Question about Bosch SHU5316UC Dishwasher
Runs continuous - Bosch SHU5316UC Dishwasher
Does the fan on a Kenmore dehumidifier run continuously, or does it shut off when the set point is reached? I returned a Frigidaire unit because the fan is designed to run continuously.
That depends on the manufacturer and in what mode you are operating it. If it's Continuous Mode. Yes, the fan will continue to run, as it's recirculating the air, in an effort to determine if and when the humidity level rises. Then the compressor will turn ON to extract the humidity.
Also, most units will do this if they are running thru the Defrost Cycle. This happens when the cooling coils frost over. It to, is a normal cycle.
So, if you are operating the dehumidifier in Continuous Mode, it's acceptable.
Hope this helped you. Please let me know. Thanks.
Jun 18, 2011 | Kenmore 54501 Dehumidifier
Water runs continually
No it should only run when the unit is on
Nov 14, 2009 | Aprilaire 600 Humidifier
My fan continues to run even though the heating
Check the fan relay and make sure it is working properly. It might be stuck, which is the most likely problem
Nov 03, 2009 | Heating & Cooling
My dryer continues to run, it won't shut off. When the dryer door is shut it continues to run. When the timer is in the ''OFF'' position the timer runs through to the next cycle.
Hellow, If your dryer continues to run when in the off position you nee a new timer dial switch. I hope this helped you out. It would be greatly appreciated if you coud rate my answer. Thanks Mike-
Nov 03, 2009 | Dryers
Motor is running continuously and is loud
The coil ubder the frig could be filled with dust/dirt and no air is flowing over it to remove the heat. This will causecontinuous running and force the compressor to work harder and louder. A loss of some refrigerant (freon)will cause continuous running but not likely to cause louder running. The fan motor in rear of frig at the compressor could be worn out and running slow or stopped and without this air flow the compressor never stops and runs loud. Also, the door gaskets (especially the bottom part could be torn and bot sealing well; this will cause continuous running but not likely loud running. Goodluck, Macgivor
Oct 22, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
When we shut off tv for the day the fan motor continues to run it does not turn off
the fan will continue to run after the power is shut down on a DLP television untill the set has cooled down . But it should shut off within a few minutes
May 23, 2009 | Televison & Video
Bosch dishwasher timer sticking
I have been told to replace the timer which I am looking to do the same to my machine!
Mar 24, 2009 | Bosch Dishwashers
Dryer wont run
Check the door switch for continuity.
Check the thermal fuse on the heat canister for continuity.
No continuity, bad part.
Mar 03, 2009 | Kenmore 72982 Gas Dryer
Fridge compressor runs continuously
Change thermostat I could go on and on ,but thats it!
Dec 25, 2007 | Refrigerators
Bosch SHU5316UC Dishwasher Logo
52 people viewed this question
Top Bosch Dishwashers Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Bosch Dishwasher Expert? Answer questions, earn points and help others
