White vertical line
My TVs has a vertical white line but still has picture on the 2 sides
    Problem Solver:
  • 6 Answers
Typical hardware problem. Open the back and check any plugs is in right position. Otherwise, junk it. :)
Posted on Jul 09, 2013
JoeO700
  • 80 Answers
SOURCE: Vertical lines on screen when viewing
If the lines are there all the time or intermittent but in the same location it is an indication of a bad panel. The panel driver can also be the cause of this symptom. Samsung panels have had issues with the connector that carries the LVDS signals to the panel itself, this is not serious and can be resolved and little cost. Joe Weibel
Posted on Feb 12, 2007
Coldcut
  • 1554 Answers
SOURCE: Philips LCD model 26TA1000, vertical lines and blank white screen with no picture
it would be easier to find it stripped from a damaged set on ebay.
I see several there but need the part number to search
of course you may purchase that and find it to be the lcd driver.hopefully not.
Posted on Feb 18, 2008
  • 1779 Answers
SOURCE: Sharp aquos has green and white vertical lines
You must contact a svc co. This is a upper or lower buffer board problem and possibly a control board. Nothing you have done wrong, it just happened.
Posted on Feb 28, 2009
  • 7 Answers
SOURCE: White, horizontal line in center with vertical striations.
55hdm71 plasma hitachi vertical lins 3 red on right side what do i do?
Posted on Nov 02, 2009
  • 36 Answers
SOURCE: 42 Plasma TV has many vertical lines (stripes)
screen itself would seem to be the problem here
Posted on Feb 15, 2010
How do I fix vertical lines on my TV?
Line Defects On Vizio TV Screens - Vizio TV Help
vizhdtv.com/line-defects-on-vizio-tv-screens/
Aug 26, 2015 - If you see a line on your TV screen it might be the result of several causes. Some might be simple to fix and others may actually require you to replace theTV. Pixels on a TVs display panel are organized in groups of straight vertical lines. ...Notice the line defect above is red but they can be white, green, ...
how to repair vizio lcd tv vertical lines then fail - YouTube
? 17:05
https://www.youtube.com/watch?v=YUKMl7_19gk
Jul 5, 2014 - Uploaded by bam6972
how to repair vizio lcd tv vertical lines then fail ... I do know quite a bit, not everything but I do know my fair share about tvs. this tv needed a new ...
TV Repair Help for Vertical & Horizontal Lines on Your TV ...
? 2:47
https://www.youtube.com/watch?v=b0sI7LB4cZE
Apr 25, 2014 - Uploaded by ShopJimmy.com
TV Repair help with troubleshooting lines on your TV Screen. ... I have Vizio M470SL. My TV has .... Why does my T.V. suck Don't buy Rca T.V..
Jan 19, 2016 | Vizio E480-B2 48" 1080p 60HZ LED HDTV
Tv fell off stand. tv has vertical rainbow lines on right side of screen. how do I get rid of the lines?
Color patches due to strong shock or vibration cannot be eliminated by anyway, to CRT type TVs. Gopakumar Gopalan Google
May 10, 2014 | Proscan Televison & Video
Vizio M420kd vertical thin white line on left of screen pictures have lots of green ghosting
If you've ruled out that the source you're displaying from is good, I would contact vizio for a warranty repair
Jan 24, 2014 | Vizio Televison & Video
My Samsung LN32D403E4D has vertical blue lines flashing in picture, why?
It sounds to be a T'Con broad problem. Check all the flat cable connections in between lcd pane and T'Con board for firmness. Re-seat them once and check. If you wish to get more details about these kind of faults to Samsung LCD model TVs, check this site.
Feb 06, 2013 | Samsung Ln32d403e4d
White vertical lines after changing dlp chip and lamp on Mitsubishi WD-65833. good picture in background.
had white dots on mine as well i changed the dlp chip and put it back together and got the white vertical lines i decided to check all connections and make sure the chip was locked in correctly
it was not locked in securely i reassembled and now problem solved picture looks brand new so always check connections before assuming its the dmd board
Aug 25, 2012 | Mitsubishi WD-65833 65" HDTV
White lines at the top 3-4 inches of the screen.
well its all new now could be bad caps or vertical i.c. okay if you have a esr meter check around the i.c. for a leakey cap good luck
May 13, 2009 | Insignia NS- 27" TV27 TV
Picture has white horizonal line accross it
You have a vertical collapse. Not sure if its worth fixing because i don't know what type of set it is or how old. But vertical is not usually expensive to fix. Possibly just replace vertical ic
Apr 22, 2009 | Televison & Video
White lines across TV screeen
if these lines are just at the top of the picture then i would suspect an electrolytic capacitor in the vertical circuit.
May 08, 2008 | Televison & Video
White vertical line on left side of screen
I had a smililar problem after taking it apart i realised that i had screwed my mount skrews into the video main board and cracked it along with a few soldered wires, if you havent done any physical dammage to it try a firmware upgrade
Jan 20, 2008 | InFocus IN72 Multimedia Projector
Hi there
This problem can only be fixed properly by replacing the Mainboard.
Jan 01, 2008 | BenQ PB6100 Multimedia Projector
Televison & Video Logo
Top Televison & Video Experts
Electro Med Services...
