Ingenico ict 220
After i changed the paper, the machine fashing TADU v1.08, core app 0047, tsa 0140, and a98 x016d, [0248-014] . it doesn't appear swipe card?
2 Suggested Answers
SOURCE: my nokia e71 camera doesn't
I do that but result is same
Posted on Sep 17, 2011
I dropped it and paper no longer advances.
Yeah, but it appears you damaged the innards! Why else would it not work, n'est pas?
Feb 18, 2016 | Ingenico iCT220 Payment Terminal
TSA opened our lock on our Delsey luggage, I now am unable to lock the suitcase. How can you reset the lock on the Delsey luggage after unlocked by TSA?
1. Look for a small recessed button below (on the bottom side) the TSA key access.
2. Push in the button with a paper clip or pen.
3. While the button is pushed, change the combination to the desired numbers.
4. Then release the button and the combination has been reset.
I also found this, but it needs to be open/
http://www.ehow.com/how_6927475_reset-tsa-lock.html
Dec 08, 2015 | Delsey Helium Shadow - 25 Trolley Luggage...
Ingenico ict 220
Get a technician to replace the gears. It means the gears are worn out and cannot food the paper
Dec 20, 2013 | Retail Supplies
Ibico 1232 adding machine won't print totals
For mine to print I have to hit either the subtotal key, or the total key. (# and/or * )
Jun 05, 2013 | Universal Office Adding Machine/Calculator...
I am trying to repair my Visionman PC WGMA-2A7810 and in the specifications paper work it doesn't appear to list the motherboard information, so I don't know what part to buy. Can you please help.
Every motherboard that has an AM2 socket will work - preferably one with an AMD 7xx chipset. One like
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=5019773&CatId=2320
Sep 07, 2011 | Visionman AMD Spider Phenom Gaming PC -...
THE RECEIPTS ARE ONLY PRINTING HALF-WAY. IT APPEARS AS IF THE INK IS LOW. I TRIED TO CLEAN THE PRINT HEAD BUT THAT DID NOT WORK.
There is no ink in this machine. Try changing the paper. If that doesn't work, then you need to either a)replace the spring that holds the paper cover closed so that the paper is pressed tightly against the print head or b) replace the print head. You can also try using a rubber band to hold the paper cover closed more tightly. If the spring is the problem, a rubber band will do the same thing.
Jun 29, 2011 | VeriFone (M19755014US1) Magnetic Card...
We've changed the roll on our Ingenico 7810 and it won't now print. The paper comes through, but there is no image on it. The paper is in correctly, i.e. roll feeding from up and underneath towards the...
That is a thermal printer. The print head uses heat to react with the paper to make it turn dark. If the paper is not installed upside down, then the issue is the printer itself and since it does get hot it will burn out. Time for a new one I am afraid.
Oct 23, 2017 | Ingenico Office Equipment & Supplies
Hi i get a set counter on my 220 what does that mean
I think it means that the machine is set up for a key counter , you need to enter the engineers service program mode and set copier 5 - 113 from 1 to zero.If you don't know what you are doing with the service program mode be very careful, if you get lost turn the machine off at its switch then start again.
enter service mode through the control panel -- press in sequence yellow button , 1, 0, 7 , press and hold orange button for at least 3 seconds - this should enter mode, repeat if it doesn't. press 1 to select copier OK, 5 to select mode OK , scan through using the previous and next buttons to 113, OKpress 0 then OK to change .exit mode by pressing exit repeatedly until normal screen appears
Jan 03, 2011 | Ricoh Aficio 220 Laser Printer
Missing of code number.
0013 0047 0049 0056 0075 0093 0104 0136 0140 1120
good luck this is a useless device. I can't get the code to work for my LG lh-d6246 dvd player and I have the book
alan
Dec 30, 2008 | Universal Remote Control Remote Control
Computers & Internet Logo
549 people viewed this question
David Payne
David Payne
