I have a Hisense ap-05cr1suvs that, after draining and plugging it back in, has all lights come on in sequence then shuts off. Any ideas? Troubleshooting in Manual doesn't cover this
I plugged it in, after draining, and it did not beep. I pushed reset button, no beep. I held down power button for a few seconds and it started with each light coming on in sequence, as if testing system. It blew out a bit of air and shut off. I retryed it with same result. Troubleshooting in the manual doesnt mention this. Any ideas?
2 Suggested Answers
  • 30 Answers
SOURCE: My Hisense AP-05CR1SUVS is leaking
hello
you check;1- drain pipe.(blocked)
2-under evaporator case leaking.
Posted on Sep 06, 2011
Kyocera model number c6745 how to reset
Hold down the Power key in order to switch off the cell phone.
In this step press and hold the Volume Down
+ Power button for a few seconds.
You should release held keys when the
Recovery Mode starts.
Afterwards press Volume Down a few timies
to highlight "wipe data/factory reset ", and
then push the Power button to confirm this
option.
Next, select "Yes--delete all user data ". Use
Volume buttons to scroll and Power rocker to
select.
6. When the Recovery Menu appears
on the screen, choose "reboot system now ".
Oct 11, 2016 | Kyocera Cell Phones
Why cant i hard reset my kyocera C6740
1. At the very beginning hold down the Power key in order to switch off the cell phone.
2. Press and hold the Volume Down + Power button for a few seconds
3. You should release held keys when the Recovery Mode starts.
4. Afterwards, press Volume Down a few times to highlight "wipe data/factory reset", and then push the Power button to confirm this option.
5. Next, select "Yes--delete all user data". Use Volume buttons to scroll and Power rocker to select
6. When the Recovery Menu appears once more on the screen, choose "reboot system now".
If this didn't work:
Go to "Settings", then-> "Backup & Reset", after that tap "Factory data reset", choose "Reset phone", and select "Erase everything"
Aug 11, 2016 | Kyocera Cell Phones
Hard reset kyocera c6740n
Press and hold the Volume Down + Power button for a few seconds. You should release held keys when the Recovery Mode starts. Afterwards press Volume Down a few timies to highlight "wipe data/factory reset", and then push the Power button to confirm this option. Next, select "Yes--delete all user data".
Feb 01, 2016 | Kyocera Cell Phones
Plug in hdmi cable and screen is just blank
A reset ought to sort it - turn the power off and on again. Hold down the standby button on the front of the console until you hear 3 loud beeps. It should work then.
May 27, 2014 | Sony Playstation 3 (PS3) Console
I have a sony tv and a ps3 and it will not pick up my ps3 how do i fix it
You can try to reset the video settings on the ps3. If you have had it hooked up to a hd tv it may be defaulted to the HD signal and need to reset the video output to be the right format for your tv. To do this simply hold the power button down when you turn the power on to the ps3. You will press to turn the power on and then keep the button pressed until you hear the unit make a beep (about 3 - 5 seconds) then let go. This resets the video settings to match what the unit is plugged into currently.
You can also try a factory reset, I have that listed below if the video reset fails to fix the issue.
This will wipe all the saved games and data from the machine but I have found it to correct most issues with the ps3.
You will need to push the power button to turn on the unit, but keep the power button held down for about 30 seconds. You will hear a beep (resetting the video settings), then 2 more beeps. After the 3rd beep you can let go of the power button and it should take you to the set up screens like you just got it out of the box.
You will lose everything you have saved doing this but it seems to make the system run just like out of the box again. If this does not fix the problem then it most likely is a hardware issue and may need serviced or replaced.
Feb 26, 2011 | Sony Playstation 3 (PS3) Console
Stops drains and bleeps with only spin light illuminated
It sounds like you need to re programme the
machine.
With the machine plugged into the wall and
turned on and the headset turned off this is what
you do.
Push and hold down the start button, while doing that you need to then push and hold down the power button.
Hold them down for about 5 seconds, during
which time you may a series of up to 3 beeps.
Then release the buttons.
Turn the machine off and then on again followed by the start button. Allow the machine to then run the complete cycle.
This should correct your problem, if this doesn't then you may need to then look at replacing the computer panels.
Jun 13, 2009 | Fisher and Paykel GWL11 Top Load Washer
PS3 Problem... I turned on my ps3 but nothing shows up on the television screen and controls wont even detect... PS3 shows that it is receiving power because the power light on ps3 is green. Can someone...
Turn the power off on the switch on the back, and then back on again. Hold down the power button, keep on holding it down after the first beep, but let go once another couple of beeps sound. It should then take at max a minute but then it should show a screen set up section.
Apr 09, 2009 | Sony Playstation 3 (PS3) Console
Kenmore elite 790.3670 oven door locked
I held down the clear button for three seconds, it unlocked but still showed the lock button lit. It began beeping over and over. I opened the door and pressed the clear button again for three seconds. It stopped and the oven works just fine now. In fact, I used it right after I got it cleared out.
Feb 07, 2008 | Kitchen Ranges
Heating & Cooling Logo
97 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Tim Whalen
Mack Baxter
