. If you LIKE the handlebars, the stem is the
best and least-invasive option as most new ones come with front loaders (detachable front
caps) that allow replacement without stripping components off one side of the handlebar. In
minutes a Bicycle Shop could swap any number of them onto your bike for you to try.
If you had purchased the bike at a reputable Bicycle Shop they would have fit the bike to you
before you took it home.
Jul 10, 2011 | Gary Fisher Precaliber 20
How to raise the handlebars on a 20" Huffy Rock It
Usually there is a hex bolt or some kind of bolt in the handlebar stem.
Loosen the bolt 4-5-6 turns.
Bolt will move upward.
Then hit bolt down with wrench.
Handlebars should be loose.
Raise handlebars to position.
Hold bolt upward with fingers while tightening.
Dec 25, 2010 | Cycling
Trek Mystic 20 Logo
21 people viewed this question
Top Trek Cycling Experts
Andrew Crawshaw
Level 1 Expert
dante
Are you a Trek Cycling Expert? Answer questions, earn points and help others
