Question about Frymaster Dean H22 Deep Fryer
Frymaster FM345EBLCSD Alarm
Is there a way to program whether or not the alarm will sound when product is done cooking? We have three wells in our fryer and the alarm only sounds on one. I would like to get the other two to sound an alarm.
    Novelist:
  • 75 Answers
Hi, As per our session, No. The sounders are probably bad or may have been hooked up backwards upon reassembly. GCS in KC would be the ones to contact for parts. Thanks for your business. If I can be of any more assistance, let me know. kstfas
Posted on Aug 28, 2007
SOURCE:
I have a Timex T311 clock radio. How do I shut off alarm and radio everyday. As I no longer need to wake in the am.
On the Timex T311, to disable the radio alarm, press the Radio Alarm button once. The Radio Alarm Indicator light should go out and the radio alarm won't sound. If you press the Radio Alarm button once more, the radio alarm will toggle to on and that indicator light will come on. Similarly, press the Buzzer Alarm button once to enable the buzzer alarm and press it again to disable the alarm.
See page 9 of the manual to see the directions to toggle these alarms on and off. The manual is available from Timex Audio on the product page: https://timexaudio.com/support/product/T311/ . The direct link to the manual is https://timexaudio.com/media/uploads/product/files/T311IB57574_35.pdf .
I hope this helps.
Nov 15, 2017 | Timex Audio Players & Recorders
Why doesn't it connect to sensors?
From your description, it seems that the transmitter section of SC-001 is working properly. What you have done to reinstall the system may not be thorough. And it is unclear whether the control panel is not responding to keychain transmitter or sensor or both.
I assume that you have followed the instructions in the manual to clear the zones. Simply unplugging the AC power and removing battery will not clear the zones. Note that sensors can be programmed into zones 1 to 4. Keychain transmitter can be programmed into zone 5 only. There is no LED indication for zone 5.
Secondly, follow the instructions to program the sensor or keychain transmitter to the control panel. The corresponding zone LED will be flashing during programming. There is sound indication as well for successful programming of the device.
If you do not program the sensor or keychain transmitter to the control panel after clearing the zones, the control panel will no longer respond to the device.
The dialer and siren is not cleared on the control panel. They can be cleared only from the dialer or siren itself.
Dec 11, 2015 | Skylink Group Skylink Sc-100 Security...
I have prolem with fire alarm system
I need more information to answer this question, sounds like you might have a ground fault. These are headaches to troubleshoot and it would be best to get a technician on-site to resolve.
Jan 30, 2014 | Sony Home Security
How do u program a new button for time? We have been introduced a new item that only needs to cook for 1 min & 30 seconds & were not sure how to do this. Model # SCFD350GNCS Serial # 0904TS0005
It will depend on which computer configuration you have on your fryers.
You can download this manual from frymaster to help, it contains all programming instructions, just find the computer/controller you have and follow the steps.
Computers Operation Manual from Frymaster.com
Jun 08, 2011 | Frymaster Dean Frymaster/Dean FPEL3 Deep...
Display shows HELP with alarm
The board displays Help with alarm when there no flame on burners during heat demands. Try replacing the gas tanks, gas pressure and volume may be insufficient.
Apr 23, 2011 | Frymaster Dean Kitchen Appliances - Others
I have lost the instruction manual how do i change the setting from miles to kilometers
If you have the model, Ped Alarm - PE319, it doesn't have metric units. Correctly, Brunton sells one model programmed for metric and one with Imperial units. The units are fixed, and no conversion information is programmed into the units. The product web site doesn't come up correctly on my browsers: http://www.brunton.com/product.php?id=45. However a FAQ is available at http://www.brunton.com/faq.php . The manuals are also available here, for the Ped Alarm, click on Instruments and look in the list for that model (followed by .PDF).
I wish I could be of more help.
Oct 30, 2010 | Brunton Digital Pedometer with Alarm
I can't find the alarm clock setting anywhere on my nokia surge phone! is this normal? I've searched everywhere for it, and it just doesn't make sense for there to not be such basic thing... I must have...
hiSelect > Tools > Clock To set a new alarm, open the Alarms tab, and select Options > New alarm. Enter the alarm time, select whether and when the alarm is repeated, and select Done. hope this will work. regards aniruddh
May 28, 2010 | Nokia 6790 Surge Cell Phone
I press the lock door/alarm activation button and
sounds like the remote is not program try programing the remote again
Jul 11, 2009 | Vehicle Parts & Accessories
MayTag Stove Model MES5770AAW
Here are the codes for Maytag Ranges:
MAYTAG
Type "C" and "D" Clocks Range/Stove/Oven Fault Codes Failure
Code
Condition Check/Repair F1 Supervisory relay enable shorted (non-cook mode); sounds alarm and inhibits cook mode if alarm fault monitor is always active in non-cook mode, and requires removal of power until serviced. Usually a bad touch pad or clock assembly (also called the ERC). Replace touchpad or ERC F2 Bake/broil/clean temp runaway alarm; sounds alarm and resets control to non-cook mode when bake/broil/clean temp exceeds programmed limits. Usually means a stuck relay. Electric @ 525F (bake), 640F(broil), 900F(clean)
Gas @ 525F (bake), 640F(broil), 900F(clean) F3 Open temp oven temperature sensor; sounds alarm and inhibits cook mode Replace oven temperature sensor F4 Shorted temp oven temperature sensor; sounds alarm and inhibits cook mode Replace oven temperature sensor F5 Supervisory relay enable open (cook mode); sounds alarm and resets the control to non-cook mode Replace electronic range control (ERC) F5 Missing a/c line cycle detector; displays code (no audible) Unplug appliance for two minutes, should clear problem F7 Function key shorted; too hot at the clock assembly (also called the ERC) or shorted touch pad or clock assembly (also called the ERC) Replace touchpad or ERC F8 Analog/Digital supervisory; sounds alarm to non-cook mode Replace ERC F9 Door latch supervisory (door latched) Unlock door and check switches or clock assembly (also called the ERC) F0 Cancel key supervision Requires the removal of power until serviced. See qualified technician
Dec 04, 2007 | Magic Chef CGS3760 Gas Kitchen Range
Frymaster Dean H22 Deep Fryer Logo
213 people viewed this question
Top Frymaster Dean Kitchen Appliances - Others Experts
Treefrog15
Treefrog15
Paul Carew
Lawrence Oravetz
Are you a Frymaster Dean Kitchen Appliances - Other Expert? Answer questions, earn points and help others
