1. try unplugging or flipping circuit breaker, wait 10 secs, hold in power/on button for 5 secs, plug back in and see if it resets.
or
2. try tapping on door lock position on front of unit and see if it unlocks unit(lock stuck). hit it hard with palm, but not enough to dent or damage
Might now be spinning fast enough for the centrifugal force to expel the water. check the drum speed as well as the pump that removes the water collected.
Mar 17, 2011 - my maytag 5000 series steam washer stopped and said Sud and now says ... Clicking this will make more experts see the question and we will .... I bought aMaytag 3000 seris in 2008 and I am getting these messages: F21 ... Maytag 5000 Series washer F21 error code was flashing and door will not open.
If your towels are coming out the dryest it is probably a problem with it being off balance. Did you make sure that the clothes are even placed in the washer. If you have a bunch of heavy stuff on one side and light stuff on the other side it could cause the same problem.
Below is a list of spreader settings. You may want to call Scotts at 800-543-8873 and verify the product you are using is able to be used in a hand held spreader.
For fine grass seed (blue, rye, fescue) use setting 1
For coarser seed (tall fescue) use setting 2
For light fertilizer (Scotts fertilizers at a regular rate) use setting 3
For heavy fertilizer (Scotts fertilizers at a heavy setting) use setting 4
For pelletized fertilizer and ice melt products use setting 5
