Question about Sony KP-53S65 53" Rear Projection Television
My sony tv doesnt turn on.
My Sony Trinitron doesnt turn on. It seems like it is trying to start but no picture. The read blinking lights are four times each. Please let me know [email protected] .Thanks for your help.
  • 1 more comment
  • sharkye46 Aug 30, 2007
    Can you help me of how to replace what is needed? i am pretty good with replacing parts. If you can tell me what part is needed then i can figure out how to replace it. Thanks [email protected]
    Thank you very much for the precaution and lead into solving my prob. Its pretty heavy, if it worth fixing then i'll do it but if it costs too much i wouldnt want to pay for the repair. Thank you again.
  • ap_smih Mar 30, 2008
    I have a very similar problem with my TV. The TV is very slow to start up, then often we only get 4 blinks from the power light. We have discovered banging on he top or side of box will restore picture. Also picture can condense to top of screen, partially lose vertical hold (half height picture) but can be restored with "Tapping" top or side of box". Please advise if this fault is repairable and estimate cost. [Sony Trinitron 32"] Thanks (Andrew [email protected])
    Brigadier General:
  • 6,966 Answers
Hi, The blinking lights is an indicator of an internal fault. On some Sony sets, 4 blinks indicate a problem where the video is muted due to a component fault. Since this involve opening the set and doing electronics diagnosis and possibly component/board replacement, you may be better off seeking the services of a qualified TV repair professional. Hope this be of assistance/idea. Post back should you need further information. Good luck and kind regards.
Posted on Aug 27, 2007
  • Louie  Role
    Louie Role Aug 30, 2007
    Hi again,
    Though I am of the opinion that you best leave it to a qualified TV serviceman, I am posting the information leaving it to you to use as you see it fit.
    It may be to your advantage to get hold of a schematic and/or service manual. Further the usual precaution applies to working with electrical and HV equipment. On opening the unit, do an ocular inspection, look for the obvious, burnt/scorching marks, cracked components, swollen/burst capacitors etc.
    The 4 blinks only goes so far as to tell us where to start, video blanking/muting. This is often caused by a failure in the vertical section - either the output IC (IC1509?) (?LA78045?) or the Vertical Pulse Buffer transistor Q1505? (2SC3311A?). NOTE: Failure in the horizontal/HV will also result in no Vertical B+ supply therefore a virtual vertical failure. The "?" refers to actual component number in some versions/models and may differ from what is in your set.
    It is not a 100% guarantee that replacing the vertical components will solve your problem. As said, H/HV failure can cause the same diagnostic blinks. This can either be the Hout (Q502?) and/or the FBT (T504).
    Lots of luck.
SOURCE:
Sony trinitron kv 32fx68e has 14 blinks. So to switch it on you have to try 20 to 30 times. What can be the problem. Thanks
sony trinitron kv 32fx68e has 14 blinks light. that"s mention tv have bad picture tube. replace it . good luck!
Sep 22, 2012 | Sony FD Trinitron KV-32HV600 32" TV
Sony trinitron 36" has 7 red blinks wont turn on
I HAVE A SONY TRINITRON KV-36HS510. IM HAVING A PROBLEM,ITS NOT SHOWING A PIC, AND BLINKING 7 TIMES THEN PAUSE FOR A COUPLE OF SECONDS THEN IT WILL BLINK 7 MORE TIMES,I CAN HEAR AUDIO BUT CANNOT SEE PIC. COULD YOU PLEASE HELP ME OUT ,I'VE TRIED CUTTING THE TV OFF FOR ABOUT 6 HOURS AND CUTTING IT BACK ON,SAME RESULTS, THANKS
Jan 02, 2011 | Sony FD Trinitron WEGA KV-36HS510 36" TV
I have a Sony Trinitron 32" TV. The picture don't
Hello
Blinking of standby light in Sony sets are fault indications. You just count the number of blinks occur at a time, by switching the set ON-OFF by its front panel power switch, not by the remote control handset. Just do it for at least three or four times, count the exact number of blinks occurs there, and inform it to me through Fixya. Through the number of blinks, I can locate the faulty section, of somtimes to the exact fault location. Count it keenly and inform me. OK.
Dec 16, 2010 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Standby light stays on and the tv will not go on
Please check batteries in remote that seems not working. Sony TV would either turns On or standby light will blinks if TV gets any internal problem.
You question shows standby light stays On that means TV does not receive power on command from remote.
If standby light is blinking in sequence, let me know how many times it is blinking and also intimate exact model number of TV to find out possible solution.
Thanks.
Sep 21, 2009 | Sony FD Trinitron WEGA KV-34HS420 34" TV
TV won't turn on, standby LED starts blinking
HI, this is the result of an unstable power sector in this unit. the fly back is malfunctioning and, you will need to replace it asap. i will list the part number below and a link to a site as well. you can purchase this part on-line if you wish.
FBT ASSY NX-4521//X4
Sony Part Number: 1-453-310-11
CLICK HERE TO ORDER
Jun 21, 2009 | Sony FD Trinitron WEGA KV-27FS120 27" TV
Blinking Sony Trinitron with no picture or sound
you have a drive ic problem. ic 600, r640 and modification needs to be performed. Take to a Sony servicer. Est.$150 parts and labor
Dec 30, 2008 | Sony FD Trinitron WEGA KV-24FS100 24" TV
Sony Trinitron Blinking Chanel 3
I have a 36 Trinitron, the sound and picture went but the red light just keeps blinking, any ideas? Please ....
Feb 26, 2008 | Sony FD Trinitron WEGA KV-34HS420 34" TV
Tv wont turn back on
Hii.... first I like to know the chassis of yor KV27FS100..
sound like problem with regulated parts block.....and can more helpfull if you count the blinking of the LED....sony have selft diagnostic at the LED Blinking.....
I hope hear from you soon....
Thank's
[Vrya]
e-mail : [email protected]
Feb 23, 2008 | Sony FD Trinitron WEGA KV-27FS100 27" TV
TV will be on for 2 hours sometimes, or 20 minutes then goes off, standby bottom is flashing. and keeps doing that over and over.
Oct 01, 2007 | Sony FD Trinitron WEGA KV-24FS120 24" TV
Sony KP-53S65 53" Rear Projection Television Logo
85 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Steve Allison
Steve Allison
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
